Device config window, and Device Directive in code listing...
Hi all,
I'm having a little trouble programming my SX chips to work correctly with the 50mHz
ceramic resonators. Also I'm having trouble with the "Device" window behaving poorly.
My main problem is that the SX-Key software appears to override any device directives
listed in the code. OSCHS2, for example will not be properly programmed into the SX chip,
unless the "Device" window is updated the correct oscillator also. Also, the "Device" window
settings are not saved·at all. Thus on subsiquent restarts of the·SX-Key software, previous configurations are lost.
Maybe I'm missing something here, but I would think that the code directives should override
the SX-Key directive?!? I would think that this would help to ensure proper directive being programmed into the chip.
Also, the "Device" window seems unreliable at times. Clicking on some check boxes and radio buttons· 'greys' out some settings that are avaliable when the window is open even when they appear to be unrelated. (Changing boxes and buttons back does not return the options)
Any insights that I'm missing???
Thanks!
Dan
Thanks!
Dan
My personal advice (others pay disagree) is to treat the device window as basically a "read only" dialog. All settings you want to make need to be in your "DEVICE" directive(s) in your code. Anything you have in the code will supercede the device directive and set the various checkboxes, etc on it.
Try this experiment:
1 - Load the source for a working project into the editor
2 - Open the device window and move it so you can still see it when the you are working in the editor.
3 - Assemble the code.
4 - Change the DEVICE directive in the code so it uses a different chip. For exampl,e, if you're using the SX28 in the DEVICE directive, change it to SX48
5 - Assemble the code while watching the device window.
You'll see that as soon as you assemble the code, the device window is updated to reflect the DEVICE directive in your code. The moral of this story? Don't try and "set" things in the device window, just treat it as a way to load and save hex files, and to visually confirm your DEVICE directives.
Thanks, PeterM
If the directives are ordered improperly, it appears that the default setting are recalled...
Try the directive like this...
DEVICE·SX28L···· ;28 pin chip
DEVICE· OSCHS2··;(OSC or External TTL OSC)
Then try the directive like this...
You will get different results with Each example...
Ok, so the question is, what is the proper order of operations when
setting the device directives in code???·
Is the directive specifying·which mcu is the target device the only important one?
-Dan
Bean.
I can only confirm this - I always use the DEVICE line in the source code to configure the SX.
Greetings from Germany,
G
