tabrokit sumobot programming — Parallax Forums
DrewdawgDrewdawg Posts: 12
edited 2004-10-14 22:35 in BASIC Stamp
i'm trying to get my bot to go forward for an allotted amount of time and can't seem to get it to work, can anyone help me out?
  • Russ FergusonRuss Ferguson Posts: 206
    edited 2004-10-05 13:36
    The 'forward' time on the Tab SUMOBOT is determined by the number of times that the 505 receives the forward instruction. Each forward instruction should have a pause between between it. The pause can be up to 180. A pause that is longer than 180 caused our robots to have choppy·movement.
    The total 'forward' time is:
    · 'forward'·command to 505
    +· pause 180
    ~ 180 m sec
    *··10 loop iterations (number of times this loop is performed).
    ~ 1800 m sec
    I have attached some code with comments which may be interesting.
  • DrewdawgDrewdawg Posts: 12
    edited 2004-10-06 13:37
    i now understand exactly how to make my bot do everything but one thing, how do you tell how many times to loop, you said the command "DO" makes it loop ten times, how do you change the number of times it loops
    edited 2004-10-06 16:58
    The comment after the 'DO' is not correct. The 'DO'/'LOOP' will be infinite.
    DO ' Do the loop 10 times
    RobotData = RobotForward ' Move forward
    GOSUB RobotSend
    PAUSE PauseTime ' Wait msecs between RobotSend commands
    LOOP ' Repeat Again
    It should have been:
    FOR sendCmd = 0 TO 9 ' Do the loop 10 times
    GOSUB RobotSend
    NEXT
    Don't forget to declare variable 'sendCmd'.
    edited 2004-10-08 14:15
    so what do i change to tell the program how many times to loop the forward command, thanks for the help by the way
    edited 2004-10-08 14:18
    do i change the "0 to 9" which makes it loop ten times, to lets say "0 to 15" to make it loop 16 times?
    edited 2004-10-08 17:17
    You are correct, "0 to 15" will make it loop 16 times
    My son has some of his TAB SUMOBOT code posted on our WEB page. Please have a look at it.
    edited 2004-10-11 21:51
    its not working correctly, when i send it to the bot it doesn't stop after the allotted number of loops it just goes on forever, it send the forward command forever
    edited 2004-10-12 00:19
    I think that the·attached file should be complete. I have not tested it. I hope it is useful.
    I encourage you to read through the·CD that came with the robot. It will take you through·several code writing execises.·The manual on the CD·is not as well written as the Parallax material but it is the only way for you to learn how your TAB SUMOBOT works.
    edited 2004-10-12 00:44
    Drewdawg-
    In case you weren't aware of it, there is a Yahoo Group which deals exclusively with the Tab Robot Kit. Here is a link to that Yahoo Group:
    http://groups.yahoo.com/group/tabrobotkit/
    Bruce Bates
    edited 2004-10-12 01:21
    i don't mean to bother u again, but i've read almost everything that comes on theat cd, and really doesn't have anything that relates to what i'm trying to do, and your latest isn't working, i've tried to tweak with it and i can't get it, and the yahoo groups is useless
    edited 2004-10-12 04:22
    If you would like to post your code, I will try using it on a TAB SUMOBOT that I have here.
    edited 2004-10-13 23:50
    ' Move forward
    ' { $STAMP BS2 }
    '|||||||||||||||||| Variables ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
    PauseTime VAR WORD ' Create a 16 Bit Variable
    CountMoves VAR NIB ' Create a 4 Bit Variable
    RobotData VAR BYTE ' Data Byte to Send to/Receive from Robot
    '||||||||||||||||||| Constants ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
    RobotStop CON 0 'Stop the Robot
    RobotForward CON 5 ' Move Forward for 200 msecs
    RobotReverse CON 6 ' Move Reverse for 200 msecs
    RobotLeft CON 7 ' Turn Left for 200 msecs
    RobotRight CON 8 ' Turn Right for 200 msecs
    RobotPWM0 CON 11 ' PWM = 0% Duty Cycle
    RobotPWM1 CON 12 ' PWM = 1st "Notch"
    RobotPWM2 CON 13 ' PWM = 2nd "Notch"
    RobotPWM3 CON 14 ' PWM = 3rd "Notch"
    RobotPWM4 CON 15 ' PWM = 100% Duty Cycle
    LED CON 11 ' LED, Negative Active On
    SC CON 14 ' Define the Serial communications Clock Pin
    SD CON 15 ' Define the Serial communications Data Pin
    '|||||||||||||||||||| Main Code |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
    debug "forward"
    HIGH SC ' Set the I/O Bits As O/P - Required by the 505
    HIGH SD ' and High - Required by the 505
    HIGH LED ' Turn off the LED
    PauseTime = 80 ' msecs between commands
    PAUSE 100 ' Time for the electronic circuits to startup
    RobotData = RobotPWM0 ' Set the speed to 0 of 4 since Behavior 1 will probably start.
    GOSUB RobotSend
    RobotData = RobotPWM4 ' Set the speed to 0 of 4 since Behavior 1 will probably start.
    GOSUB RobotSend
    FOR CountMoves = 0 TO 1 ' Do the loop # times
    GOSUB RobotSend
    RobotData = RobotStop ' Stop the Robot
    GOSUB RobotSend
    RobotSend: ' Send the Byte in "RobotData"
    LOW SC ' Hold Low for 1 msec before
    PAUSE 1 ' Shifting in Data
    SHIFTOUT SD, SC, LSBFIRST, [noparse][[/noparse]RobotData]
    HIGH SC
    return
    edited 2004-10-14 00:10
    Drewdawg -
    I didn't look through your coding all that thoroughly, but there is definitely a NEXT statment missing after your FOR statement. Additionally, I don't see anywhere that the variable CountMoves is incremented or decremented or even referenced anywhere in your coding except in tha FOR statement mentioned above. Lastly, you are probably going to drop right into the RobotSend coding. The RobotSend coding is a sub-routine, and it should only be accessed by a GOSUB statement.
    I'd clean up at least that much before you try toactually troubleshoot it any further.
    Bruce Bates
    edited 2004-10-14 01:17
    everything is functioning right except for the countmoves command, no matter what i set countmoves equal to, it just loops the forward command forever, i can't get it to work
  • Ken GraceyKen Gracey Posts: 7,415
    edited 2004-10-14 04:10
    Drewdawg,
    I'll invite the guys who designed the robot into this discussion.
    edited 2004-10-14 14:03
    I also found that the code would not stop the·robot.
    I modified·the code to·make·it·stop after the forward commands. I also tested it on my TAB SUMOBOT.·The·sub-routine had been a part of the main program logic. When the context came to the 'Return' statement it caused the program to start over again. I choose to use an endless loop before the subroutine but you could just as easily use a 'goto' to skip over it and have more code.
    The·code is attached.
    i finally got the code to work thanks to your help russ, i had to change a few things but i got it to work, thank you very much
