BS2/VB connection problem
I am working on a data collection project using VB6.0.
When I try to compile my VB program, I get an "Object required" error
for any any "mscomm..." statement. Any help would be appreciated.
Marylou
Marylou
> Marylou
Have you added the MSComm activex control to the project, and dropped
it on the form?
-Bruce
tech@r...
http://www.rentron.com
Components (or Control+T) and see that MSCOMM32.OCX is checked. If you don't
have it at all, you need to install it or register it. There are some
replacements referenced at http://www.lvr.com
Al Williams
AWC
*NEW: Universal PCB fits Stamp, SX, more
http://www.al-williams.com/gpmpu40.htm
Original Message
> From: astumpf999 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=k8lN0Ati2d79DszsrkZd9ypS57gQ9bvWlR2QjSfim8EGgmMRWxwoJYUgNDhkekZSzZ8Rzbo6S-I73NvHrSU]astumpf999@y...[/url
> Sent: Friday, January 09, 2004 3:55 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] BS2/VB connection problem
> Marylou
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
components box, clicked on the "Apply" button and still get the same
error message.
Marylou
________________________________
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Sounds like you need to add MSComm to your project. Go to Projects |
you don't
some
> Al Williams
You could find the ocx and run :
regsvr32 mscomm32.ocx
That will cause it to self-register. And you do have it dropped on the form
with the right name, right? You can see an example, btw, at
http://www.al-williams.com/stampcom.zip
Al Williams
AWC
*NEW: Universal PCB holds Stamp, SX, more...
Original Message
From: astumpf999 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t1AH1jASMz0hQwkvelEswKmT3Yid5pyUCeEP4Il7keFlWt5gR-eh8zyMDf1f8M5i6yrzEMd6XVmD-5E]astumpf999@y...[/url
Sent: Friday, January 09, 2004 8:55 PM
Subject: [noparse][[/noparse]basicstamps] Re: BS2/VB connection problem
How do I install or register mscomm32.ocx? I checked it in the
error message.
Marylou
you don't
some
> Al Williams
from the same email address that you subscribed. Text in the Subject and
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
Thanks for your help. I looked at your program and found the
mscomm32.ocx object entry. My question is how did it get there or how
do I "drop it in the form"? Could you get a bit more specific?
This may be a simple thing to a professional programmer. My only
previous experience was quickbasic for hobby projects and I find VB
somewhat overwhelming.
Marylou
______________________________________
> Well if it is in the list and checked then I suspect you already
have it.
the form
> Al Williams
> AWC
Original Message
> From: astumpf999 [noparse][[/noparse]mailto:astumpf999@y...]
same
> error message.
> Marylou
Projects |
> you don't
> some
> > Al Williams
Subject and
> Yahoo! Groups Links
You must have VB Professional to use the MSComm control in your own
projects. If you don't have VB pro, you'll need to find an MSComm
replacement. A couple people have built wrappers around the MSComm
control do that it could be released and used all users.
If you do have VB Pro, you can make the MSComm control available to your
project by going to Porject | Components, then selecting MS Comm Control
and clicking [noparse][[/noparse]Apply].
-- Jon Williams
-- Parallax
Original Message
From: astumpf999 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=63-ouDqRVVLjOyMH2tfhyCsOq2jMLYZ4pipipp_rQvWYNBhVjke4UFE-BtZFAqkEZ--Mqp6_xyIx-IM8hpg]astumpf999@y...[/url
Sent: Saturday, January 10, 2004 12:49 PM
Al,
Marylou
have it.
the form
> Al Williams
> AWC
Original Message
same
> error message.
> Marylou
Projects |
> you don't
> some
> > Al Williams
Subject and
> Yahoo! Groups Links
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
double click it to put one on the form (or drag it out like a button, but it
will stay the same size). This control only shows up at design time not run
time.
If you need a replacement, look at http://www.lvr.com for more.
Al Williams
AWC
* Easy RS232 Prototyping
http://www.al-williams.com/rs1.htm
Original Message
From: astumpf999 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Kmvi6pSw3tbnOC_L43rrn2eOvHZnYDYjgJg0HMPJ6rRQcA61Ow-K6RFOc9uFQw8W5vWMh-CR2YUVtqrw]astumpf999@y...[/url
Al,
Marylou
have it.
the form
> Al Williams
> AWC
Original Message
same
> error message.
> Marylou
Projects |
> you don't
> some
> > Al Williams
Subject and
> Yahoo! Groups Links
Yahoo! Groups Links
This file has:
1. A complete example, both VB side and BS2 side.
2. A 'readme.txt' file, which tells you how to
create the application on VB from scratch.
See the .TXT file for exact drag-and-drop instructions
on how to use the MSCOMM control. It DOES assume
you have the VB5 PRO or VB6 PRO versions.
--- In basicstamps@yahoogroups.com, "astumpf999" <astumpf999@y...>
error
> Marylou
Marylou
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> In the 'Files' section, see AlDemo\BS2_VBDemo.zip
> This file has:
> error
> > Marylou
