Can microcontroller count objects??
Hello...
·I'm new in microcontroller. I'm doing a project using microcontroller for my final year project. I wanted the microcontroller to count up to 15 before it can trigger a solenoid valve to execute the work intended. I faced a problem in making the controller to do that. The solenoid valve is triggered even if its only count up to 1 or 2.I don't want this. Can microcontroller do this job or not? Can it count? I mean counting objects, not time. Or do·I need to use an interface for it?
·Thanks..
·Thanks..
A. Wait until you see an object
B. Wait until object goes away
C. Add 1 to count
D. Go back to A
Jon Williams
Dallas Office
To trigger the solenoid valve you need a condition like this:
if x=15 then goto trigger_valve
where trigger valve is a routine in the program which trigger the solenoid valve
so you would be pleased if you kan give me some REALLY low cost ideas.
i get 380dkk(im danish(to do dollar to dkk you should multipliced it with 6,5 and then plus 25%, and then plus 70 for import)at month an i get MAX 2000dkk in birthday and cristmas.
PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Please explain what you are looking for.
Low cost ideas for robotics? A low cost robot? A low-cost microcontroller? Low cost sensor? Everything?
Give us some details about what you are looking for and we can help. if you want some good assistance in Danish, you could always ask our distributor:
DENMARK
Penil Design
Maaloevvej 96
DK-3660 Stenloese
Phone: int +45 48195252
Fax: int +45 48195251
Web: http://www.penil-design.com
Email: peer.nielsen@penil-design.com
But we can help you here as well.
