Analog Digital Manual chp 1
In this chapter they use a POT, OP AMP, and an LED. Im wondering if you can
vary an LED's brightness with just a POT, VDC, and an LED or do you need the OP
AMP?
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
AMP?
Do you Yahoo!?
with just a POT. BUT, the next step in
the lab is to replace the POT with a
resistor-capacitor combination, charged
with a software command from the BS2.
For this command to work, you need to
have the op-amp there. An op-amp has
a very high input impedance, so it
takes very little charge from the
capacitor, so the capacitor
can maintain its charge. This is
the heart of a simple (cheap)
D to A converter.
Just so you know, an LED's output is
usually full on or full off. You can dim
it by finding that narrow range of currents
where it is partially on, which is what
this lab does.
if you can vary an LED's brightness with just a POT, VDC, and an LED
or do you need the OP AMP?
> Do you Yahoo!?
that helps for now, I will need to absorb that.
Allan Lane <allan.lane@h...> wrote:
Yes, you can vary an LED's brightness
D to A converter.
this lab does.
> Do you Yahoo!?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
