Does the Javelin have a ghost?
Ok, this one's got all of us baffled.· We set up serial communications from the PC to the Javelin through the JIDE Port.· We sent a simple ASCII character to the Javelin to perform a logical "or" operation on it to confirm that it was sending back the correct value.· Well, we found out that when you have your rxUart set up for the COM port instead of the JIDE port were the information is coming in on, the Javelin will automatically echo back the same information sent.·· EVEN IF THE POWER TO THE JAVELIN IS OFF!· Why would it do this?· Is it some kind of built in error checking or is the board wired in some weird way?·
atekippe
ISU
atekippe
ISU
Jon Williams
Dallas, TX· USA
atekippe
atekippe
