max7219 interface with BS1 debuging assist — Parallax Forums
nick bernardnick bernard Posts: 329
edited 2004-12-23 00:18 in BASIC Stamp
i have a small pcb with a max7219 and 4 7 seg displays. its works just fine w/ a bs2p via the 3 wire serial interface (shifting)
if i hook it up to a bs1 running a simple routine the max7219 does not respond to any commands
also the shifting routine on the bs1 works fine with a tpic6a596 shift register in another applicaion of mine.
i just modified it to shift 2 bytes and latch.
here's the code and schematic where R9 = 68k
anyhelp?
nickB
League Bowling.... it's not a sport, it's a way of life
    edited 2004-12-22 18:40
    The MAX7219 is expecting bits MSBFIRST, so the following [noparse][[/noparse]partial] example should get you going:
    SYMBOL  shftDat = B0         ' byte for MAX7219
    SYMBOL  shftMSB = BIT7       ' MSB of shftDat
    ' put byte for MAX7219 into "shftDat"
    SHIFT_OUT_MSB:
      FOR idx = 0 TO 7           ' shift eight bits
        Dpin = shftMSB           ' put bit on data pin
        PULSOUT Cpin, 1          ' clock the bit
        shftDat = shftDat * 2    ' shift bits left
      NEXT
      RETURN
    Jon Williams
    Dallas Office
  • nick bernardnick bernard Posts: 329
    edited 2004-12-22 21:29
    HAIL JON
    thx for the help
    i got it now... also i had to throw in a dirs line in there too
    ROX ON
    nickB
    Yep, you have to do that -- sorry I forgot to mention it -- as
    Dpin = shftMSB
    is like saying
    OUTx = some_bit_value
    If the pin has not been made an output then there will be no change of state on it.
    Jon Williams
    Dallas Office
