DAC7612 Digital to Analog converter, only 11 bit resolution — Parallax Forums
K de JongK de Jong Posts: 154
edited 2004-10-25 00:11 in BASIC Stamp
Hi all,
I have built a prototype with the DAC7612 DA converter.
The datasheet specifies 12 bit resolution, =4096 steps from 0 to 4.095 Volts (1 mVolt each). But I only get out 2048 steps = 2 mVolt for each step.
Below is the routine I use. I have to devide my variable OutDAC by two because of the resolution problem.
WriteDAC:
HIGH LOADDACS
LOW CSDAC
SHIFTOUT Dout,Sclk,MSBFIRST,[noparse][[/noparse]ChDAC\2,(OutDAC/2)\11]
HIGH CSDAC
LOW LOADDACS
RETURN
Also a graph of the DAC output versus time is atached.
Does anybody have a good idea where to find the missing bit ??
Thanks in advance,
Klaus
  • NewzedNewzed Posts: 2,503
    Klaus, try writing:
    SHIFTOUT Dout,Sclk,MSBFIRST,[noparse][[/noparse]ChDAC\2,(OutDAC/2)\12]
    Sid
  • K de JongK de Jong Posts: 154
    And this code goes first, Of course smile.gif)))))))))).
    OutDAC VAR Word
    ChDAC VAR Nib
    OutDAC=0
    ChDAC=2
    DO
    IF OutDAC>4095 THEN OutDAC=0
    OutDAC=OutDAC+2
    ChDAC=2
    OutDAC=OutDAC+2
    ChDAC=2
    GOSUB WriteDAC
    ChDAC=3
    OutDAC=OutDAC-500
    GOSUB WriteDAC
    OutDAC=OutDAC+500
    PAUSE 200
    DEBUG CR,DEC OutDAC
    LOOP
    Klaus
