PWMPal and BS1 — Parallax Forums
PWMPal and BS1
DonivanDonivan Posts: 23
edited 2004-10-27 20:42 in BASIC Stamp
Is it OK to use the PWM Pal appMod with the BS1 Rev Dx?· I'm assuming output from the PWMPal would still need to be buffered via Darlington array IC (that's what I'm planning anyway).· Other than the physical hookup, are there any other gotchas on using this combination?
Donivan
  • DonivanDonivan Posts: 23
    edited 2004-10-27 17:51
    Oops RTM, yea. Looks like the BS1 max serial is 2400 BAUD and the PWM PAl's minimum is 9600, so from the docs it looks like it won't work. OK on to plan B...
  • AlWilliamsAWCAlWilliamsAWC Posts: 135
    edited 2004-10-27 18:32
    Consider a PAK-Vc (http://www.awce.com/pak5.htm) which can be set to 2400 baud for just this reason. Also, the PAK-VIII (http://www.awce.com/pak8.htm) can produce PWM with a bit of work and is not baud rate sensitive at all. If you just want 8 channels of 8 bit PWM, stick with the PAK-V. If you want to do some other things (for example, drive servos) the PAK-VIII might be the ticket.
    Al Williams
    AWC
    http://www.awce.com
    Thanks Al, looks like that will work.· I'll check it out.
    -Donivan
