PBasic Wishlist Item
As long as we're on the subject, it would be
REALLY nice if the IF statement could include
IF condition THEN GOSUB xxxxxx
Would simplify a lot of code for me. Any chance
of getting this in the *next* version of PBasic??;-)
Tom Fisher
Dallas,TX
Tom Fisher
Dallas,TX
>Tom Fisher
>Dallas,TX
>IF NOT condition then branch_around
>GOSUB XXXXX
>Branch_around:
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
syntax.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: tboonefisher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kKehISGSDXeXJ5p1jnBaqkOYkaoQE9erL4LFB84jkqch-ls37INEAFQaHY32lTDMVLSmYkDmojCdz5wAyg]tboonefisher@s...[/url
Sent: Sunday, April 25, 2004 11:24 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] PBasic Wishlist Item
Tom Fisher
Dallas,TX
doesn't seem to do any convincing, let me PROVE it. Copy and paste this
demo into your BASIC Stamp editor:
' {$STAMP BS2}
' {$PBASIC 2.5}
cntr VAR Nib
Main:
DEBUG HOME, DEC2 cntr
IF (cntr.BIT0 = 1) THEN GOSUB Is_Odd
DEBUG CLREOL, CR
cntr = cntr + 1
PAUSE 500
GOTO Main
Is_Odd:
DEBUG " is odd"
RETURN
-- Jon Williams
-- Dallas Office
Original Message
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9i7BE679IdU5jlTTIwpdHldS7p_jV4ZwLEH7siro1d7hkRaBFFqHcwkhUIc8sOAtLhe-dq3Qcr-I7J4z]bvbates@u...[/url
Sent: Sunday, April 25, 2004 11:44 AM
Subject: Re: [noparse][[/noparse]basicstamps] PBasic Wishlist Item
>Tom Fisher
>Dallas,TX
>GOSUB XXXXX
>Branch_around:
> >Tom Fisher
> >Dallas,TX
Odd Bruce,
your post came up with the > marks like it was part of the origional.
I assume this is what you posted.
GOSUB XXXXX
Branch_around:
Is this your wish list item ?
Dave
> >Yahoo! Groups Links
>> >Tom Fisher
>> >Dallas,TX
>Odd Bruce,
>I got lazy and didn't break the original, as I've done again here :-)
>GOSUB XXXXX
>Branch_around:
No. it's one method to solve what you see as a deficiency. Jon claims there are
other methods too, but my HELP feature doesn't work, so I can't check it out.
I haven't used all that many features of PBASIC 2.5, but if Jon says it's there, I'm sure that it is.
Bruce
> GOSUB XXXXX
> Branch_around:
Yep, it is and is what I'm using BUT
IF condition GOSUB subrout
*looks* and reads much better!!<G>
Tom Fisher
Well knock me over!! It does work....HOWEVER it
isn't documented in Help.
Thanks, Jon!!
Tom Fisher
Dallas,TX
occasional bobbles (opens under main window after it's been opened and
closed in a given session) that we continue to investigate. In the very
worst case, you could certainly create a desktop shortcut to the help
file (I do this anyway, because I sometime want to look at the file
without having the editor open). If you've download the latest Beta,
the file you want is here:
C:\Program Files\Parallax Inc\Stamp Editor v2.1 Beta 1\PBASIC.chm
NOTE: You must have MS Explorer 4.0 or later installed in order to view
this file.
-- Jon Williams
-- Dallas Office
Original Message
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sIWq1nkrFLexfOTCdWR1bVksGafmjBtypuF1ucjS2-rxSSqvQC3Lt1HystpLx-rzEUNvnhIWWI9VVK8Ml0HjhEU]bvbates@u...[/url
Sent: Sunday, April 25, 2004 12:09 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: PBasic Wishlist Item
<snip>
there are other methods too, but my HELP feature doesn't work, so I
can't check it out. I haven't used all that many features of PBASIC 2.5,
Bruce
syntax explanation on the IF-THEN-ELSE page:
IF Condition THEN Statement(s) { ELSEIF Statement(s) } { ELSE
Statement(s) }
Since "GOSUB Some_Label" is a valid program statement (that is, it can
stand alone), I maintain that it IS documented.
Now, before somebody gets angry with me, the reason we didn't (perhaps)
specifically document
IF (condition) THEN GOSUB Label
is that PBASIC has about 60 valid instructions that could follow THEN in
that line of cde. Like this:
IF (randValue.BIT0 = 1) THEN oddCount = oddCount + 1
You see, it works the same way and fits within the syntax definition
provided in the help file. I hope this helps.
-- Jon Williams
-- Dallas Office
Original Message
From: tboonefisher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rugKK3R_Csz6jwzlepShUxjCsnx1WLU6vovlZvP7I26wNn_b53tSuBh8V5M6gqy0oUeq6-6y-MRLK_NYx7_Plg0]tboonefisher@s...[/url
Sent: Sunday, April 25, 2004 1:13 PM
> Really, gang, it's much easier than that -- and since telling the
> group doesn't seem to do any convincing, let me PROVE it. Copy and
> paste this demo into your BASIC Stamp editor:
Thanks, Jon!!
Tom Fisher
Dallas,TX
>Your help feature doesn't work at all? Not heard that -- just
Last week it locked up my entire computer and I had to re=-boot as I mentioned
to you last week. I had thought that was an initial use only problem, but that seems not to be the case, Now the HELP program, when invoked from the PBASIC Editor, locks up all by itself. That alone can be cancelled (CTL-ALT-DEL --> End Task) and operation can continue.
>In the very worst case, you could certainly create a desktop shortcut to the help file (I do this anyway, because I sometime want to look at the file
That seems to work fine as a circumvention.
>this file.
>No problem there, I'm using MSE 6.02.8 . Thanks for the tip.
>-- Jon Williams
>-- Dallas Office
Bruce
to our Engineering staff. When you do send a problem report, be sure to
include anything that may help:
* processor type and speed
* RAM
* operating system and version
* detail description of problem, and steps that can repeat it
-- Jon Williams
-- Dallas Office
Original Message
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lQp7HtoC7yxS3ewVeJJcMa9Ac9pxIAZ25zvpJt6y5G_iTIUWQ2YwA1mKIGqexsR4kqbRWf0IRE5dmiyT]bvbates@u...[/url
Sent: Sunday, April 25, 2004 1:52 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: PBasic Wishlist Item
mentioned
>the file without having the editor open). If you've download the
>latest Beta, the file you want is here:
>this file. No problem there, I'm using MSE 6.02.8 . Thanks for the tip.
>-- Jon Williams
>-- Dallas Office
Bruce
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
>Thanks, Jon!!
>Tom Fisher
>Dallas,TX
Hi Tom,
Are you sure you have the latest help file? I can't check right now,
but I'm pretty sure that the help file is the most up to date source
of info about PBASIC.
You should also be aware--PBASIC 2.5 has a lot more features you
might like to take advantage of. For example, it used to be only
IF conditions THEN label
In PBASIC 2.5 you can now also do:
IF conditions THEN statements ELSE statements
IF conditions THEN
statements
ELSEIF
statements
ELSEIF
statements
ELSE
statements
ENDIF
IF conditions THEN GOSUB xxx
ON index GOSUB xxx,yyy,zzz
and many more. The magic happens in the complier (STAMPW.EXE v. 2.0
beta 1, which implements PBASIC 2.5). It works on all BASIC Stamps,
old and new.
I have my own little write-up on it, how the compiler translates the
new PBASIC 2.5 back to the old PBASIC. The compiler hides all the
messy details from the programmer.
<http://www.emesystems.com/BS2pbasic25.htm>
-- Tracy
BUT *not* under IF-THEN:
"IF Condition THEN Address"
Looks like I found an omission...
Do I get a *free* Stamp for this??<VBG>
Tom Fisher
Dallas,TX
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, April 25, 2004 1:48 PM
Subject: RE: [noparse][[/noparse]basicstamps] PBasic Wishlist Item
> Which help file are you reading? In the latest, you will find this
> Statement(s) }
> -- Jon Williams
> -- Dallas Office
Original Message
> From: tboonefisher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AUROX3STbtKGE-AxI8ItRgnl3kbMAr5MNKDkWnt4ZOVU6jDWBUNsEvBsCGEVO4IcDz7EfHS2ZJxPiIO81ZGVhIc2]tboonefisher@s...[/url
> Thanks, Jon!!
> Tom Fisher
> Dallas,TX
> Yahoo! Groups Links
<grin> And you get to pay my overtime for answering questions on a
Sunday ... oh, shoot, I'm on salary and don't get overtime pay....
All kidding aside, notice that IF-THEN works with any version of PBASIC,
while IF-THEN-ELSE only works with the BS2 family and when PBASIC 2.5 is
declared.
-- Jon Williams
-- Dallas Office
Original Message
From: tboonefisher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zi_A9dIFZWIuawTM97_II0QHeZe69JHhDqaNS4t903PXkuqMwRzBWZkbMCeSt-um_VY99xbUd9uutJvHRQ6i]tboonefisher@s...[/url
Sent: Sunday, April 25, 2004 2:06 PM
It *is* documented under IF-THEN-ELSE
Tom Fisher
Dallas,TX
Original Message
> Statement(s) }
> (perhaps) specifically document
> in that line of cde. Like this:
> -- Jon Williams
> -- Dallas Office
Original Message
> Thanks, Jon!!
> Tom Fisher
> Dallas,TX
> and
> Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
> declared.
Thanks.....methinks you are 'tap dancing' a bit and I bet a cup 'o
StarBucks
there's a clarification in the next help version!!<VBSEG> Anywho.....my code
looks much better now with your help!!
Tom Fisher
Dallas,TX
on a Sunday, ANYWAY? Don't you EVER have time
off?
Seriously, all of us would like to thank you
for your timely support. It is above and
beyond normal service.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> No, you get a smack-on-the-head for not actually reading the Help
file!
PBASIC,
2.5 is
> declared.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: tboonefisher [noparse][[/noparse]mailto:tboonefisher@s...]
> Tom Fisher
> Dallas,TX
Original Message
> From: "Jon Williams" <jwilliams@p...>
this
> > Statement(s) }
it can
THEN
definition
> > -- Jon Williams
> > -- Dallas Office
Original Message
the
and
> > Thanks, Jon!!
> > Tom Fisher
> > Dallas,TX
Subject
> > and
> > Yahoo! Groups Links
Subject
> Yahoo! Groups Links
> abuse@p...
> Tom Fisher
> Dallas,TX
Yeah, is that a 37cent USA Flag stamp or the 37 cent Elvis Stamp ?
Dave
identical to):
cntr VAR Nib
Main:
IF (cntr.BIT0) = 1 THEN xxx
GOTO yyy
xxx:
GOSUB Is_Odd
yyy:
DEBUG CLREOL, CR
cntr = cntr + 1
PAUSE 500
GOTO Main
Is_Odd:
DEBUG " is odd"
RETURN
It works fine, but in this instance it shows how code space may not
be artfully optimized by the new editor. Thankfully, thought and
creativity are still in play in Stamp programming :-).
Steve
> ' {$STAMP BS2}
> ' {$PBASIC 2.5}
> cntr VAR Nib
> Main:
> DEBUG CLREOL, CR
> cntr = cntr + 1
> PAUSE 500
> GOTO Main
> Is_Odd:
> DEBUG " is odd"
> RETURN
> -- Jon Williams
Even if there was, I've been working with BASIC Stamp users for over 10
years now (long before I was an employee), and helping others solve
technical problems with BASIC Stamps is fun for me. And thank you for
you kind note.
-- Jon Williams
-- Dallas Office
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=90TCi64XVMNGlNM1NmL8bPswMIxr1p2-j3evRPf_6XyTcdyj2HgklHcc7fY4s8X7ZaypUuG4MpWxmhQ4uNgWQIjoUhA]allan.lane@h...[/url
Sent: Sunday, April 25, 2004 2:41 PM
Subject: [noparse][[/noparse]basicstamps] Re: PBasic Wishlist Item
Yeah, what ARE you doing answering questions
off?
I agree. Thank you for your efforts. And that's my arrangement for
running an office, as well.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
Original Message
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6rjWx6klS_afIMaLCvnRQvI23_i4w_iLyH-JRWwG98KPdcTdaMReX_Imo5cHhAM7U7EXWa_AjqRE84UET_FWOwU]jwilliams@p...[/url
> Sent: Monday, April 26, 2004 8:50 AM
> Well, my office is at home, so there is no clock to punch in and
out.
10
for
> you kind note.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lNL1Hk_haSuULqWkoAzXkVNEhMC7jFpDOBKDCYj8RgYiAUkZHbYs8JWeKdLbsKjrQ3uqen1iFSGUDaXL4eyG4dAP2fE]allan.lane@h...[/url
> off?
question, I need to look at the problem from a different angle and
often I realize something I didn't know. Seems their questions help
me learn as well.
But, I think most of us do appreciate your seeminly endless high
quality support Jon. Very Well Done !
Dave
--- In basicstamps@yahoogroups.com, "Gregg C Levine"
<hansolofalcon@w...> wrote:
> Hello (again) from Gregg C Levine
Original Message
> > From: Jon Williams [noparse][[/noparse]mailto:jwilliams@p...]
> out.
over
> 10
solve
you
> for
> > you kind note.
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
> > off?
