Need a stable reading
I am using BS2 and ADC0831.
I have attached my code herewith which I got from the manual.
I just want a stable reading coming out of the A/D. I can see a voltage representation as well as 8 bits binary representation of the analog input I am using but my readings seen on debug screen are fluctuating like anything.
I assumed that the reading out of the ADC would display simply the amplitude voltage of the analog input which is what I am looking for.
I need to send the 8 bits binary data to Labview and am displaying a digital value in there.
Any advice please.
Any advice please.
Also, doesn't it take some time for the ADC to make its reading? Are you giving it that time?
And do you have a common ground?
Sid Weaver
4 digit serial LED
http://hometown.aol.com/newzed/index.html
Dave
I also tried keeping the CS high and that gives 11111111 and 5V reading.
The code I attached has been retrieved from the manual so I know it is right.
I am however not able to get a stable reading for the output coming out of A/D.
Can someone please help.
That does not change the fluctuations.
I had my Temp Sensor on separate board and my BS2 on separate board. And though both of them were grounded, they didnt have common ground.
Thanks alot for your help.
