ot - insulation dispalcement connectors
In a message dated 7/11/2004 3:28:57 PM Eastern Daylight Time,
davemucha@j... writes:
> Is there a proper name for these ? my searches ma be failing because
> I don't know what to call them.
Dave, that's a ribbon header connector [noparse]:)[/noparse]
Sid
Sid
sorry for the off topic post.
I can't find wire connectors that one pushed the wire into and as the
wire is pushed, it strips some of the insulation and also makes a
connection.
the phone company uses something like this, but I'm looing for
something I can put on a PC board.
Dave
>connection.
We use two varieties: AMP MTA series and Panduit MASCON series. These are
both the style where one terminates the wires into the connector, then the
connector pushes onto the male pins soldered in the PCB.
I have seen Telco type 66 pins soldered into a PCB but I have no idea of
manufacturer or availability.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 20 years of Engineering Innovation (1984 - 2004)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Right.
Ribbon connectors consider themselves to be IDC connectors. But what
Dave needs are the type used by the TELCO trade, (or something like
it.). Try searching through the AMP division of Tyco electronics, or
the Leviton Voice & Data sites. And of course the good people at
Phoenix Contact.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
Original Message
> From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=esTFVtF3r9jMkD6mS6ftVjOA3KcnVNihNHORn2VPyzc56aLclojUcqHODA_AOhOUUimmUV0OEouW]Newzed@a...[/url
> Sent: Sunday, July 11, 2004 3:39 PM
> To: basicstamps@yahoogroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] ot - insulation dispalcement connectors
because
> Sid
<hansolofalcon@w...> wrote:
> Hello from Gregg C Levine
> Right.
> Phoenix Contact.
Right,
The things I am looking for would be solder mount on the PC board.
Leviton has something that looks possible, but does not offer specs.
I'm thinking there is something in the alarm industry where the most
secure thing is the source for parts and details of the units.
But, if you have used a network connector, the Cat-5 or whatever
cable is connected in such a manner.
Dave
0.100 and 0.156 spacing. See Mouser catalog #617
(Feb-Apr04), pages 715-720. There are tools for wire
insertion on page 717. I only do a few at a time so I got
the plastic T handle version.
Dick Ballard
ballardr@a...
>>connection.
>dwayne
