VAR
Will this work
cat VAR IN4
or do I need something like this
car VAR IN4.Bit1
I looked in help but it wasnt very clear.
cat VAR IN4
car VAR IN4.Bit1
In PBASIC 2.5 an easier way to do that is:
{$PBASIC 2.5} Cat PIN 4 Dog PIN 5 Setup: OUTPUT Dog Main: Dog = Cat PAUSE 100 GOTO Main
In this program Cat and Dog names assigned to P4 and P5, respectively.· On reset, all pins are inputs, so Dog (P5) is made an output.· The main loop causes the output from Dog to follow the input from Cat.· The equivalent code is:
Main: OUT5 = IN4 PAUSE 100 GOTO Main
Jon Williams
Dallas Office
drive PIN 0
forward CON 500
MAIN:
PULSOUT drive, forward
PAUSE 20
GOTO MAIN
Jon Williams
Dallas Office
