basic stamp and pc communication
How do I test my bs1? The stamp dont communicate with pc. I tested
and found no shorts. The voltage (in and out of regulator) is OK. The
cable is OK too. What else should i check? Thanks.
Which version of the Stamp Editor are you using ?
I trust you are using the parallel port if you're using the Stamp1.EXE Editor.
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
The latest version (2.1, beta 1) of the editor supports the BS1 but
requires a serial adapter.
http://www.parallax.com/detail.asp?product_id=27111
Note: Our Windows editor does NOT support the original (parallel port)
BS1 programming cable.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: luiz_kapa [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=v9dL97DUe7FknI_PmqLacYRsaeZx858uecrn3B2Qe38oaKbqvcA2p2LA6IZWOXYANcrmgoXhEkXw]luizzz@h...[/url
Sent: Sunday, January 18, 2004 3:34 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] basic stamp and pc communication
