The math of making a motor spin
I was just wondering if someone could explain to me the math of making a stepper motor spin.
I am looking at the stepper motor example that you have on your BS2 examples.
This line makes the stepper go forward
stpindex = stpindex + 1 // 4 ' point to next step
READ (Step1 + stpindex), coils
, but this line makes it go in reverse
stpindex = stpindex + 3 // 4 ' point to previous step
READ (Step1 + stpindex), Coils
I was just wondering how adding 3 and dividing by 4 makes the motor spin in reverse and adding 1 and dividing by 4 makes it go forward?
Step1··········· DATA··· %0101
Step2··········· DATA··· %0110
Step3··········· DATA··· %1010
Step4··········· DATA··· %1001
How does the read command increment to Step2 then Step3, then Step4
We are 3 guys who just can't get our heads around how this is being acomplished.
Post Edited (Acadian) : 11/11/2004 7:40:38 PM GMT
When we do this:
· stpIdx = stpIdx + 1 // 4
It is the same thing, albeit more concise, as doing this:
· IF (stpIdx = 4) THEN stpIdx = 0
The first line works because the modulus operator (//) returns the remainder of a division.· As 4 / 4 is 1 with no remainder, when the value of stpIdx reaches 4 the modulus operator gives us a quick way of moving it to zero.
Going the other direction works the same, but is a little less obvious.· When going forward we added one to our current index; so when going backward we want to subract one from our current index.· But ... we can't simply do that because PBASIC represents negative values in 2's-compliment form.· So what we do, then, is add one less than the total loop value.· What we want is 3, 2, 1, 0, 3, 2, 1 ...
Here's how we get there using the modulus operator:
3 + 3 = 6, 6 // 4 = 2
2 + 3 = 5, 5 // 4 = 1
1 + 3 = 4, 4 // 4 = 0
0 + 3 = 3, 3 // 4 = 3
If we didn't have the modulus operator, we could do this using PBASIC 2.5:
· IF (stpIdx·> 0) THEN
··· stpIdx = stpIdx - 1
· ELSE
··· stpIdx = 3
· ENDIF
I hope this helps.
Jon Williams
Dallas Office
