Industrial BS2sx or BS2p24
What components would I need to swap out on the 'sx or 'p in order to allow it to operate down to -20C (preferably -40C)?· I'm not sure if the resonator is the limiting factor, or if there are others.
Thanks for the help!
Dave
Dave
My BS2pe based data loggers are constructed with 100% industrial rated components:
www.emesystems.com/OWL2pepr.htm
It also has the AT45DB041 flash memory with RAM buffers, that allows for data streaming that might be relevant to a separate question you had about rapid memory access.
Tracy Allen
www.emesystems.com
