EE newbie resistor placement question...
Hello, in the attached picture, there are 4 leds that have 4 resistors. and is powered by 5v.. Lets say the pins on the left side is a bs2 sinking all 4 pins.
My question is, why not put 1 resistor at the top (right after the 5v is applied to the line).. then we will not have to worry about the other 3 resistors.
I was wondering this because.. on my mcp23016 chip, I have to have some pullup resistors to assign an address to the chip.. and was wondering why I had to use a pullup resistor for each pin that needs to be high
Hopefully my wording wasn't to confusing on such a simple question
thanks for the help [noparse]:)[/noparse]
Lee
Lee
As for resistors for pulling up lines on inputs...There is no way to share a resistor...Per se...All the pins that shared the resistor would effectively be tied together.· Individual resistors ensure that each line remains independent.· If your address lines need to be able to be changed, you wouldn't be able to employ this method at all.· And I wouldn't recoomend it anyway.· If you need seperate pull-ups, use them, since resistors are cheap anyway.· Is space is an issue, consider using a SIP resistor pack.
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Jon Williams
Dallas Office
