OT: Looking for Small Linier Actuators, for stamp project
I am looking for 3 to 6 inch throw Linier actuators. I used to buy them from a
company called ORA but the havn't sold them in years. These are not high
precision are more plastic than metal. Run off 6 or 12 VDC. is early 90s cost
about $12.00 each
Any help would be great.
Tom
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing
about $12.00 each
Tom
Do you Yahoo!?
I need something similar. Please let me know if you turn something up.
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, February 15, 2004 8:48 PM
Subject: [noparse][[/noparse]basicstamps] OT: Looking for Small Linier Actuators, for stamp
project
from a company called ORA but the havn't sold them in years. These are not
high precision are more plastic than metal. Run off 6 or 12 VDC. is early
90s cost about $12.00 each
> Tom
> Do you Yahoo!?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
At 6:49 AM -0800 2/16/04, Jonathan Peakall wrote:
>Tom,
>Jonathan
>www.madlabs.info
Original Message
>From: "Thomas Grenga" <tip32a@y...>
>project
>> Tom
>> Do you Yahoo!?
>> Yahoo! Groups Links
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
Chuck Britton Education is what is left when
britton@n... you have forgotten everything
North Carolina School of Science & Math you learned in school.
(919) 416-2762 Albert Einstein, 1936
1.5" inches. This unit looks like the arm to move a satellite dish. but is
much smaller.
Thanks for the try...
Original Message
To: "Jonathan Peakall" <jpeakall@p...>; <basicstamps@yahoogroups.com>
Sent: Monday, February 16, 2004 11:19 AM
Subject: Re: [noparse][[/noparse]basicstamps] OT: Looking for Small Linier Actuators, for stamp
project
> CD player's laser head positioner?????
> >Tom,
> >Jonathan
> >www.madlabs.info
Original Message
> >project
them
not
early
> >> Tom
> >> Do you Yahoo!?
and
> >> Yahoo! Groups Links
> >Yahoo! Groups Links
> Yahoo! Groups Links
a matching nut, and a dc motor. Attach the all thread to the motor shaft,
attach what you want to move to the nut, and rotate the motor one way to
move out and the other to move back.
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: Tom G [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DtShlsT9QfUcv7wYHKqU6_j7sz-e4akR3St5vKMYFLEaRlz0lR1w5gxCdIfWXasmDKXIDYktyxzaGp2ro7V6e715]basicstampgroup@a...[/url
Sent: Monday, February 16, 2004 11:43 AM
To: basicstamps@yahoogroups.com
stamp project
No and if my ruler serves me correctly the throw on a Cd player is about
much smaller.
Original Message
project
> >Tom,
> >Jonathan
> >www.madlabs.info
Original Message
> >project
them
not
early
> >> Tom
> >> Do you Yahoo!?
and
> >> Yahoo! Groups Links
> >Yahoo! Groups Links
> Yahoo! Groups Links
Yahoo! Groups Links
First how do you determin the position. The unit I am speaking of has a
gearset to control the position of a potentiometer.
Speaking of gears. Typical units are gear reduced to increase torque..
Original Message
Sent: Monday, February 16, 2004 1:03 PM
Subject: RE: [noparse][[/noparse]basicstamps] OT: Looking for Small Linier Actuators, for stamp
project
> you can make a linear actuator very easily by using a piece of 'all
thread',
> jim
Original Message
> From: Tom G [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WRkDiqPH5Q4Lv-QIS2MHQ8MU0ax1L6ct8yh6ElAWGbW72VsXdZ8XQCNMqCitazFSyfuso3Ju60dvn6y37ry9OZOmM94J]basicstampgroup@a...[/url
> stamp project
is
> much smaller.
Original Message
> From: "Chuck Britton" <britton@a...>
stamp
> project
> > >Tom,
> > >Jonathan
> > >www.madlabs.info
Original Message
stamp
> > >project
> them
> not
> early
> > >> Tom
> > >> Do you Yahoo!?
Subject
> and
> > >> Yahoo! Groups Links
> > >Yahoo! Groups Links
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
> Yahoo! Groups Links
instead lends itself to linear movement to fixed positions. Just put a
flag on the mechanism that interrupts an optical sensor(s) and you will know
when you are at that position(s). Small dc gearmotors are available for
good prices from James Electronics http://www.jameco.com or DigiKey
http://www.digikey.com . There is an inherent gear reduction in the screw
mechanism itself as well. If you want finer positioning, you can couple the
motor shaft to an encoder and read out position or to a slide potentiometer
(such as used on audio mixer boards). For some low cost linear
positioners, raid the local junk yard. Most cars with adjustable seats have
a couple and you may be able to get them for a couple of dollars each. Most
of these don't have any position feedback but you could add that in the
above detailed ways. Many have limit switches attached or built in. Also,
consider using a toothed belt and pulleys or sprocket and chain driven by a
dc gearmotor. The straight stretch of belt or chain moves in a linear
manner (each side in opposite directions simultaneously) and something
attached to it will also, and the teeth or links can be counted to determine
position. I design custom industrial controls and electro mechanical
devices so always consider different approaches to these kinds of things.
I'm from the old school of hotrodding so I was around when you had to design
and build everything, not buy it off a shelf somewhere, so I tend to 'think
out of the box'.
have fun,
jim
Original Message
From: Tom G [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WK4ROQGh06_siNbI6k8L3YTAxK7OWhyFUSPz7h91FK3Wg1WGsAxSPdDycUDNQDU697JZKW7lVzjHZuOyny7RIU5S2bytFG4]basicstampgroup@a...[/url
Sent: Tuesday, February 17, 2004 8:21 PM
stamp project
Jim you make it sound so simple but you leave a bunch out.
Original Message
project
thread',
> jim
Original Message
> stamp project
is
> much smaller.
Original Message
stamp
> project
> > >Tom,
> > >Jonathan
> > >www.madlabs.info
Original Message
stamp
> > >project
> them
> not
> early
> > >> Tom
> > >> Do you Yahoo!?
Subject
> and
> > >> Yahoo! Groups Links
> > >Yahoo! Groups Links
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
> Yahoo! Groups Links
Yahoo! Groups Links
