New USB SX-Key?
At our product planning meeting yesterday there was a discussion regarding the SX-Key and possibly changing it to USB.· At issue is volume, and being a specialty device, we would have to go one way or the other.· What we do know is that the SX-Key works with the FTDI USB-Serial adapter that we carry, so one can use a USB port today.· Your thoughts would be appreciated.
Jon Williams
Dallas Office
Post Edited (Jon Williams) : 12/3/2004 4:29:55 PM GMT
Jon Williams
Dallas Office
I vote againt a direct USB version. First, I use a 486 laptop without
usb for field programming. Secondly, with your adapter I have the choice
between serial or usb. Also, the serial programming protocol is public
and (easy) to implement for other platforms than windows.
regards peter
Another good reason is that USB supplies power also, so goodbye wall-wart too. And with the notebook, I cannot do any SX-key stuff unless I'm near an outlet (great I just bought that expensive long-lasting battery and I have to plug in the SX-Tech board·anyway).
No disrespect to Peter, but serial is just about history, USB is going to be here for quite awhile.
Bean.
Jon Williams
Dallas Office
Yes, at some point a USB only version will probably be necessary, but for now I don't see that the benifits exceed the cost.
Bean, using the USB power to supply juice to a circuit you are breadboarding or that is otherwise not totally stable strikes me as asking for disaster. At a minimum, I would recommend connecting through a powered external hub so that if something frys, it MAY not make it back to your laptop.
Also, read the specs on those long-lasting batteries and I'll bet you find they are only good for 50 or 100 cycles... then you get to buy them all over again. (voice of experience here) laptops need to be plugged in whenever possible.
James Newton, Host of SXList.com
james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
A USB to Serial converter is becomming a commodity item -- cheap, re-usable. If you have a laptop, and you *ever* want to talk RS-232 again, you'll need one. Since RS-232 is so simple and straightforward for micro to micro communications (ie SX28 to SX28, or SX28 to BS2) you might as well get a good converter now so your PC can 'stand-in' for any RS232 device.
It is *impossible* to make a USB-Master device without some hard-disk-drive to keep the drivers (as far as I know, at this time). Thus the only device which will be able to use the USB-SX-Key would be a PC which had the correct drivers loaded -- at this point, Win98 or later. I don't know what implications this has for the Mac.
Also, I'm pretty sure that USB is capable of the 150mA I saw on the data sheet by the rules of the spec (implementatons would be the deciding factor). Is the Ipp higher than that?
My $0.02, worth precisely what you paid for it.
-dave
This is not a sig. This is a duck. Quack.
Anyway, I am going to vote Serial, since that way you have a choice.· Sure you have to buy an adapter to go USB, but if you don't have USB and the device is USB only, you're out of luck.· Besides, as Jon said, you'd still need ext. power.
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
The combination of a serial SX-Key and a separate FTDI USB/Serial adapter might be more expensive than a USB SX-Key, but it is more versatile too. Ok, someone might consider buying another USB/Serial adapter, possibly cheaper than the FTDI but in this case, Parallax can't make a guarantee that the combination works as expected.
Greetings from Germany,
G
Tracy Allen
www.emesystems.com
Chris
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
Jon Williams
Dallas Office
When I get a newer PC, my older PCs usually hang around for a number of years as project boxes. It's nice to be able to develop on those perfectly functioning older pieces of hardware as well as on my current more modern machine. Yeah, USB is becoming more widespread but with all the serial users still in existance, I think that our death is being reported a bit prematurely.
Very soon we won't even be able to buy serial cables...
William Chan
Jon Williams
Dallas Office
Please remember that a lot of SX boards run at much less than 5 volts, so a USB powered SX-Key would help a lot.
William
They don't want to buy a USB to serial adapter that works. So they ask Parallax to simplify this part of the problem for them. Not realizing that soon, down the road, they're going to want to 'talk' from their BOE to some other RS-232 device -- and only THEN will they realize what trouble they've gotten themselves into.
I expect that 50% of people who buy a BOE never finish all the labs, so it may be a minor issue.
Now, the SX is bought by people who've been down the road with the BOE already. They KNOW the value of a bi-directional port that can run stand-alone (without a connected PC). Well, most of them do.
I'd suggest it's a non-issue. You still have 16 I/O pins that can be used for serial communication with a USB-BOE. Several thousand customers are now using the USB BOE and none have complained about lack of serial I/O through the programming port. It's quite the reverse, almost like you mentioned - several thousand people requested USB.
What we did is not only simplify the issue by eliminating the adapter, we reduced their cost of using a USB port. Now it's the same cost - USB or serial - without the expense of the adapter. We've built it in free of charge.
The most frequent requests were from Mac users who have only USB. We now offer some of the only microcontroller development tools that can be easily programmed on Macs. The other common request were from laptop users. And educators. . . they'd often get a lab of new machines with no serial ports.
Perhaps we will make two versions of the SX-Key, but we'll certainly be keeping serial.
In fact, my Dell Laptop does NOT have serial.· And I had to buy the adapter.· But if I had bought 2 models higher, I'd have gotten a serial port...I just didn't have the other $600.00!·
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
That's cool, thanks for the update. I had not thought about educators, and the troubles they face with USB adapters.
And I appreciate your letting Parallax take the (small) cost hit for putting the USB chip on the BOE. As long as I can still purchase the Serial version, I'm not too worried about it.
I appreciate that I sounded harsh up there. Sorry about that. I think Chris's point about 'hackers' is well taken, though.
- Ken
·· I can see you are passionate about your trade.· I remember my mentor from years ago who taught me much of what I know.· He was passionate about his work, and he loved Vacuum Tube amplifiers, Power Supplies, etc.· He didn't even want to hear about my Integrated Hybrid Amplifier designs when I started my own business.· Of course, he never liked Windows, and was a dedicated Unix/Linux user.· He also thought BASIC was useless...Yet I used it (Compiler Version) for many small applications to cut down development time.
·· I for one am glad that Parallax gave us a choice (A say in the matter).· The votes speak for themselves.· There are more of us that like things the way they are.· Advancement is nice.· But some things are better left alone.· If it ain't broke, don't fix it!· I guess that logic still lives in me.
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
While the vote is currently at 2:1, I'm not sure such a victorious attitude should be adopted. While it's clear that Parallax is going to postpone the development of a USB SX tool, the flip side of the coin is that people like me won't be purchasing an SX system for personal use any time soon (I've been RS-232 free since 1999, and I like it). And while I have an immediate use for one here at work, it would be infinitely more usable with a USB port, since the only serial port I have on my machine is taken up with a software dongle for a heavy duty design tool I use constantly. I have two choices in the matter: Lose a fairly significant amount of productivity to serial port swaps and restarts, or try and convince management to spend another 15% on a USB-232 adapter. I'll likely do the latter, because it's the only way to keep things on schedule, but it's going to make adoption of the SX here slow. I can't tell you how nice it was when we went from parallel and serial based JTAG tools to USB ones. The problems with serial addresses,·time slices,·and Windows as a whole suddenly disappeared, at the same time the bandwidth went up by an order of magnitude.
As for my personal development, I'm going to be stuck with the Stamp for the dually damning reasons of a lack of a Mac compiler and a lack of native USB support. I know I can use the FTDI adapter, but it's a real PITA to carry around with·my dev laptop. I know there are a lot of old-school hackers here who live and die by serial ports.·I used to be one too. For some things, I still am. But aside from a vocal population here, I'm not entirely sure that the forums are representative of the general user base. Let me give you a ferinstance: I know that a program at a local high school was planning on bringing SXs into their electronics course (1 class, 25 students, pilot program), but nixed it this fall after theiy got a new lab of machines without serial. The extra cost ($34 x 25 boxen) was a little too much for them, and they're sticking with Stamps, despite the fact that the students are outgrowing them quickly. Ken·alluded·to similar issues·in a post on page 1, and I've seen it·locally. At some point USB will have to happen, just like the parallel -> serial change happened. Some of us just want it sooner than the others
I'm sure Parallax will do what's best, but for a little longer, some of us will be left out in the cold. Judging by the poll, 'some'·could be·as many as 33%. I think that's really unfortunate if it's true.
Ken...You know where to find a USB SX-Key beta tester if you need one
-dave
Post Edited (Dave Paton) : 12/16/2004 3:32:55 PM GMT
·· One final note, and I will refrain from posting anymore biased opinion (I know, sometimes I ramble)...I just wanted to point out, that the extra cost of adding the USB-to-Serial adpater seems to be the big thing for those who prefer USB, but it was pointed out as well that the cost of the SX-Key would increase as a result of going to USB.· Perhaps not as much as a USB-to-Serial adapter, but the fact is, it will cost more.· I just wanted to make a point of cost is something to consider as well...I guess I take it for granted that I already had to buy a USB-to-serial adapter for my first BOE-Bot, and have since had to use it on my NX-1000, BOE's, Demo Boards and SX-Board.· Anyway, I apologize if I made it sound like the USB votes didn't count...They do!· Parallax sees that.· But I suppose a decision had to be made.· Who knows, a year from now the tables may turn...Change IS inevitable.
PEACE!
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
