Code Confusion....
Hi everybody,
Consider the following code:
however, this code executes as:
when using the SXSim simulator.
Now, if a macro like:
substitutes the <jz> compound statement such that:
which lead me to the conclusion that <jz> has the <snz> instruction implemented as <snb STATUS.2>. If that's the case (and it seems so) then the <jz> statement wiil never jump to the address in mind.
If this·bug (which I believe it is) has been fixed in later version(s), please forgive me - I couldn't resist·thinking about·the problem
Kenneth
Post Edited By Moderator (Jon Williams) : 11/8/2004 2:34:44 PM GMT
·mov a,#10
·mov b,a··; b := a
:loop
·sub a,b··; if 0 set z := 1
·jz :loop·; if z == 0 then jump :loop
·nop··; if z == 1 then <nop>
·mov b,a··; b := a
:loop
·mov a,#10
·mov b,a··; b := a
:loop
·sub a,b··; if 0 set z·:= 1
·jz :loop·; if z == 1 then jump :loop
·nop··; if z == 0 then <nop>
·mov b,a··; b := a
:loop
ifz·macro·1
·sb STATUS.2
·jmp \1
endm
·sb STATUS.2
·jmp \1
endm
·mov a,#10
·mov b,a
:loop
·sub a,b··; if 0 set z = 1
·ifz :loop·; if z == 0 then jump :loop
·mov b,a
:loop
.Thanks,
Kenneth
In the first example you have
jz :loop ; if z==0 then jump :loop
The comment does NOT describe the action "jz" means jump if the zero flag is SET not if the zero flag is zero
Maybe that is the confusion.
Bean.
cheers,
Kenneth
