Periodic Error: Hardware communnication failure!
I have a BS2 with a USB BOE Rev B. It has been working fine for the past week, but today has started giving me sporadic errors while trying to download programs to it. The error I get is:
Hardware communication failure! Check serial cable and power supply.
Immediately downloading again works fine.
I don't know if this is related or not, but this is also the longest program I've written for it, although the failure occurs at different points in the download and occasionally quite early.
Any thoughts or suggestions?
Jim
Jim
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Jim
Just for the heck of it, if you have a spare battery (don't use the one in the smoke detector
I will never use a battery when programming....just an old habit from working in a tech shop and trying to flash bioses on a bad power day!
Steve
Click on "Control Panel"
Click·on "Systems"
Click on "Hardware"
Click on "Device Manager"
Click on "Ports"
Click on the com port that you are using
Click on "Port Setting"
Click on "Advance" and change the "Latency" from 16 to 1 and this should solve the problem.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Dave gets a new kwepie doll...
Ok, it's a Surf, but it's the closest one there.
Dave, Thanks for the help. Before the change I could download 3 or 4 times without the error. Afterwards, well, let's say I got tired of counting around 25.
Cheers,
Jim
