Serial Communication Question
Hi All,
Is it possible to use a BASIC stamp to receive serial data in the
form of 4800, 8, N, 1 and convert and send it to another device in
the form of 4800, 8, N, 2?
I was reading the manual and I don't think it can be done with the
STAMP, but I have been wrong before. Anyone have any thoughts on
this or know of another way to do it?
Jeff
Jeff
A BS2* can receive at 4800,8,n,1. Because a stop bit and an idle
line share the same line level, all you need do to transmit at
4800,n,8,2 is wait about 0.208 msec before sending the next byte.
If you're using a BS2, the interpreter will probably use up at least
that much time setting up the SEROUT, if you SEROUT a byte at a time.
What you can't do is accept a continuous 4800 baud stream, reformat
it and send it back out continuously, because your Stamp can't SERIN
and SEROUT at the same time, plus it would fall behind anyway since
transmitting 11 bits would take longer than 10. But you can SERIN
several bytes into variable storage space and then SEROUT them one at
a time with two stop bits.
Steve
Here is the scenario. My repeater controller can only send 8, N, 1
and my FT-1000D radio which I want to give the remote control
commands can only receive 8, N, 2.
I am not very good with bits and bytes, but maybe you hit on
something.
The remote control command sent to the radio consists of a 5 byte
command from the controller. From what I read in the radio manual,
each byte consists of a start bit, 8 data bits (bit 0 - bit 7) and 1
stop bit. Everything is good except the radio needs 2 stp bits.
I think I understand your reply in that I could read in the serial
data at 4800, 8, N, 1 and send it back out at 4800, N, 1 and add
another bit to simulate 2 stop bits. Am I correct?
If so, any help or suggestions you have for programming to do this
would be appreciated as I have not used a STAMP before.
Jeff
--- In basicstamps@yahoogroups.com, "S Parkis" <parkiss@e...> wrote:
> Jeff-
least
time.
SERIN
since
at
> Regards,
> Steve
The Stamp program would be very simple. If I understand the concept
correctly:
repeat forever
wait for five input bytes (4800,n,8,1)
send first byte (4800,n,8,2)
send second byte (4800,n,8,2)
send third byte (4800,n,8,2)
send fourth byte (4800,n,8,2)
send fifth byte (4800,n,8,2)
In PBASIC for your Stamp, that would be something like:
i VAR NIB
cmd_bytes VAR BYTE(5)
again:
SERIN 0,baud,[noparse][[/noparse] STR cmd_bytes\5 ]
FOR i = 0 TO 4
SEROUT 1,baud,[noparse][[/noparse] STR cmd_bytes( i )]
NEXT
GOTO again
Seems like nothing is ever as simple as it looks at first, but I
don't think there'd be a whole lot more to it than this. This
assumes the repeater controller works through I/O pin 0, and your
radio is connected via I/O pin 1. The processing overhead
associated with the FOR-NEXT loop and the SEROUT within it should
provide ample idle time for a perceived second stop bit.
Assuming the controller doesn't spew one 5-byte string on the heels
of another (probably need ~5 msec break minimum), this should take
care of the timing. Signal polarity and logic levels must also be
considered in the choice of the value for "baud" above and may also
require some level-shifting hardware external to the Stamp (see the
Stamp manual for the gory details).
Steve
Assuming your PC's program can insert a non-ASCII numeric value prior
to the command sequence:
SERIN pin,baud,[noparse][[/noparse]length, STR command\length]
Or, if ASCII numeric would be much easier:
Your PC would figure out how many command bytes it's about to send,
then send that value in a byte followed by the real stuff. If high
baud rate being used, this may not fly.
Steve
On 9 Mar 04 at 17:10, skogsvargen wrote:
> Can anyone give me any ideas on how to implement a protocol that
> allows me to receive commands with a size (4-8 bytes) unknown by
> the Stamp...
Better make that:
SERIN pin,baud,[noparse][[/noparse]DEC1 length, STR command\length]
I am currently trying to implement a protocol to transmit commands
between my PC and my BS2e. The link is a small radio modem. I run
into problems when i need to send commands of varying length to the
Stamp. Can anyone give me any ideas on how to implement a protocol
that allows me to receive commands with a size (4-8 bytes) unknown
by the Stamp. The alternative is to use a fixed length message from
the PC, but this seems lik an innefficient way to solve things...
Any ideas?
/Magnus, Stockholm, Sweden
SERIN MyPin, MyBaud, [noparse][[/noparse]STR MyData\8\0]
' The above says, recieve 8 bytes, or to first 0,
' whichever comes first. Thus, you can use some
' specific value to end your messages at 4 bytes.
--- In basicstamps@yahoogroups.com, "skogsvargen" <skogsvargen@h...>
wrote:
> Hi,
> Any ideas?
character. You'll have to modify the PC end so that your termination
character is appended to each packet. Your Stamp will need to have an
array defined to capture your maximum data length.
ETX CON 3
buffer VAR Byte(8)
SERIN Rx, Baud, [noparse][[/noparse]STR buffer\8\ETX]
Read up on the details in the Help file or manual (see SERIN).
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: skogsvargen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UXB05S9-r4kEaK0L-2L5tbk3tjcgU_9zRFalZXoLpRCA7KqtVQrGhEWwT9HGkizAynhkdh35NJGz4i1QNVf4F8M]skogsvargen@h...[/url
Sent: Tuesday, March 09, 2004 11:10 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Serial communication question
Hi,
Any ideas?
First, if you are transmitting only 7-bit ASCII data, set the
high-order bit of the last command byte. The Stamp can use this extra
bit to detect end-of-command.
Second, let the first byte indicate how many bytes follow, but as an
ASCII letter. That is, if four bytes of command follow, send a "D".
This first letter can be converted to a numeric value by anding it
with 0x0F, which will give you up to 15 bytes.
Russ
wrote:
> Hi,
> Any ideas?
