Pulsin in a if then statment
Hi all
Is it ok to do this as a statement line... i.e. the
IF x>=3 AND x<=4 OR x=0 THEN
PULSIN 0,0,x
ENDIF
in below part of a program
on
'{$STAMP BS2}
'{$PBASIC 2.5}
SAMPLE2:
PULSIN 0,0,x
PULSIN 0,0,x ............................................ The reason I am
checking twice is if i get a consistent 3 or 4 or 0 I know sequence has ended .
want to move on rather than sample again.
ENDIF
IF x>=3 AND x<=4 OR x=0 THEN DISPLAYA
CHK(0) = x
I=1
FOR I=1 TO 8
PULSIN 0,0,x
CHK(I)=x
NEXT
GOTO CHECKCOUNT2 (do some maths here at checkcount two with results)
The reason I am checking twice is if i get a consistent 3 or 4 or 0 I know
sequence has ended and want to move on rather than sample again.
Used x>=3 AND x<=4 as may swap to a variable later like x>=A AND x<=B
Also another question on variables in a FOR NEXT loop
PROGRAMBODYC:
N=0 ...................................... (as I am using the same variable N
and M in different programbodya:,b ,c, d is it correct to set them to 0 for a
FOR N=0 TO 4 loop)
M=0 .......................................(so as not to get an error on the
FOR NEXT loop in next part of program)
FOR N=0 TO 4
M=(8-N)
IF CHK(N)>CHK(M) THEN
LC=LC+1
ENDIF
IF CHK(N)<CHK(M) THEN
HC=HC+1
ENDIF
NEXT
GOTO SAMPLE3
Its on a BS2 and all the variables are defined at the top!
I have use this a couple of times (PROGRAMBODYC: and SAMPLE2: re named D and 3
etc respectively) in the same program it seems to work the first two times but
not sure if its working properly over. Cant DEBUG to a screen without a big
effort.
Thanks in advance
Rob Farrand
This email is confidential and may also be privilege.
If you are not the intended recipient, please notify us immediately.
You should not copy or use it for any purpose, nor disclose it's contents to any
other person.
PULSIN 0,0,x
ENDIF
on
'{$STAMP BS2}
'{$PBASIC 2.5}
SAMPLE2:
PULSIN 0,0,x
ENDIF
CHK(0) = x
I=1
FOR I=1 TO 8
PULSIN 0,0,x
CHK(I)=x
NEXT
PROGRAMBODYC:
FOR N=0 TO 4 loop)
FOR N=0 TO 4
M=(8-N)
LC=LC+1
ENDIF
HC=HC+1
ENDIF
NEXT
GOTO SAMPLE3
effort.
Thanks in advance
Rob Farrand
other person.
>Hi all
>PULSIN 0,0,x
>ENDIF
The Stamp only recognizes integers, so the beginning of that IF statement has no
logical meaning, and can only be TRUE when X=0.
>on
>'{$STAMP BS2}
>'{$PBASIC 2.5}
>SAMPLE2:
>PULSIN 0,0,x
>ENDIF
>CHK(0) = x
>I=1
>FOR I=1 TO 8
>PULSIN 0,0,x
> CHK(I)=x
>NEXT
>PROGRAMBODYC:
FOR N=0 TO 4 loop)
It will be set to ZERO at the beginning of the loop, so it really isn't
necessary.
>FOR N=0 TO 4
>M=(8-N)
>LC=LC+1
>ENDIF
>HC=HC+1
>ENDIF
>NEXT
>GOTO SAMPLE3
effort.
>Thanks in advance
>Rob Farrand
Bruce Bates
any other person.
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
aware that PBasic evaluates strictly from
left to right -- UNLESS you use parens to
detail your intent. So it should be:
IF ( ( X >= 3) AND (X <= 4) ) OR (X = 0) THEN
Note this 'strict left-to-right' evaluation
is NOT typical of programming languages, but
simplifies the PBasic runtime, with the only
cost being the additional parens.
--- In basicstamps@yahoogroups.com, "Rob Farrand ... FTech
Connection" <ftech@n...> wrote:
> Hi all
> PULSIN 0,0,x
> ENDIF
> on
> '{$STAMP BS2}
> '{$PBASIC 2.5}
> SAMPLE2:
> PULSIN 0,0,x
know sequence has ended . want to move on rather than sample again.
> ENDIF
> CHK(0) = x
> I=1
> FOR I=1 TO 8
> PULSIN 0,0,x
> CHK(I)=x
> NEXT
I know sequence has ended and want to move on rather than sample
again.
x<=B
> PROGRAMBODYC:
same variable N and M in different programbodya:,b ,c, d is it
correct to set them to 0 for a FOR N=0 TO 4 loop)
error on the FOR NEXT loop in next part of program)
> FOR N=0 TO 4
> M=(8-N)
> LC=LC+1
> ENDIF
> HC=HC+1
> ENDIF
> NEXT
> GOTO SAMPLE3
named D and 3 etc respectively) in the same program it seems to work
the first two times but not sure if its working properly over. Cant
DEBUG to a screen without a big effort.
> Thanks in advance
> Rob Farrand
immediately.
contents to any other person.
