help
MacGeek117
I have a question. I'm going to build a robot that uses 2 Stamps together
for extra computing power. I need to use the SHIFTIN/SHIFTOUT
commands, but I don't understand how to use them. There will be
one-way communication only. Could I please have some help? -bugg
The Help file shows how to connect two BASIC Stamp through a serial connection with flow control, and the article below will give you even more details.
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv81.pdf
The article will show you how to have bi-directional communications between the Master and Slave using just two pins (one for serial, one for flow control).
Jon Williams
Dallas Office
commands, but did not know if they would work. Can I also ask if my idea for the robot
will work? -bugg
-bugg
Jon Williams
Dallas Office
was unsuccessful. There is a book that you might have already read but is very
interesting. Build your own Robot. -bugg
Jon Williams
Dallas Office
communicate with it.-bugg
