Newbie question - sequencing outputs
Hi all,
I am new to basic stamps and have an application I would like to get
running.
I have a signal source that generates a square wave of up to 14
pulses 50ms apart at it's fastest. Pulse duration is ~ 1ms active LOW.
What I am trying to do is have this pulsed input on PIN 0 of the
stamp, and for each pulse of the input generate a LOW out on
sequential pins.
For instance, an input of 6 pulses would generate:
LOW 1
LOW 2
LOW 3
LOW 4
LOW 5
LOW 6
I will never know how many pulses I will be receiving but it will
never be more than 14 at a time. I then need the stamp to reset
automatically so the next series of pulses will start back at
generating the same LOW out sequence.
Any suggestions? I have been looking into PulsIN and Pulsout
statements...
Don
running.
sequential pins.
LOW 1
LOW 2
LOW 3
LOW 4
LOW 5
LOW 6
statements...
Don
For starters, I'd try a PULSIN to simply detect pulses (as opposed to
timing them), using the timeout condition to determine when the end
of the pulse stream has occurred. First non-zero value indicates new
series has begun.
At initialization set DIRS to $FFFE. Following each sequence of
pulses, set OUTS to $FFFE. When each pulse within sequence arrives,
OUTS = OUTS << 1 + 1 will cause P1 through P15 to go successively
and individually low.
Steve
On 11 Mar 04 at 17:56, donaldscott_18 wrote:
> ...I have a signal source that generates a square wave of up to 14
> LOW.
> sequential pins.
> LOW 1
> LOW 2
> LOW 3
> LOW 4
> LOW 5
> LOW 6...
If you don't care how long the input pulse is low,
then you can use PULSIN to find out how long the
time between pulses is -- up to 131 mSec, anyway.
If you want the best characterizations of the pulses,
you can also use RCTIME. RCTIME MyPin, 0, MyValue
will measure how long it takes for MyPin to leave
the '0' state. RCTIME MyPin, 1, MyValue will
measure the time it takes to leave the '1' state.
By the way, a 'Square' wave typically does not
have 'LOW Pulses' -- if it has pulses, it's not
'square', which implies equal time high and low.
You'll have to know something about your signal to
know when it's safe for the BS2 to assume the
signal is over. What you are doing sounds like
reading IR Remote data. Typically there is some
max delay between repetitions of pulses there --
when you see that delay, you assume one 'message'
is done. You then wait for the next 'descent'
of the input line to start another pulse capture.
I 'wait' by:
Waiting:
IF IN1 = 1 THEN Waiting
' Now, when here, first pulse just dropped...
--- In basicstamps@yahoogroups.com, "donaldscott_18"
<donaldscott_18@y...> wrote:
> Hi all,
get
> running.
LOW.
> sequential pins.
> LOW 1
> LOW 2
> LOW 3
> LOW 4
> LOW 5
> LOW 6
> statements...
> Thanks
> Don
For reference, here is my application:
I have a high speed camera that is able to burst images at a rate of 20 images
per second. So an image capture happens at maximum speed of every 50ms.
Becuase this camera is so fast, I need to trigger a bank of strobes so that a
different strobe fires for each picture taken, up to a maximum of 14 pictures.
The strobe trigger is an active low, that remains low for approximately 1 - 2
ms, so no, this is not a square wave, but an active low pulse chain, each low
going pulse can happen as fast as 50ms, or sometimes as slow as every 150ms -
depends on what is being photographed.
The photographic sequence can take place every 20 seconds or longer, hence the
need to reset the whole thing.
I currently have two stamps,Stamp1 is acting as the camera and Stamp2 is acting
as the strobe controller being triggered by stamp1.
Don
Allan Lane <allan.lane@h...> wrote:
There are a couple of approaches.
I 'wait' by:
Waiting:
wrote:
> Hi all,
get
> running.
LOW.
> sequential pins.
> LOW 1
> LOW 2
> LOW 3
> LOW 4
> LOW 5
> LOW 6
> statements...
> Thanks
> Don
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Search - Find what you’re looking for faster.
the 'pulse' line to go low. As soon as it does,
the BS2 should 'trigger' the next strobe flash
in its sequence.
The time between the 'pulse' line dropping is
very variable -- 50 mSec to 150 mSec.
If the 'pulse' line hasn't dropped in 150 mSec,
then that sequence is over -- something must
now be done to insure the 'recharging' strobes
aren't used until they're ready.
So:
FirstStrobe CON 1 ' First pin to use for Strobe flash
LastStrobe CON 14 ' Last pin to use for Strobe Flash
OldStrobe VAR BYTE ' 0..14 -- Allows longer 'Strobe' pulse
StrobeNum VAR BYTE ' 0..14
MAIN:
OldStrobe = FirstStrobe
StrobeNum = FirstStrobe
WaitFlash:
IF IN0 = 1 THEN WaitFlash ' Wait for drop
' Okay, if here we've seen drop...
LOW StrobeNum ' Pulse to trigger strobe
StrobeNum = StrobeNum + 1
HIGH OldStrobe ' Release strobe.
IF StrobeNum <= LastStrobe THEN Continue1
'ELSE
Continue1:
OldStrobe = StrobeNum
WaitRise:
IF IN1 = 0 THEN WaitRise ' Wait for line to go high
GOTO WaitFlash
' What you still need is some way to detect
' the > 150 mSec 'space' between IN0 drops.
' You can do that with a counter, with some
' experimentation.
' Try #2:
MaxDelay CON 65530 ' Or something. Experiment...
TimeCount VAR WORD
TimeCount = 0
WaitFlash:
IF IN0 = 0 THEN StrobeIt
TimeCount = TimeCount + 1
IF TimeCount > MaxDelay THEN ...
'THEN goto someplace to wait for the
' next sequence to begin again...
StrobeIt:
TimeCount = 0 ' Reset timecount for next delay
' HERE, do 'flash' stuff from above...
--- In basicstamps@yahoogroups.com, Chapman Donald
> Thanks all for the fast replies.
of 20 images per second. So an image capture happens at maximum
so that a different strobe fires for each picture taken, up to a
approximately 1 - 2 ms, so no, this is not a square wave, but an
active low pulse chain, each low going pulse can happen as fast as
50ms, or sometimes as slow as every 150ms - depends on what is being
photographed.
longer, hence the need to reset the whole thing.
Stamp2 is acting as the strobe controller being triggered by stamp1.
> Regards,
> Don
> I 'wait' by:
> Waiting:
> wrote:
> > Hi all,
> get
> > running.
> LOW.
> > sequential pins.
> > LOW 1
> > LOW 2
> > LOW 3
> > LOW 4
> > LOW 5
> > LOW 6
> > statements...
> > Thanks
> > Don
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> Do you Yahoo!?
> Yahoo! Search - Find what you're looking for faster.
