BS2P24 Question — Parallax Forums
BS2P24 Question
BrianmcmBrianmcm Posts: 33
edited 2004-11-03 18:21 in BASIC Stamp
I currently have a BS2-1C mounted in the Basic Stamp 2 Carrier Board. I would like to upgrade to the BS2P24 module. Will the BS2P24 module work in my existing carrier board or does it require a different board?
    edited 2004-11-02 20:08
    Yes, it will work in your BS2 Carrier Board.
    Parallax, Inc
  • allanlane5allanlane5 Posts: 3,815
    It should work in your existing carrier board, if you have a 24-pin socket there. The BS2P 'demo' board has a 40 pin socket so you can use the BS2p40, as well as demonstrate some of the I2C functionality -- but it's not required.
  • dandreaedandreae Posts: 1,375
    edited 2004-11-02 20:16
    Hello,
    The BASIC Stamp 2, 2e, 2sx, 2p24, and 2pe all have the pin outs, therefore, you able to use the same carrier board for the BASIC Stamps listed above.
    Dave
  • BrianmcmBrianmcm Posts: 33
    Fantastic, that was the answer I was hoping for!
    Thanks for the help.
