Serial port timeout...
I've been playing around with my new Javelin Stamp (using the USB-BOE) for a couple of days now and have had great·fun flashing LEDs, etc...· Yesterday I started trying to control a servo using the PWM object and, after some initial success, have a problem that I can't figure out how to fix:· I've used the IDE to download about ten revisions of a simple program, but something has happened that's preventing me from downloading any new programs to the chip.· Specifically, when I select the "Program" action from the "Project" menu on the IDE, the pop-up dialog displays "Resetting Javelin" and then "Downloading Program", but shortly afterwards I see
"[noparse][[/noparse]Error IDE-0022] Error reading from the serial port (timeout)"
at the bottom of the IDE.· I've tried restarting the IDE, disconnecting and reconnecting the USB serial cable, rebooting the (XP) machine, and disconnecting and reconnecting the power·to the ·the Javelin Stamp, but nothing has solved the problem.
Anybody have any ideas?· I was doing so well· [noparse]:)[/noparse]
counter
counter
regards peter
Thanks very much for the advice, but unfortunately it didn't help-- I'm still seeing the same problem even after a hardware-restart of my XP box.
Another data point:· I'm able to successfully invoke the "Test Connection" action from the "Project" menu-- the Javelin Stamp is found successfully.
Again, thanks for the help. Any more ideas? I'm pretty well stopped dead here [noparse]:)[/noparse]
..counter
with nothing connected to javelin.
Check your Vin voltage (pin24) (do you use batteries?)
and check if pin21 (VDD) outputs 5V.
Also try re-inserting javelin in socket (if any).
regards peter
Thanks for the reply.
With respect to the "Identify" command-- it does work, successfully finding the Javelin on COM4.
With respect to Vin-- I'm showing 12.5 volts between Vin and Vss, which is a little alarming because my AC adapter (so no, I'm not using batteries) is clearly marked 9 volts. Could this be the problem?
Vdd to Vss shows exactly 5 volts.
Following your advice, I removed and re-inserted my Javelin into the socket on my carrier board (a BOE USB, rev
Again, thanks very very much for taking the time to think about this-- I really appreciate your advice. Any recommendations for other things I could try?
..counter
There's also another thread in this forum discussing the same problem: http://forums.parallax.com/forums/default.aspx?f=8&m=4723
..c
I just plugged my javalin into my boe revc board serial connection, and am getting the same problem. I can detect and test Terminal test is on there, and thats about all it'll seem to take. When I try to program something new like hellow world, it links, resets, goes to download, then the terminal pops up displaying the terminal_test app again. about midway through the text being displayed, it seems to drop the serial connection.
This is on a win2k laptop (pII-300) with the latest software on the machine. and nothing else cept for acrobat to read the pdf files.
I also have a bs2 that works just fine with the same battery.
Anyway, this is all new stuff that I just bought a week ago....
Thanks for any help ]
Mark
my bs2 works fine on the laptop though....don't quite understand what the problem is.....
Windows Ver:· XP Pro, w. Service Pack 2
Javelin IDE Ver:· 2.0.3 build 0
Port:· COM4
Baud:· 9600
Data bits:· 8
Parity:· None
Stop bits:· 1
Flow control:· None
[noparse][[/noparse]>Advanced]
Receive:· 4096 Bytes
Transmit:· 4096 Bytes
Latency Timer:· 1 msec
Minimum Read Timeout:· 0 msec
Minimum Write Timeout:· 0 msec
Serial Enumerator:· Checked
Serial Printer:· Unchecked
Cancel If Power Off:· Unchecked
Event On Surprise Removal:· Unchecked
Set RTS On Close:· Unchecked
Port Driver Ver:· 1.0.2151.0
The settings seem pretty standard and I've played around with them until I couldn't stand the sight of the device manager anymore, but nothing has revived the chip yet.· The Identify and Test Connection commands work,·but it times out when you try to download a program.· With Ryan I set the latency to 1 and·reinstalled the Parallax-specific driver files, but nothing has worked.· The only thing different about the last program from the other 20-or-so was that it was the first time I'd tried using a UART within an endless loop.· I think the program sort of worked the first time, but the chip's been useless since.· Will an endless loop void any attempt to reprogram the Javelin?· If so, is there a way to manually clear the memory?
Thank you in advance for any suggestings,
DaFonz
I have been having the same problem with uart's in an endless loop. The senario is nearly identical to what dafonz described. I have, however, both a paralledl boe-bot with one javelin and a usb boe-bot with a second javelin. This problem comes up with both javelins but only on the usb boe-bot.
The problem is resolved by puting the offending javelin into the parallel boe-bot and re-loading it with the same code, re-insert the re-loaded javelin into the usb boe-bot and everything is fine... unitl it happens again...
It is worth pointing out I run the parallel boe-bot on a the same laptop using a FTDI US232B USB to Serial Adapter without any problems.
Before I trash the javelin pins I am buying another parallel boe-bot board and another FTDI US232B USB Adapter.
By "parallel" boe-bot, do you mean using a standard serial cable to program the Javelin?
DaFonz
There are only 10 kinds of people in the world:
Those who understand binary, and those who don't.
My project started out with two javelins. One USB based BOE board and one serial based BOE board. The catch is that the serial board was running from my laptop's USB port though a FTDI US232B USB to Serial Adapter then to the serial port on the BOE board without any problems, until…
I have been following the USB BOE Board/ javelin problem through this forum and have been keeping up with the suggested fixes. When you mentioned your problems with a UART running in an endless loop, I realized that my own problems started when I began working on communicating between my USB BOE board and my serial BOE board through a UART. The program I am working on runs unmodified on both javelins. The only hardware failure I have experienced has been a number of USB BOE board locking-ups. The solution to the problem was to take the offending javelin from the USB BOE board to the serial BOE board system and reloading the program. That worked fine until the next failure, then away we go again.
I now have two serial BOE board systems running from USB ports on my laptop though USB to serial protocol converters (FTDI US232B USB). Since changing to two serial boards I have continued with my UART development without jamming the javelin chip as yet (nock on wood).
From my experience, the problem seems to be related to the on-board USB system.
DaFonz
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
The board I'm using is the Professional Development Board. Since AuburnSky's board was BOE, I'm guessing the problem is in the on-board FTDI. Please keep me updated if anything is ever found.
DaFonz
Unfortunately I don't have a serial BOE to play with. I got desperate so I wired up the Javelin on a separate breadboard with a serial port (see Javelin Stamp Errata v1.3, page i). I got it unstuck, put it back into the BOE and immediately managed to get it stuck again.
I really don't want to buy another board but it looks like I don't have much choice.
Rodney.
