Power supply
Hello,
I have been experimenting with a posible robot using 2 pager motors. I made my own wheels and I have a bsii and sx28s. I have a lm293d motor controller or I can use a discrete component halfbridge. My problem is that I want to make this robot small and I would like to use 1 9v battery for all power. Is there a way to split power for motors and 5v regulated for the stamp. Years ago I had bought a tab robot kit and it ran on 1 9v.
Curtis
Curtis
Jon Williams
Dallas Office
Rick
I will be using one 9 volt battery and a 78l05 5v regulator with a discrete half bridge.· Any hints on splitting the 9v to power both the microprocessor and supply the motors?
Curtis
Are you stuck with a 9V for some reason ?
Bean.
I dont need a 9v battery I just thought that the sx needed a 5v regulated power supply. I will use the sx28 I must have misunderstood. Are you saying that 3 volts is fine for the pager motors and the sx28. Sorry for so many questions.
Curtis
