Rtc pcf8563
I am having some problems getting my phillips PCF8563 real time clock
to work with the basic stamp/
I am able to set the time and date correctly. The time works well,
but when the day switches over it seems to be switching the month
also.
I set the time for 23:59, and wait for the date to switch, it will
increment the month and the day and I can't figure out why, it will
go from directly from 7/2/04, to 8/3/04
It also allows the month to go higher then 12.
anyone have any luck trouble shooting a problem like this?
thanks
MikeDolan
MikeD@B...
also.
thanks
MikeDolan
MikeD@B...
MMDDYYYY as compared to DDMMYYYY
The changing of the month when the time changes is what has led me to ask
the question
Original Message
From: MikDolan54 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AGiibyeSzpj4I0bj_eFWuQw_NTWByhbEvKlMC41dyrzHkKHsbwdEg0uxZOmKhfFF8McXkjVxLv0q]MikeD@B...[/url
Sent: Monday, June 28, 2004 4:09 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] RTC PCF8563
also.
thanks
MikeDolan
MikeD@B...
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Yahoo! Groups Links
device; if I remember correctly the year value is actually an offset
from the last leap year (0 - 3, set in bits 6 and 7 of register 5). Are
you setting it correctly? Today, for example, would be coded as:
Reg $05 --> %00101000
--> %00 = 0 (2004 is leapyear)
--> 10 = 2 (tens digit of 28th)
--> 1000 = 8 (ones digit of 28th)
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: MikDolan54 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j8GRxadU8rnIETgYIJfUg6v5A8NIssicMdmifGzy9WM14m6eIiQ8wBvxhmBHuYeFr9FLhPX8RG8]MikeD@B...[/url
Sent: Monday, June 28, 2004 3:09 PM
also.
thanks
MikeDolan
MikeD@B...
thanks for the response...
I haven't solved the problem yet, but I checked a chip I was using
this morning and it is a PCF8583 while my data sheet is for the
PCF8563.
I will find the correct data sheet and go from there.
Mike Dolan
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Do you mean the PCF8583? The year/date register is a bit funky on
that
5). Are
> -- Jon Williams
> -- Dallas Office
Original Message
> From: MikDolan54 [noparse][[/noparse]mailto:MikeD@B...]
clock
> also.
will
will
> thanks
> MikeDolan
> MikeD@B...
I've looked things over and your were correct I was using the wrong
datasheet. Thanks for the help.
How do I keep track of the year with the PCF8583. It simply goes
from 0-3 and rolls over.
Do I have to keep track of how many times this year rolls over in a
EEPROM, and if so then I guess I have to keep this thing on all the
time. In other words if I were to not monitor it for a multiple
year span, how would I distinquish the year?
any insight would be appreciated...
thanks
mike
that
5). Are
> -- Jon Williams
> -- Dallas Office
Original Message
clock
> also.
will
will
> thanks
> MikeDolan
> MikeD@B...
something like the following to track the year.
Note that the PFC8593 does count yr=0 as a leap
year and yr=1,2 or 3 as non-leap yeas, for the 28
or 29 days in February. The code looks for
rollovers in the yearly and 4 year cycle, and
automatically updates two eeprom locations when
necessary the first time the code runs after a
rollover.
yr0 DATA Word 2004 ' base of 4 year cycle, updated once/ 4 years
yrx DATA Word 2004 ' 1 year cycle, updated once/ year.
GOSUB get_yr ' yr=0 to 3 from PFC8593
READ yr0, Word baseYear
READ yrx, Word nowYear
IF baseYear+yr < nowYear THEN ' yr has rolled over from 11 to 00
year=baseYear+4 ' new leap year cycle
WRITE yr0, Word year
WRITE yrx, Word year
ELSEIF basYear+yr > nowYear THEN
Year=nowYear+1
WRITE yrx, Word Year
ELSE
Year=nowYear
ENDIF
debug ? year
-- Tracy
>Since you are entering the year anyway, you just
>need to know its relationship vis-
