Power Resistors and stepper motors
I have a 5 volt, 1 amp 5 ohm stepper motor. After reading that stepper motors should be driven 3 to 25 times higher voltage
I would like to at least try 12 volts on the one I am using as I am using an old PC power supply and running it at 5volts now.
The numbers work out to drive this motor at 12 volts, I need a 7 ohm 25 watt resistor
I have looked at the listings on resistors and I am confused as to what kind of resistor I should use as there are quite a few different kinds.
Ceramic, thin film, and others.
I also would like to verify my thinking as to the wattage needed. If I need 25 watts and 7 ohms
could I use 2-14 ohm resistors with say 15 watts power rating that would give me a 7 ohm 30 watt resistor?
Could I even use 4 28 ohm resistors in parellel ith say 7 watts power rating
I would tend to think a variable resistor would work so I could experiment with higher voltages and keep my current at 1 amp.
If the Stepper Motor is rated at 5V @ 1A, then that's what it needs...If you're giving it 5 Volts and not getting what you expect, then either it's not getting the 1A of current it needs @ 5V, or it doesn't have a high enough rated torque spec for your application.
Wow...125V...That would interesting to see...
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
http://www.cs.uiowa.edu/~jones/step/
lots of tech info beyond me, but it is a good resource.
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
Better to play safe. And i shall keep that in mind on future posts. kelvin
metron9, I hope you get the information you need from someone/somewhere.· Good luck!·
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
