Servo Percision
What level of percision can you get from a standard servo?
Stepper motors can get down to "microsteppers" like 50, 000 steps per rotation, I definitly do not need that kind of percision.
A server turns 180 degrees, how many steps does it take to turn the 180?
My plan is to setup the servo to connect to the guide rod, sort of how a car windshield washer motor is setup, less the wiper arms, I only need lateral movement.
Thanks for the help.
Besides working with Parallax robots, I work with industrial CNC machines.
Here are a couple notes that may help you out. First hobby servos depend on a electronic circuit that uses a variable resistor(pot) to give a feedback to where the servo arm is at in relation to the signal sent by the BS2. I do not believe you can place a hobby servo arm to the percision you need ( 0.25 mm equals about 0.010" ). Industrial servos use encoders, not pots for movement feedback to the servo circuit. There are number of good articlies on the WEB that explain how hobby servos work and how you can modify them do all kinds of things they are not suppose to do. But I believe Stepper motors would still be a better and·easier choice, not knowing what you are actually trying to do.
Joe Fishback- Fishback Designs
This is only my opinion, other people may differ.
kelvin
I've started another thread on stepper motors, in paticular the one offered by parallax. Not sure if its gonna do the trick or not.
Johnny
