Pulsout not working right
Im trying to control a servo motor, using the PULSOUT command. Im
running a BS2 that is new and im using a brand new servo. Here is a
sample of the code i tried.
Main:
PULSOUT 1, 750
PAUSE 20
Goto Main
No matter what duration a replace the 750 with, it always makes the
servo go straight to the left and try to keep on going past the
stop... I've tried 2 other servos that i own, and it does the same
thing on them too.... Im running +5v to the servo. i dont know
what is wrong.... Any help will be appreciated.
-Tim
Main:
PULSOUT 1, 750
PAUSE 20
Goto Main
-Tim
There was an example code in the "What's a Microcontroller" book.
The code is
counter VAR Word
DEBUG "Counterclockwise 10 o'clock", CR
FOR counter = 1 TO 150
PULSOUT 14, 1000
PAUSE 20
NEXT
DEBUG "Clockwise 2 o'clock", CR
For counter = 1 TO 150
PULSOUT 14, 500
PAUSE 20
NEXT
DEBUG "Center 12 o'clock", CR
For counter = 1 To 150
PULSOUT 14, 750
PAUSE 20
NEXT
DEBUG "All done."
END
Tim,
I'm having trouble with the PULSIN. I'm trying to read a pulse from
a receiver. The receiver sends the same signals as the signals sent
to a servo. The PULSIN measures the pulse. So, what I tried to do
was, generate the pulses with the code above and include the pulsin
statement. It isn't reading the pulse/pulses. HELP!!
Good Luck
Jennifer
a
> Main:
> PULSOUT 1, 750
> PAUSE 20
> Goto Main
the
same
> Thanks
> -Tim
servopos var word
main:
servopos = 100
for servopos = servopos + 50 MAX 700
pulsout 1, servopos
goto main
Main:
PULSOUT 1, 750
PAUSE 20
Goto Main
-Tim
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
Setup:
LOW 1
Main:
PULSOUT 1, 750
PAUSE 20
GOTO Main
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Tim [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kTEl7VuicTvDL_zFE5udvyjJGj76uvGy7V99gDYEHC0RzihFlTsGx_pibajUbTXZ6yw3bbAvA7SmGLDF]tim_korn_99@y...[/url
Sent: Thursday, February 05, 2004 8:52 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Pulsout not working right
Main:
PULSOUT 1, 750
PAUSE 20
Goto Main
-Tim
and Body of the message will be ignored.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
"expected "TO""
thanks though
--- In basicstamps@yahoogroups.com, Kyle Cooper <crazykurby@y...>
wrote:
> This might help.
> servopos var word
> main:
> servopos = 100
> pulsout 1, servopos
> goto main
a
> Main:
> PULSOUT 1, 750
> PAUSE 20
> Goto Main
the
> Thanks
> -Tim
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> Do you Yahoo!?
center position, and ran the code, and it just went all the way to
the left. i dont know what's wrong with it. it does that on all of
my servos.
thanks
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Make your servo pin an output low before running your main code.
> Setup:
> LOW 1
> Main:
> PULSOUT 1, 750
> PAUSE 20
> GOTO Main
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Tim [noparse][[/noparse]mailto:tim_korn_99@y...]
a
> Main:
> PULSOUT 1, 750
> PAUSE 20
> Goto Main
the
same
> Thanks
> -Tim
Subject
> Yahoo! Groups Links
> abuse@p...
think that there is something wrong with my stamp. i just got the
thing, and plugged it into the carrier board... that's it... maybe
its a defect. i dont know how to check
--- In basicstamps@yahoogroups.com, "engjennifer21"
<engjennifer21@y...> wrote:
> Tim,
> The code is
> counter VAR Word
> PULSOUT 14, 1000
> PAUSE 20
> NEXT
> PULSOUT 14, 500
> PAUSE 20
> NEXT
> PULSOUT 14, 750
> PAUSE 20
> NEXT
> DEBUG "All done."
> END
> Tim,
from
sent
do
pulsin
> Good Luck
> Jennifer
Im
is
> a
> > Main:
> > PULSOUT 1, 750
> > PAUSE 20
> > Goto Main
> the
> same
> > Thanks
> > -Tim
> That bit of code didnt work for me either. im really starting to
> > > -Tim
750 is a *HUGE* pulse for a servo. A pulse of 100 will get it
reasonably close to center. 200 may or may not be beyond its upper
limit. and you <obviously> can't send it a pulse of 0 (zero) in the
other. I think you're trying to tell the servo to move farther than it
can...
Applicacion note 4: Controlling and Testing Servos - tells you what
you need to know, right out of the manual. Download it. It's free! :-)
Stephen Weller
American. Veteran. Patriot.
> sorry, but that didnt work. I even manually move
> the servo to its
> all the way to
> does that on all of
> my servos.
> thanks
Just a thought Tim, but are you certain all your
connections are right? Are you certain of which wires
on the servo are for power, ground and signal?
Chris Savage
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
a 1 mSec pulse to go one way, and a
2 mSec pulse to go the other way.
A 1.5 mSec pulse should put it in the
middle position. Also, the input line
should be normally LOW, and the pulse
should go high for the desired time.
And, the pulse should be 'refreshed'
every 20 to 50 mSec.
The above is what your code should do.
Parallax sells 'modified' servos which
continuously rotate, with direction set
by the pulse.
If all this is true for your servo,
then the one wild card is how you
specify that pulse.
PULSOUT 2, 750 on a BS2 will output
a 1500 uSec pulse (since the BS2 units
are in 2 uSec). This should work.
PULSOUT 2, 750 on a BS2sx will output
a 600 uSec pulse on pin 2
(since the BS2sx uses 0.8 uSec units).
This won't center the servo.
I'm guessing you either have a BS2sx,
or your servo does not use the
1 mSec/2 mSec standard, or your
servo is wired to some other pin.
Note pin 12 and pin 13 are standard
on the BOE.
You probably want:
PULSOUT 12, 1875
to output a 1.5 mSec 'center' pulse
on a BS2sx, on pin 12.
> sorry, but that didnt work. I even manually move the servo to its
of
> my servos.
> thanks
> > Setup:
> > LOW 1
> > Main:
> > PULSOUT 1, 750
> > PAUSE 20
> > GOTO Main
> > -- Jon Williams
> > -- Dallas Office
Original Message
Im
is
> a
> > Main:
> > PULSOUT 1, 750
> > PAUSE 20
> > Goto Main
> the
> same
> > Thanks
> > -Tim
> Subject
> > Yahoo! Groups Links
> > abuse@p...
100% sure that my connections are right. i've checked, and double
checked, and triple checked... My servo is on pin 1 right now, i've
even tried moving it to different pins and changing to code to see
if it will work.... nope still nothing. it seems like ANYTHING that
i send to the servo makes it go straight to the left. ALWAYS. i
cannot get the servo to move the other way... so, its either 1 of 2
things wrong. 1, all three of my servos are bad. 2, my stamp is
bad. the stamp is less than 2 weeks old, and the servo im using is
less than 2 days old. i have no clue.
thanks
-tim
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> My understanding is that the servo wants
> by the pulse.
> specify that pulse.
> on the BOE.
> You probably want:
> PULSOUT 12, 1875
its
to
all
> of
> > my servos.
> > thanks
<jwilliams@p...>
code.
> > > Setup:
> > > LOW 1
> > > Main:
> > > PULSOUT 1, 750
> > > PAUSE 20
> > > GOTO Main
> > > -- Jon Williams
> > > -- Dallas Office
Original Message
command.
> Im
Here
> is
> > a
> > > Main:
> > > PULSOUT 1, 750
> > > PAUSE 20
> > > Goto Main
makes
> > the
the
> > same
know
> > > Thanks
> > > -Tim
> > Subject
> > > Yahoo! Groups Links
to
> > > abuse@p...
the BS1 maybe. Anyhow, i've even tried giving it every kind of
pulse, from 10 to 1500. guess where it goes.... straight to the
left.
thanks
-tim
to
the
maybe
> > > > -Tim
than it
> can...
free! :-)
> Stephen Weller
I think you need a 6 volt, or 7.5 volt
power supply for the servo. I don't know
what more than that would do.
How are your batteries, if you're using those?
> thanks for the help, but im 100% sure that i have a BS2 and im also
i've
that
2
> thanks
> -tim
> > by the pulse.
> > specify that pulse.
> > on the BOE.
> > You probably want:
> > PULSOUT 12, 1875
> its
> to
> all
> > of
> > > my servos.
> > > thanks
> <jwilliams@p...>
> code.
> > > > Setup:
> > > > LOW 1
> > > > Main:
> > > > PULSOUT 1, 750
> > > > PAUSE 20
> > > > GOTO Main
> > > > -- Jon Williams
> > > > -- Dallas Office
Original Message
> command.
> > Im
> Here
> > is
> > > a
> > > > Main:
> > > > PULSOUT 1, 750
> > > > PAUSE 20
> > > > Goto Main
> makes
> > > the
> the
the
> > > same
> know
> > > > Thanks
> > > > -Tim
> > > Subject
> > > > Yahoo! Groups Links
SPAM
> to
> > > > abuse@p...
what's happening.
-- Jon Williams
-- Dallas Office
Original Message
From: Tim [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TXppFsHql4yzCEUdQTiUSUSLpMIORTXg8fvvNlUR9Qnn6HdWhNhVNWmBHh_evmSqi9qtfMRDXoFSgSWiWVtx]tim_korn_99@y...[/url
Sent: Friday, February 06, 2004 10:10 AM
Subject: [noparse][[/noparse]basicstamps] Re: Pulsout not working right
thanks
-tim
> by the pulse.
> specify that pulse.
> on the BOE.
> You probably want:
> PULSOUT 12, 1875
its
to
all
> of
> > my servos.
> > thanks
<jwilliams@p...>
code.
> > > Setup:
> > > LOW 1
> > > Main:
> > > PULSOUT 1, 750
> > > PAUSE 20
> > > GOTO Main
> > > -- Jon Williams
> > > -- Dallas Office
Original Message
command.
> Im
Here
> is
> > a
> > > Main:
> > > PULSOUT 1, 750
> > > PAUSE 20
> > > Goto Main
makes
> > the
the
> > same
know
> > > Thanks
> > > -Tim
> > Subject
> > > Yahoo! Groups Links
to
> > > abuse@p...
Yahoo! Groups Links
abuse@p....
a BS2. The units in the BS2's PULSOUT instruction are two microseconds,
so PUSLOUT pin, 750 will give you a pulse of 1500 microseconds, or 1.5
milliseconds which is the centering value for a standard servo.
-- Jon Williams
-- Dallas Office
Original Message
From: wun_fungi [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VPMznXOcJF0fceFIwjjWLvZazrgc_n1KYg8df0S0vVsbrIwtG2cQSiod1MOLNmZtFdjJXzkGPm8bqmqDrHU]sweller@a...[/url
Sent: Friday, February 06, 2004 7:27 AM
> > > -Tim
750 is a *HUGE* pulse for a servo. A pulse of 100 will get it reasonably
close to center. 200 may or may not be beyond its upper limit. and you
<obviously> can't send it a pulse of 0 (zero) in the other. I think
you're trying to tell the servo to move farther than it can...
Applicacion note 4: Controlling and Testing Servos - tells you what you
Stephen Weller
Yahoo! Groups Links
abuse@p....
>thanks
>-tim
Tim -
An R/C servo only goes on way. You set the center position with the PULSEOUT
command and use shorter or longer duration pulses to move from that
center-point.
Perhaps that's were the misunderstanding is.
Bruce Bates
>> by the pulse.
>> specify that pulse.
>> on the BOE.
>> You probably want:
>> PULSOUT 12, 1875
>its
>to
>all
>> of
>> > my servos.
>> > thanks
><jwilliams@p...>
>code.
>> > > Setup:
>> > > LOW 1
>> > > Main:
>> > > PULSOUT 1, 750
>> > > PAUSE 20
>> > > GOTO Main
>> > > -- Jon Williams
>> > > -- Dallas Office
Original Message
>command.
>> Im
>Here
>> is
>> > a
>> > > Main:
>> > > PULSOUT 1, 750
>> > > PAUSE 20
>> > > Goto Main
>makes
>> > the
>the
>> > same
>know
>> > > Thanks
>> > > -Tim
>> > Subject
>> > > Yahoo! Groups Links
>to
>> > > abuse@p...
>Yahoo! Groups Links
reason to get one. i've checked my voltage to the servo, im getting
4.95v to it because im using a 5v regulator. i called Parallax tech
support, and he seems to think that the stamp is working fine. he
advised me to try some extreme duration numbers for the pulsout. i
tried everything from 1, to 5000 for the duration. still just
always to the left. i called the place where i bought the servo,
and they've never had anyone complain that they didnt work. I cant
get ahold of the manufacturer though. i'll try again in a little
while. everything else on the stamp works fine, even on the pin
that im using for my servo.
im still stumped.
thanks
-tim
wrote:
> No, no, no ... 750 is the correct value to center a standard servo
with
microseconds,
1.5
> -- Jon Williams
> -- Dallas Office
Original Message
> From: wun_fungi [noparse][[/noparse]mailto:sweller@a...]
the
maybe
> > > > -Tim
reasonably
you
what you
> Stephen Weller
Subject
> Yahoo! Groups Links
> abuse@p...
> im using a BS2. 750 pulse = 1500. i think you are talking about
> the BS1 maybe.
You guys are right. I *was* thinking BS1. And "centered" to me is
relative. Sorry for the confusion. I go through servos like candy
(animatronics).
You probably already know that the servo expects to see a "train" of
pulses. Even when the sticks on an RC transmitter are centered, it
still sends pulses to keep the servo from drifting.
Have you tried adding a 1K pull-down resistor? (I never do) :-P
Is there noise getting into the signal?
Is it convenient to take the servo to a hobby shop and ask them to
test it?
Stephen Weller
--- In basicstamps@yahoogroups.com, Bruce Bates <bvbates@u...> wrote:
also
double
i've
see
that
of 2
is
> >thanks
> >-tim
> Tim -
the PULSEOUT command and use shorter or longer duration pulses to
move from that center-point.
> Bruce Bates
<allan.lane@h...>
> >> by the pulse.
> >> specify that pulse.
> >> on the BOE.
> >> You probably want:
> >> PULSOUT 12, 1875
to
> >its
way
> >to
> >all
> >> of
> >> > my servos.
> >> > thanks
> ><jwilliams@p...>
> >code.
> >> > > Setup:
> >> > > LOW 1
> >> > > Main:
> >> > > PULSOUT 1, 750
> >> > > PAUSE 20
> >> > > GOTO Main
> >> > > -- Jon Williams
> >> > > -- Dallas Office
Original Message
> >command.
> >> Im
> >Here
> >> is
> >> > a
> >> > > Main:
> >> > > PULSOUT 1, 750
> >> > > PAUSE 20
> >> > > Goto Main
> >makes
> >> > the
> >the
the
> >> > same
> >know
> >> > > Thanks
> >> > > -Tim
the
> >> > Subject
> >> > > Yahoo! Groups Links
SPAM
> >to
> >> > > abuse@p...
> >Yahoo! Groups Links
together.
Al Williams
AWC
* Universal Stamp Prototyping Board
http://www.awce.com/asp3.htm
Original Message
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FqVImxR7s4Fz4ycM-5zqjQ4IrMaQQYk7lx90EX3jBzZEmrraKgWO9stzQai_WXgILsLaWj4jDYqfVCvjmk8]knight_designs@y...[/url
Sent: Friday, February 06, 2004 7:51 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Pulsout not working right
> the servo to its
> all the way to
> does that on all of
> my servos.
> thanks
Chris Savage
Knight Designs
(607) 535-6777
Do you Yahoo!?
Yahoo! Groups Links
Just to quadruple check [noparse]:)[/noparse] could you describe which wires on the servo you
have connected to power ground and signal.
Also, describe VSS, Vdd connections if you are using a BOE
It just sounds like to me the servo is miswired.
Shawn Lowe
>ok, then what is the center point?
Tim -
The following is just what Jon Williams has already said:
"750 is the correct value to center a standard servo with
milliseconds which is the centering value for a standard servo."
Bruce Bates
>also
>double
>i've
>see
>that
>of 2
>is
>> >thanks
>> >-tim
>> Tim -
>> Bruce Bates
><allan.lane@h...>
>> >> by the pulse.
>> >> specify that pulse.
>> >> on the BOE.
>> >> You probably want:
>> >> PULSOUT 12, 1875
>to
>> >its
>way
>> >to
>> >all
>> >> of
>> >> > my servos.
>> >> > thanks
>> ><jwilliams@p...>
>> >code.
>> >> > > Setup:
>> >> > > LOW 1
>> >> > > Main:
>> >> > > PULSOUT 1, 750
>> >> > > PAUSE 20
>> >> > > GOTO Main
>> >> > > -- Jon Williams
>> >> > > -- Dallas Office
Original Message
>> >command.
>> >> Im
>> >Here
>> >> is
>> >> > a
>> >> > > Main:
>> >> > > PULSOUT 1, 750
>> >> > > PAUSE 20
>> >> > > Goto Main
>> >makes
>> >> > the
>> >the
>the
>> >> > same
>> >know
>> >> > > Thanks
>> >> > > -Tim
>the
>> >> > Subject
>> >> > > Yahoo! Groups Links
>SPAM
>> >to
>> >> > > abuse@p...
>> >Yahoo! Groups Links
>Yahoo! Groups Links
signal wire. it is connected to pin 1 on my stamp. sound right to
you?
--- In basicstamps@yahoogroups.com, "Shawn Lowe" <livinlowe@e...>
wrote:
> Tim-
servo you
> Shawn Lowe
(find URL by googling on "WinScope 2.51"), connect it (your circuit)
to your sound card (you'll need a headphone patch cable and a small
jack, or alligator clips at worst), and watch the signal pin through
a 10k resistor. If you don't see a 50 Hz 1.5 ms signal (at
Pulseout1, 750) and a 1.0 ms signal and a 2.0 ms signal at the other
extremes, you got a problem with your stamp or program. I went
through this experiment/exercise several weeks ago - solved my
problem in 30 minutes. Winscope is super easy to use. Invented by a
Russian scientist - go get it.
If the signal looks good, then there might be a problem with your
Servo, but all 3 ??? Not likely, eh, but to test the Servo
separately you could build a small circuit from a couple of 555
timer chips. See this URL for such a circuit
http://www.seattlerobotics.org/encoder/200210/servoex/ServoExcerciser
.htm
Now if your Stamp puts out the right signal, and the servos don't
work right, and the 555 Circuit puts out the right signal (assuming
it's assembled right - but hey you got WinScope to test it with) and
the servos still don't work, you got a wiring problem, or you burned
out all three servos. Laws of deduction rule
> nope, i dont have an o-scope, but i think this is a pretty good
getting
tech
i
cant
> im still stumped.
> thanks
> -tim
is that the Stamp is being 'browned-out'
when it tries to control the servo. Note
the servo can take 35 mA when it's being
moved. If you're driving the servo with
4.9 volts, what is the Stamp getting?
Are you using a BOE?
Are you really using a 5-volt DC supply?
(I think a BOE needs at LEAST a 6 Volt).
> red wire to +5v and black wire to ground. the grayish wire is the
> you?
> wrote:
> > Tim-
> servo you
> > Shawn Lowe
it. they hooked it up to a radio and receiver, and bam, it worked.
both ways, just like it should. that means its my stamp. i know
the I/O pins arent dead, cuz they do everything else that i want
them to, such as frequency out and light up an LED. im using a
separate power source for the servos. i've got a 7.2v battery pack
hooked to a 5v regulator. that's how im getting the 5v to the
servos. the BSII itself is running on a fresh 9v battery. where
could some noise be coming from? how would i isolate it?
im using a regular ol' BS2 carrier board, not the BOE.
thanks
-tim
about
> > the BS1 maybe.
> (animatronics).
of
> test it?
> Stephen Weller
Since you're running both off batteries, that pretty much eliminates a
noise problem.
If you pulsout to an LED you should be able to ramp it up from off to
full on and back down - exactly the same way you'd sweep the servo
from stop to stop.
Someone else had asked, is the servo ground connected to the stamp
ground?
7.2 volts? Hmm. I have serious doubts that servos are *that* picky,
but it wouldn't hurt to run up to Rat Shack and get a 4-cell AA
holder. I always run servos off 6 volts.
Running out of options fast! :-P Grasping at straws.
Stephen Weller
> BS2 and im also
> checked, and double
> right now, i've
> to code to see
> like ANYTHING that
> left. ALWAYS. i
> its either 1 of 2
> 2, my stamp is
> servo im using is
> thanks
> -tim
One last thing Tim, what are you using for the Power
Supply? On one occasion, I had a servo moving reset
my BS2 occasionally. Was a weak supply. Not sure if
that would cause what you're getting, but it's a
suggestion, nonetheless...
Chris Savage
Knight Designs
(607) 535-6777
Do you Yahoo!?
noise problem, so after i got off the phone, i routed the ATN wire
from the serial cable through 2 0.1UF capacitors just like the board
of education uses. he said that might fix it. well, ummmm.. nope.
didnt help a bit. i am using a 7.2v battery pack to power the
servo, BUT it is going through a 5v regulator. so my servo is
getting real close to 5volts.
on another note, i know for sure that the servo is good, because i
tested it on a R/C receiver. and the Parallax tech guy says that
the stamp is good, because other functions work off of that pin. im
running out of options too...... the servo ground is not connected
to the stamp ground right now, but im going to go try it now.
thanks for the help guys
-tim
where
eliminates a
> noise problem.
to
> from stop to stop.
> ground?
> Stephen Weller
>> servo you have connected to power ground and signal.
> is the signal wire. it is connected to pin 1 on my stamp.
> sound right to you?
No, actually. It bothers me as it does Shawn. It's almost certain that your
problem lies in the wiring. Possibly in the power arrangements. I don't
recognize that wiring color pattern, and some manufacturers have peculiar
notions. Not every engineer in the world agrees with US conventions.
More to the point, if we're going to be any help we can't keep playing
twenty questions, Tim. Can you be specific about these following points?
1. What is the manufacturer and model number of these servos? What do they
specify as the order of the wires starting from one side? Does it go G-V-S,
or S-G-V or what?
2. In the likely case that their order for the wires in the connector does
not match Futaba, then how are they wired without using the standard
Parallax connectors? (The standard connectors on all my Parallax boards use
the Futaba wiring pattern. I presume all Parallax boards do.) Are you
inserting solid wires in the end of the servo connector and taking those to
a prototype area? Or have you removed the connector and soldered directly to
the servo wires? How have you handled this problem? Have you torn all this
out and re-wired from scratch to see if it's a bad connection we're dealing
with here?
3. Are you willing to run a couple of experiments that any of us would run
on site to diagnose this problem? Then try this:
Using a 5V supply for the servos is an odd choice. Hopefully, you don't mean
you're running the servo off the Vcc provided by the Stamp's regulator. If
not, if you are using a completely separate supply for the servo, then that
adds another whole set of potential problems. Drop that approach for testing
purposes. Connect the servo to the battery source supporting the BS2, and
change that source to one using four AA's. That will make the Stamp
regulator just as happy as a 9V battery would, and the servo circuits also
will be fine with an unregulated source around 6V.
Now, with that done, what is the behavior when you connect in the usual
pattern? By that I mean the BS2 is running off it's own power regulator;
that regulator is supplied by four fresh AA's; and the same Vin from those
AA's, the raw battery voltage, is providing the power line to the servo. Oh,
yes. And don't use your own software. Download one of Jon's programs, just
in case a coding error is keeping that PULSOUT command from being the one
that actually executes.
The only result consistent from everything you've told us is that the servo
will behave correctly at this point. Now we start adding back complexity
until we find the problem.
Speaking as a past test engineer, this sounds like almost enough trouble to
get an answer. Sorry, but Murphy was right you know. Seriously, you have
independently tested the servos; and independently tested the Stamp. That
leaves only your configuration: the choice of power arrangements and the
wiring and anything else you haven't mentioned yet. Get back to a simple
known-good configuration first. Then build back to your desired
configuration.
Hope we can help you eventually,
Gary
At the risk of sounding overly optimistic:
B-I-N-G-O!!! E-U-R-E-K-A!!! Y-I-P-P-I-E S-K-I-P-P-I-E!!!
The servo and the stamp *MUST* have a common ground!
Well? C'mon, Tim! We're waiting... :-)
Stephen Weller
