Serial connection
I have several questions about serial connection of a device and a
basic stamp through a the 9 pin.
I have a police scanner that can communicate through a serial port at
9600 baud (ajustable) and at 8 data bits.
The one thing I don't know is this whole ttl thing. What is it and
what does it have to do with the stamp/radio.
I do have all of the command protocals for the radio.
Any help would be appreaciated
Duncan Fairley
Djdunkman@h...
Duncan Fairley
Djdunkman@h...
driver and reciever built in, so it can be directly connected to
another 232 device, and communicate with it using SEROUT/SERIN.
All of its other data pins CAN be used for SEROUT/SERIN, BUT they
don't have 232 drivers on them, so they will talk/listen at TTL
levels.
That 'TTL Levels' phrase means a logic '0' is 0 volts, and a
logic '1' is 5 volts. These are used instead of the +/- 12 volt (or
+/- 5 volt) signals used for 232.
--- In basicstamps@yahoogroups.com, "Duncan Fairley" <Djdunkman@h...>
at
> Duncan Fairley
> Djdunkman@h...
I have done some small work with a BS1, and now trying to send or
recieve data through a serial connection to a pc. I have made a
cable as described in the stamp manual, but to no avil, I cannot send
or receive data from the stamp. I don't know if it has something to
do with my port on my computer or something else. The book makes it
sound simple but maybe I'm still missing something. So if anyone can
give me some idea's on what to try or tell me what it is that I'm
missing that would be great as its driving me crazy to what is the
problem.
> Please help,
send
to
it
can
> problem.
> Thanks,
Hi,
Most of my work has been with BS2 and BS2sx, but I think I
can give you a few things to try.
First, make sure the PC serial port is working. Jumper pin 2 to
pin 3 on the computer serial port. Open up a communication software
program like hyperterm or procomm. When you type on the keyboard, you
should see characters on the screen. Remove the jumper, and the
display should behave differently when you type( ie, either no
characters or only a single character per key). The important thing
right here is that the screen behaves differently with and without
the jumper between pin 2 - 3. If connecting-disconnecting the jumper
gives a different response, then port is OK. If changing the jumper
doesn't help, also jumper pins 7 - 8 and check again.
Second, set your stamp in a loop putting out some short string
like "hello". Connect the stamp 0 volt to pin 5 on the PC. Set the
stamp baud rate to some low speed like 2400, 8, N, 1. Start up the
PC communication software ( hyperterm or procomm ) and set it for the
same speed and other parameters as the stamp. Run a single wire from
the stamp output pin to pin 3 on the PC. While the stamp runs, you
should see "hello" on the screen. If you see some unrecognizable
series of 5 characters, go back to the stamp and select 'true'
communication parameter, and check again.
Once you get the transmit part to work, you can then put your
stamp in a loop to watch for a character from the PC and do something
like blink an LED to let you know things are happening. Obviously,
the PC transmits on the other pin (2)and the stamp expects to see the
data come in a designated pin.
If it looks like the PC port is not working, go into the start-up
configuration and make sure the serial port is enabled.
Despite the aggravation of getting serial to work the first
time, it is one of the most valuable features of the stamp families.
Don't give up!
I hope this is easily related to the BS1!
Cheers,
Tom Sisk
