video tracking with the stamp
Hey group,
This is two part question.
Firstly, is it possible to real-time video track using the basicStamp and
a video cam(like the one from parallax), and would it be possible to not only
use it to detect presence or movement etc. but to head track and even more
precisely to track the direction a head is looking or even an eye?
The second is part, would be just for any help to direct me to some starting
point and/or info for hardware and programming advice or ideas to be able to
track an eye's direction of interest(or head to start out with)
All input is extremely appreciated and needed.
Thanks in advance,
jeff
Thanks in advance,
jeff
where the main presentation was from a gentlemen who makes very lifelike
human head robots. His robots do facial tracking, but all the
processing is done in a PC from a USB-fed camera.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: jeff alten [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kqGhNRLXfgNMif5iWrA2a8l_yt3eYM8WXrBqpsVJg2WJqWvBaol0T5L4CZ7SxwAdZZmDU5rO2od0mGR4fOaiRA]jeffalten@h...[/url
Sent: Saturday, February 14, 2004 1:43 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] video tracking with the stamp
Hey group,
basicStamp and a video cam(like the one from parallax), and would it be
possible to not only use it to detect presence or movement etc. but to
head track and even more precisely to track the direction a head is
starting point and/or info for hardware and programming advice or ideas
to be able to track an eye's direction of interest(or head to start out
with)
Thanks in advance,
jeff
Thanks for the info, and speedy reply.
jeff
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, February 14, 2004 3:51 PM
Subject: RE: [noparse][[/noparse]basicstamps] video tracking with the stamp
> No, I don't think so. I just attended a DPRG (www.dprg.org) meeting
> -- Jon Williams
> -- Dallas Office
Original Message
> From: jeff alten [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=URR2GsAI0jKpw_6FbqZhDNJNVn88uMluTGAHAHdxCbnO623UoHzr98GnDBnimvoJqy-My1oi2a-J24Iaja_ZIg]jeffalten@h...[/url
> Hey group,
> with)
> Thanks in advance,
> jeff
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
I have been working with face tracking for two years now. This is how
much I could tell you in brief.
Basically there are three stages in face/head tracking:
1. The sensors. This could be anything from infra red reflective
paint to orientation sensors. Check out Intersense at www.isense.com.
Their products come with SDKs.
2. The interface to PC. This could be the Basic Stamp with an RS232
out or Ethernet out
3. A software on PC for 3D application or just data logging to
convert to a motion capture file format for other applications. I use
a software called Famous3D. Their website is at www.famous3d.com. It
has an SDK for you to develop your own software interface to their
product.
The next question is do you want real time processing or not. Real
time use low resolution video. The camera has to be head mounted for
stability. I have designed one with infra red LEDs and small CCD
camera. If you want detail capturing of facial movement, a high
resolution video is needed. You may need a separate capturing
hardware for that. Real time may not be possible. I used Matrox
Meteor card for capturing.
For all that been said Basic Stamp just don't have enough processing
power to do all that but perhaps part of it. May be the task can be
broken down to several Basic Stamps.
If you want to interface it to a PC, a good knowledge of DirectX will
makes things much easier.
- Johari Aziz
--- In basicstamps@yahoogroups.com, "jeff alten" <jeffalten@h...>
wrote:
> Jon,
> jeff
Original Message
> From: "Jon Williams" <jwilliams@p...>
meeting
lifelike
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > From: jeff alten [noparse][[/noparse]mailto:jeffalten@h...]
> > Hey group,
it be
but to
is
to some
ideas
start out
> > with)
> > Thanks in advance,
> > jeff
Subject and
> > Yahoo! Groups Links
Thank you for the step by step launch pad, it is greatly appreciated and
is helping me move along in my research.
As a side note I was hoping to have real - time processing or ever so
slightly delayed.
sincerely,
jeff
Original Message
Sent: Sunday, February 15, 2004 4:52 AM
Subject: [noparse][[/noparse]basicstamps] Re: video tracking with the stamp
> Hi Jeff,
> out or Ethernet out
> product.
> - Johari Aziz
> wrote:
> > Jon,
> > jeff
Original Message
> meeting
> lifelike
> > > -- Jon Williams
> > > -- Dallas Office
Original Message
> > > Hey group,
> it be
> but to
> is
> to some
> ideas
> start out
> > > with)
> > > Thanks in advance,
> > > jeff
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
As I had mentioned for real time you need to use very low resolution
video, perhaps non-standard format. It has to be processed by a
separate video capture hardware with it's own memory and output to
Basic Stamp in parallel format. If you want to sync audio with it,
you have to delay the audio with an audio delay unit to sync with the
video.
Orientation sensors usually output three signals, pitch, roll and
yaw. If you use DirectX on the PC you can use the joystick routine to
capture it. Another orientation sensors maker is Microstrain. their
site is at www.microstrain.com. Good luck and have fun.
- Johari
wrote:
> Johari,
appreciated and
so
> slightly delayed.
> sincerely,
> jeff
Original Message
> From: "Johari Aziz" <johaziz@y...>
> > Hi Jeff,
how
www.isense.com.
RS232
> > out or Ethernet out
use
It
> > product.
for
processing
be
will
> > - Johari Aziz
> > wrote:
> > > Jon,
> > > jeff
Original Message
> > meeting
very
> > lifelike
> > > > -- Jon Williams
> > > > -- Dallas Office
Original Message
> > > > Hey group,
the
would
> > it be
etc.
> > but to
head
> > is
me
> > to some
advice or
> > ideas
> > start out
> > > > with)
> > > > Thanks in advance,
> > > > jeff
> > Subject and
> > > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
