SX18 & SX28 with the SX Tech Board
Hi,
I'm new·to the SX and I'm looking to order the SX Tech Tool Kit to be shipped to the UK.· Before I do I would
like to ask, does anybody know if the SX18 chip fits this board like the SX28 does (same DIP socket) ?
This details for the chip,·shown on this site, seem to suggest it does.
Many thanks in advance
Tony
Tony
Jon Williams
Dallas, TX· USA
(like is used in the line-follower board)
It is not difficult.· The SX key comes with a good data book that has a schematic for the SX-Tech board.· It is pretty simple to adapt this schematic to the pin-out of the SX-18 using a protoboard, IC regulated power supply (w/ capacitor), 10K ohm pull-up resistor (for the reset circuit) and a couple of jumper wires.· Takes about 8 minutes and will cost you about $7.
Nate
·· I would imagine it shouldn't be too difficult to design a small adapter board to plug into the SX Tech Board socket which will route the appropriate pins to those on the SX18.· Had I a need for it now, I would probably design my own...Who knows, maybe I still will anyway.· If I draw one up on ExpressPCB, I will make the file freely available.· If not, anyone else up to it?
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Jon Williams
Dallas, TX· USA
··· chip notch is V
1·-|----V
|- 8
2·-|··········|- 7
3·-|··········|- 6
4·-|
|- 5
Cut off pins 3, 5, and 18-25·of the 28 pin dip socket.
Cut off pins 3-6, 13 and 14 of the 22 pin dip socket leave enough metal to solder to but not make contact when popping the 22 pin socket in the 28 pin socket.
Plug 22 pin socket in 28 pin socket with bottom of the two·sockets flush (pin 11 of 22 pin socket·into pin 14 of 28 pin socket).
Solder the following jumpers, the first number is 28 pin socket push the jumper wire into the socket hole (solid wire works best), then solder wire·to the underside of the 22 pin socket pin given as the second number:
1· -> 4
2· -> 17
4· -> 6
6· -> 20
7· -> 21
8· -> 2
9· -> 3
14-> 13
15-> 14
16-> 15
17-> 16
26-> 18
27-> 19
28-> 8
plug the two sockets into the tech board,·continuity test·all connections (but not the four corner holes, the extra 4 holes are for stability of the two dip sockets when mated)·with thier correponding breadboard connection·to make sure they are properly mapped (use figure 1.1 of SX user guide as reference).
plug your SX18 into the 22 pin socket leaving the four corner holes unused. now·the tech board pins are mapped to an SX18 and you should be able to program and debug your SX18.
Paul
I can draw a figure later if you are confused
Bean.
Jon Williams
Dallas, TX· USA
I think those must all be the DIP-18 package. I ask because I'd like to get ahold of about 36 of the SX18AC/SO in the surface mount package., to stuff into some existing boards. I think I cleaned out the Parallax stock of those. If anyone has some they don't need, please contact me off list.
Tracy Allen
www.emesystems.com
Jon Williams
Dallas, TX· USA
