event triggering from ds1302 time
I'm trying to read a time value from the DS1302 chip and then
evaluate it against an "alarm time." I'm able to set the time and
display it in the debug window, but I can't yet capture the value to
compare it to my setpoint.
I think the reason this string
DEBUG HEX2 Hours,":",HEX2 Minutes,":",HEX2 Seconds,CR
prints the time value is because the values of those variable are
held in these declarations.
Seconds VAR Byte
Minutes VAR Byte
Hours VAR Byte
but I can't find a way to use Hours:Minutes:Seconds to trigger the
event.
can anyone help?
I've learned a lot from just reading on this site and appreciate all
the work that everyone is doing to make the site such a useful tool.'
thanks
Seconds VAR Byte
Minutes VAR Byte
Hours VAR Byte
event.
can anyone help?
thanks
stored in the variables, here is one approach. You have to remember
that time is HEX:
IF hours=$07 AND Minutes=$30 THEN DEBUG BELL
I like to convert the time into a continuous variable that goes from
0 to 1439 for the minute of the day, or 0 to
14390 for ten second resolution.
julian = hours.nib1*10+hours.nib0*6+minutes.nib1*10+minutes.nib0
In that scheme, 7:30 am is 450
IF julian=450 THEN DEBUG BELL
-- Tracy
>Seconds VAR Byte
>Minutes VAR Byte
>Hours VAR Byte
>event.
>can anyone help?
>thanks
timely and helpful response.
Steve Hinote
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> This should be a piece o'cake. If you have the time successfully
remember
> that time is HEX:
from
> julian =
> -- Tracy
to
> >Seconds VAR Byte
> >Minutes VAR Byte
> >Hours VAR Byte
> >event.
> >can anyone help?
all
tool.'
> >thanks
