Motor movment / as effect of sensors...
... Yes I am new..
Anyone know where I can learn about
causing a servo motor to move as an effect of a photoresistor /sensor?
I know how to cause motion in the survo using pulseout command.
What I want to do is track the sun.
I imagine the code would be a "loop"
DO
check sensor to see if value of pho-tonic energy is
= or grater than a stored "pho-tonic" number in memory.
then add 0002 to last stored pulsout command stored in memory.
how can I do this?
Learn to this?
Maybe educational cirriculum?
Dave
DO
how can I do this?
Learn to this?
Dave
the Stamp to measure light. Put the CdS cell
inside a tube (or a dome with a slot cut in
it), so it only gets light when
it's pointing at the sun. See the
Analog and Digital class for circuit.
2. Put the dome on the servo, so it can be
swung by the Stamp. Swing the dome so the
light falling on the CdS cell is maximized.
You already know how to do #2 above.
--- In basicstamps@yahoogroups.com, "crazyidagain"
<crazyidagain@y...> wrote:
> ... Yes I am new..
> DO
> how can I do this?
> Learn to this?
> Thanks
> Dave
