Driving a unipolar stepper motor with only two outputs
Hello,
I need to drive a unipolar stepper motor with only two outputs.· I found a simple circuit that uses a ULN2003.· It says that since coil 1 and coil 2 are always the inverse of each other (i.e. if coil 1 is high, coil 2 is low),·and like wise with coil 3 and coil 4, you really only need two inputs.·
Can anyone walk me through this circuit? (See figure 1)
http://www.eettaiwan.com/ARTICLES/2002MAR/PDF/2002MAR08_AMD_MPC_AN81.PDF
What is the 5V for? Could I just use a flip flop to provide the inverse voltage?
Thank you so so much!!!
-Eric
-Eric
If you want to go independent of the stamp, you'll need a clocked state machine to do the dirty work. From my quick notes, it looks like a 3 bit counter might do the job, but you'll want to do a proper state machine design to be sure. Google would be your friend here.
The +5V and the 1k resistors turn outputs 6 and 7 into inverters feeding inputs 2 and 4. No need to provide the inverse voltages, as they are provided for you by some trickery and the ULN2003 itself. The ULN2003 is an inverter as well as a driver, and those outputs, being 'spares', are put to good use making the 4 output system drivable with only 2 inputs.
What is your goal with the circuit? Are you trying to run it without a stamp?
-dave
This is not a sig. This is a duck. Quack.
I am trying to run 2 stepper motors, two contact sensors, and 1 solenoid with a Basic STAMP. That's 4+2+1 = 7 i/o pins.·
It's for a robot that navigates a cooper tape bullseye and drops off a payload.
I'm running a 9v motor instead of a 12v motor as pictured in the diagram.· I assume I can just keep the 5V--it corresponds to the stamp's output voltage.· Can I get the 5 volts from the stamp's onboard regulator?· I assume it doesn't draw much current?
Thanks Again!!!
Eric
p.s. I like your slogan... I program with solder!
A +9 motor, yes, switch +12 for +9. I'm not sure about usign the onboard regulator for the +5 tho. It really depends on how much current will be delivered to other drvices. The onboard Vreg on the BS2 is only good for about 100mA total as I recall, so be careful where you decide to have the stamp push current.
Personally, I always use an outboard Vreg for +5, since I usually have more than just the stamp using that voltage, and I often use local ultra-low LDOs with a switching supply (for efficiency).
As for my slogan...I'm a EE. I code for fun, but I solder for food.
-dave
