What is wrong with this servo controlling code?
Sorry for the flood of posts, but I am just excited about getting started on my new project[noparse]:)[/noparse]
I have a servo with these specs:
http://www.gws.com.tw/english/product/servo/servo.htm
most notably:
[list=4][*]Pulse width range (Frame time· : 16-23 ms)
[/list]Max : 2.1 ms
Min· : 0.9 ms
and
Why doesn't my program run the servo with the above specs?:
' {$STAMP BS2}
Servopin CON 7
Temp VAR Word
start:
· FOR temp = 200 TO 1200
· PULSOUT Servopin,temp
· PAUSE 17
· NEXT
· FOR temp = 1200 TO 200
· PAUSE 17
· NEXT
GOTO start
? Is it because of the 200 to 1200 and 1200 to 200 declarations?
I do have my servo hooked up to the bottom left pin on my bs2 (isn't that pin7?)
thanks Lee
most notably:
[/list]Max : 2.1 ms
Min· : 0.9 ms
and
' {$STAMP BS2}
Servopin CON 7
Temp VAR Word
start:
· PAUSE 17
· NEXT
· PAUSE 17
· NEXT
GOTO start
thanks Lee
We've worked a lot with the GWS servos. Your lower value of 200 (400 us) is probably out of the servo's range of motion. According to their datasheet 0.9 ms (a PULSOUT of 450) is the lowest value you can send to the servo, so you're pushing against the mechanical stop and unless you wait a long time (you are stepping 2 us at a time) it might not move. I've seen GWS servos not match the specified values exactly, so I wouldn't be surprised if their data is a bit off. In fact, that's part of the reason we've switched to Futaba (for the Boe-Bot at least). How are you powering the servo? You can't connect it to the Stamp's 5V due to current source limitations, so use an external power supply of 5-6V and connect the grounds together.
Try this:
' {$STAMP BS2}
Servopin CON 7
Temp VAR Word
start:
FOR temp = 500 TO 1000 Step 5
PAUSE 30
NEXT
FOR temp = 1000 TO 500 Step 5
PAUSE 30
NEXT
GOTO start
Once you have it working you can experiment with different values. This range will play it safe between 1 and 2 ms, which is clearly within their range of motion if the datasheet is almost correct.
I am powering the servo with a seperate power supply (6v· 1.5amp) (power supply is known good).
The pins I am using are known good.
When I plug in the servo to the power supply, I hear it move for an instance.
What can I do?
thanks for all your help!
Are your ground lines connected (from the stamp power·to the servo power)?
Peter
Dr. Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
servo:
power supply + > servo +
power supply - > servo -
bs2 pin 7 > servo Signal Line
then.. all the basic stamp's grounds are connected to the 9v battery and ground for the serial port.
Should it be different?
All the ground lines should be tied together (Stamp, Serial Comms and Servo power supply).· That should solve the problem.
peter
That fixed it.
Thanks cyberbiota and Ken, I would of NEVER figured this out without ya'll
I am so excited [noparse]:)[/noparse]
