Servo voltage
Still having problems with my servos (see earlier·thread).· What voltage do the control pulses work at?· According to the SumoBot manual it says that the pulses are at 5 volts, if this is true I must have a problem with my board as I only get around 300 millivolts, or is this just because of the short pulses.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Post Edited (Dave Andreae (Parallax)) : 1/1/2005 7:08:54 PM GMT
Your comment about short pulses is on the right track. At 1.5 millisec out of 20 millisecs, it comes in under 8 percent in an idealized standard or 800millivolts. [noparse][[/noparse]The BasicStamp's software probably doesn't support these figures and 300 millivolts may be in the ballpark]
Your meter is likely averaging the readings of the on/off and coming way down. You really need a scope to read the voltage accurately.
A similar thing happens with AC and we use a value of 0.707 to adjust the duty cycle [noparse][[/noparse]this is a sine wave, not a digital square wave] or about 71% of the peak voltage - so 120 volts Ac requires insulation for roughly 170 volts [noparse][[/noparse]the actual peak voltage] minimum.
In other words, though most people think that household AC is 120volts, it is really 170 volts at its peak, but we commonly accept the average because it is what is displayed on a meter AND it is the useful figure for calculating power consumption.
G. Herzog in Taiwan
Just·tried it again with a new set of batteries, the right servo started rotating clockwise (forward), then slowed down (my attempt·to get it to stop using the programing changes), it then reversed and then continued to run in reverse.· I then hit the reset button to restart the programing and the servo continued to run in reverse neither changing speed nor direction.· Any·ideas, or·are both servos shot.·
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 1/5/2005 1:37:19 AM GMT
I have attached a copy of the program to the message
' Mini Sumo 2.1 : Motor Test
' {$STAMP BS2}
[noparse][[/noparse] I/O Definitions ]
LMotor CON 13 ' left servo motor
RMotor CON 12 ' right servo motor
[noparse][[/noparse] Constants ]
LFwdFast CON 1000 ' left motor forward; fast
LFwdSlow CON 800 ' left motor forward; slow
LStop CON 750 ' left motor stop
LRevSlow CON 700 ' left motor reverse; slow
LRevFast CON 500 ' left motor reverse; fast
RFwdFast CON 500 ' right motor forward; fast
RFwdSlow CON 700 ' right motor forward; slow
RStop CON 760 ' right motor stop
RRevSlow CON 800 ' right motor reverse; slow
RRevFast CON 1000 ' right motor reverse; fast
[noparse][[/noparse] Variables ]
pulses VAR Byte ' counter for motor control
[noparse][[/noparse] Initialization ]
Start_Delay:
PAUSE 20 ' time to disconnect cable
[noparse][[/noparse] Main Code ]
Main:
FOR pulses = 1 TO 2000 'stop right motor
PULSOUT RMotor, RStop
PAUSE 20
NEXT
FOR pulses = 1 TO 50 ' forward slow - about 12 inches
PULSOUT RMotor, RFwdSlow
PAUSE 20
NEXT
FOR pulses = 1 TO 50 ' pivot turn - left wheel (ccw)
PULSOUT RMotor, RRevSlow
PAUSE 20
NEXT
FOR pulses = 1 TO 50 ' forward fast
PULSOUT RMotor, RFwdFast
PAUSE 20
NEXT
FOR pulses = 1 TO 30 ' spin turn - clockwise
PULSOUT RMotor, RRevFast
PAUSE 20
NEXT
Hold_Position:
PAUSE 20
GOTO Hold_Position
Jon Williams
Dallas, TX· USA
