PWM Amplification to 0-10V
Hi All,
Am fairly new to electronics so bear with me if this sounds daft! I
need to amplify the O-5V PWM signal that the stamp outputs to a 0-
10V PWM signal. Has anyone any information on how to go about this.
Any help will be most greatfully appreciated.
Many thanks
Hugh
Many thanks
Hugh
http://groups.yahoo.com/group/basicstamps/message/39364.
In his case, he needed 0-12V and 4W so you actually have it easier. You
could select an op amp to run at 12V and easily get 10V out.
Al Williams
AWC
Stamp FAQ: http://www.wd5gnr.com/stampfaq.htm
Original Message
From: hughgoodbody [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-K5cwdxQbKmvqxmDZ7T42VNykHXNswHgfEEO5jgn3K8-ls_PE_NLhZfz1GPPVQS496pZTQ9ovVetgSRz5eEZBwM]hughgoodbody@y...[/url
Sent: Wednesday, January 21, 2004 8:48 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] PWM Amplification to 0-10V
Hi All,
need to amplify the O-5V PWM signal that the stamp outputs to a 0- 10V PWM
Many thanks
Hugh
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Yahoo! Groups Links
To visit your group on the web, go to:
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
from Vin to Vss to power the stamp. The resistor value
should be selected to limit the voltage to the stamp, 75 ohms will drop 7.5v at
100ma and leave 7.5v to power the stamp, if your app
draws a lot less than the max (most of mine are around 20ma.) try 100 to 470
ohms the goal here is to keep the stamp input voltage
between 5.5v an 11v to limit its internal dissipation.
Now finally use the full 15v to power an op amp such as the lm2902 that is
capable of output swings to 0v, and feed your pwm signal
to its non-inverting input, take your output directly from its output pin and
connect a resistor from there to the inverting input,
add another equal value resistor from the inverting input to Gnd. The inverting
input will now see 1/2 the op-amps output and drive
it's output to 2x the input voltage.
KF4HAZ - Lonnie
> Hi All,
> Many thanks
> Hugh
the output with an inverting unity (no gain) stage and there you are. A
dual-op amp like an MC1458 would probably work well for you.
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: hughgoodbody [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8UAdY2ruVlG9VQ_UTv1SG-cinv8pLzcXXXAft-Qa6wOBe-9V4OfteL_dGJ7QRPfEGUUNLu8AmeBaPu-IQCjG7Mg]hughgoodbody@y...[/url
Sent: Wednesday, January 21, 2004 9:48 AM
Hi All,
Many thanks
Hugh
Yahoo! Groups Links
Two questions:
1) how much current can the 0 to 5 volt PWM signal sink/source?
2) how much current does teh 0 to 10 volt PWM signal need to sink or source?
Setting up this circuit should be very simple once I know answers to the
above.
Ken
In a message dated 1/21/2004 7:07:06 AM Pacific Standard Time,
hughgoodbody@y... writes:
Hi All,
Many thanks
Hugh
The 0-5V PWM Signal I think will be approx 5-10mA
The 0-10V PWM Signal Max Current is 1.1A and max Power is 0.5W
Hope this helps!
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> Hugh,
> Two questions:
or source?
to the
> above.
> Ken
> Hi All,
I
this.
> Many thanks
> Hugh
Couple other questions I forgot to ask, what is the frequency of the PWM
signal.
Also, will the 0 to 10 v pwm provide power (source current) to the load, or
provide ground (sink current) to the load.
Ken
In a message dated 1/21/2004 1:19:17 PM Pacific Standard Time,
Ken,
Hope this helps!
The signal will provide current to the load. As to the frequency, i
am not sure. The signal is being generated from the stamp and the
cycle value am using is 100ms, but this can be altered.
> It helps!!!
the PWM
> signal.
load, or
> Ken
> Ken,
> Hope this helps!
I'm not 100% sure what the signal is supposed to look
like at the load, but here's a couple ideas:
1) Filter the PWM signal from the Stamp through an R/C
circuit, then drive the varying signal into a power
op-amp (something like a TDA2040 or LM1875, etc. with
appropriate power supply and heatsinking). The power
op-amp can provide the necessary gain to get get the
signal amplitude you're looking for and can easily
drive +/- a couple amps. These are designed for audio,
so they can easily handle from DC to the fastest
signal a Stamp can deliver.
2) Drive the PWM signal directly into a power switch
(like a TC4425 or UC2710 from Digi-Key also with
appropriate power supply). These switches will both
sink and source from 3 to 6 amps with very fast
slew-rates. Plus, these have both an inverting and
non-inverting output so you can run them in a bridged
configuation to double the output swing to the load.
Best of all is these saturate so well, the don't
require heatsinking and are in an 8-pin DIP package.
This will provide a high-current PWM signal to the
load, but the voltage delivered will depend on the
power supply rails or bridge configuration. With the
bridge configuration, you only need a single 5V supply
to get 0-10 volts.
DrDiode
--- hughgoodbody <hughgoodbody@y...> wrote:
> Ken,
> the frequency, i
> stamp and the
> altered.
> wrote:
> > It helps!!!
> the frequency of
> the PWM
> > signal.
> current) to the
> load, or
> > Ken
> Standard Time,
> > Ken,
> Power is 0.5W
> > Hope this helps!
> removed]
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
http://webhosting.yahoo.com/ps/sb/
