Still a Newbie, 1-wire devices
I'm the happy owner of a BS2p and 4off DS18S20 and having everything
working. Now that's on the board. Trying to extend cables to about
10 meters, problems starts. I'm using 4,7 k pull-up. Cables are 0.14
mm2 copper, 3 wire shielded.
Any idea what cables to use or other advice.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, February 18, 2004 3:31 PM
Subject: [noparse][[/noparse]basicstamps] Still a Newbie, 1-wire devices
> Thanks
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
ls@l... writes:
If it were me I'd go RF or IR over that distance. Notwithstanding, you might
try a .1uf at each end of the data cable. Even with shielding your going to
pick up some AC. Also, DO NOT ground the remote end of the shield.
Sid Weaver.
