Wifi/ 802.11 Controller
I am working on a project that would send out a wifi/802.11 signal·to be received by an antenna.
Details:
·1. Signal sent out every 15 seconds or so.
·2. Would send MAC ID, and the letter Z (Thats it).
Ideas I've had:
·1. connect something to a laptop card that would power it up every 15 seconds.
·2. Get just a 802.11 chip attached to a 555 and some processor.
Any Ideas??
Details:
Ideas I've had:
Any Ideas??
That said...
Does the beacon need to be seperate from a computer for any reason?
Do you really need to use something as complex as 802.11?
What's attached to the antenna on the other end?
What's the actual goal of the project?
All of these answers will help us help you
-dave
This is not a sig. This is a duck. Quack.
They would go in cars and when they pass by a billboard (or other area), with·an antenna and logger,·the receiver·would see the MAC ID and little other info. They can be initially programmed by a computer, but then act alone. I don't want the signal to reach out 2-3 miles, just about 2-300 feet.
The result of this is, Billboard and marketing companies will know based on the demograhics of the driver (of the car) who sees the advertisement.
Thanks,· Sam
Check out http://www.parallax.com/detail.asp?product_id=30065
Bean.
