what chip to use?
A handicap friend has asked my help to build a circuit to control a 3
level home brew elevator. I have designed a logic circuit consisting
of several logic IC's but have finally decided to look into applying
a microchip to replace the numerous logic chips. Due to the large
number of Microchips available and the necessity to now teach myself
programming, I'm stumped at where to begin to choose what Microchip
to use. Can anyone help?
The logic circuit I have put together will monitor the ON – OFF state
of five inputs to control three separate outputs, 1 for a brake, 2
for the 110v AC motor, 15 amp max (two separate wires for one
direction two for the other reverse direction ). I plain on
connecting 2 solid state relays (SST-240D25) to the outputs of a
microchip to switch AC. Also, would like to use three infrared or
such from elevator to eliminate any need for wires from elevator
although we do have two wire ( 110v ) coming off of a spring spool to
elevator.
I hope to be able to program a chip to distinguish the latch on off
state of the outputs based on the state of the 5 inputs.
The output of my present logic circuit controls to JK flip-flops used
for latching on – off (one up direction the other down ) and
feeding the AND gate that controls the brake action. I hope using a
Microchip wont be as much trouble as the countless hours spent
designing the logic circuit that at first seemed simple. Any input
will be greatly appreciated. Thanks T.O.
elevator.
documentation.......the BASIC STAMP.
ken
In a message dated 1/12/2004 11:27:47 AM Pacific Standard Time,
tloleksy@y... writes:
for latching on
still many to choose from ( which one? ) and would
seem like over kill if it were possible to put
together a pic or microprocessor circuit that was
capable of the task, cost is a big issue for many
handicap individuals. Thanks T.O.
__________________________________
Do you Yahoo!?
Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
http://hotjobs.sweepstakes.yahoo.com/signingbonus
They (Parallax) have solved the issues of
power supply, EEPROM programmer, PIC assembly,
PIC programming, brown-out recovery, debugging.
As long as you don't use too much current,
(which will reset the chip)
the BS2 lets you try almost anything.
Its only drawback from PIC's -- it's not as fast,
and it doesn't have interrupts, and it costs
$50.00 for the Module.
Otherwise, it's MUCH easier to program, verify
it's correct, put in-circuit, use RS-232 with,
you name it. And a decent PIC programming
setup is going to cost more than $50.00.
A 100 line program in PBasic should be sufficient
to do what you are attempting. Short to write,
short to debug. Running the wires to support
the sensors will probably take longer than writing
and debugging the code in PBasic.
For one-of solutions like yours, I don't think
you can have a more cost-effective solution.
3
consisting
applying
myself
state
to
> elevator.
off
used
a
a PIC chip to use -- in which case:
the 16F876 (28-pin, narrow DIP) can program
itself, once a bootloader has been installed in
the chip. The 16F877 (40-pin, wide DIP) is the
same internally, with additional I/O pins.
Both can use 20 Mhz resonators, take 4 clock cycles
per instruction, and so can run at 5 MIPS.
You can check this chip out on the Microchip site.
But I still stick with what I said earlier --
the BS2 (plain) or BS2sx (faster) is the
easiest and most cost-effective way to go.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> HIGHLY recommend the Basic Stamp, in the BOE board.
a
> 3
> consisting
> applying
> myself
Microchip
I got into Basic Stamps designing devices for a handicapped friend also.
If you don't already have a programmer for PICs, AVRs etc., you will come
out way ahead on cost and especially time by going with one of the basic
Stamps. Any of the stamps can handle your chore but I would probably start
with a BS2 if for no other reason than pin count. If you want to produce
your project commercially in the future, you can always port it to one of
the cheaper chips or buy the interpreters etc. from Parallax and roll your
own.
Jeff
Original Message
From: Terry Oleksy [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pYnRjFZrBuT1QEsCRCgY9iEv2-dxIE2Jbc5jR-C2kHJKbG70h0LsSDjEMVRX1Ud1PhmfQfoEbLk]tloleksy@y...[/url
Sent: Monday, January 12, 2004 2:55 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] what chip to use?
Thanks for the fast response, how ever there are
page 99
"The first step in solving any problem is to clearly define the task to be
accomplished
The next step is to break that task into sub-functions.
This process continues until all the sub functions are reduced to the point
where they seem easy to implement.
Then, each sub-function is meticulously implemented and individually tested.
Once all the sub-functions are complete and work perfectly, they are then
combined and tested as a whole.
Of course it never works the first time through. And, after the panic wave
ripples through the fabric of your soul because your deadline is about to
expire, the troubleshooting begins. The trouble, invariably, is caused by a
ubiquitous computer bug: the PEBCAC, (Problem Exists Between Chair and
Computer.)"
The Parallax site has loads of documentation you can download to broaden
your level of understanding. An excellent book for help and reference is
"The Art of Electronics" by Paul Horowitz and Winfield Hill, 2nd edition
Publisher Cambridge.
When you invest time in your own learning process, Then you will see more
rewarding results in your projects.
Regards, Steve Chapman
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, January 12, 2004 11:12 AM
Subject: [noparse][[/noparse]basicstamps] what chip to use?
> The logic circuit I have put together will monitor the ON - OFF state
> elevator.
> for latching on - off (one up direction the other down ) and
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
this question about controlling an elevator for a handicapped friend caused
an immediate involuntary clenching of that special pucker muscle. Please be
aware that most parts for elevators need to be certified, licensed, and
inspected by a local authority. This is to prevent accidents from happening,
and liabilities from occurring. It's one thing to write your own program for
a data logger or a robot or even an industrial process, but quite another
when a human can be injured or worse from a program bug. Please, please,
please, review this with any local authorities before you build it. And if
you do build it, make sure you test, test, test, and put in fail safes. I
understand wanting to save money and build helpful things for those who
can't afford the big stuff, but that will all be worthless if someone gets
hurt. We all joke about Murphy's Law, but it's one of those universal
constants that we'll never get around.
Let's be careful out there...
Mike Sokol
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Original Message
Sent: Monday, January 12, 2004 2:12 PM
Ref: A handicap friend has asked my help to build a circuit to control a 3
