Paintball
Hi, just joined here, and i've done alot of TRUBasic programming, but
nothing here on a basic stamp yet. If there are any similar programs
you could email me, or if you have any advice for how to put it
together, feel free to let me know. What i'm trying to build is
a "bomb" to use in paintball, similar to the game "Counter-strike" on
PC and Xbox. Don't worry, no dangers in this one, it will simply run
a relay to a small siren to signal the "bomb" went off and the game
is over. Here's what the program needs to do:
It needs to recieve input from 3 switches, and give output to an
innovation first Spike relay. With the switches, the "Arm" switch
must be held for 10 seconds to turn on the "bomb". A counter will
count down from 100 seconds, while telling the relay to beep the
siren again and again, with the time gap in between beeps getting
smaller to match the timer. Now, the "Disarm" button must be held for
10 seconds to turn off the "bomb", which then results in the relay
beeping the siren in some sort of pattern to let everyone within
earshot know that it is disarmed. The 3rd button is an instant
disarm, for in case the person disarming is the one on their team (or
has access to the person) with the "disarming tool", most likely a
headphone plug, which completes its switch circuit when installed.
This is all built onto a Board of Education with a basic stamp 2 v1.
The unit itself will be about the size of a small lunchbox. Thanks
for any and all help you guys can give me.
Should be easy beans. Look up the "button" command for your switches. As the
basic Stamp does not have a timer, you will need to use program loops and
pauses to effect the timing you want.
In pseudo code, something like:
main:
if button1 = high then
pause 10
gosub Armed
endif
endif
goto main
Armed:
for i = 0 to 99
sound alarm
pause X
next
if button3 = high then
pause 10
sound alarm
return
else
goto Armed
endif
if button2 = high then
sound alarm
return
endif
return
This code is very crude, and there are better ways of doing it I am sure,
but it is a start.
Hope this helps,
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, January 08, 2004 7:27 PM
Subject: [noparse][[/noparse]basicstamps] Paintball "bomb" program
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
toggle a pin on and off. This can be used for a blinking led<G>.
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fnQ02zICztrb14Oq8potQhvEsAsqRqDgFh-b5-eznjgjNI01mrVCfiaTWEAhC6inlCFMNanylBhuM14]jpeakall@p...[/url
Sent: Friday, January 09, 2004 10:59 AM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Paintball "bomb" program
Neal,
main:
pause 10
gosub Armed
endif
endif
goto main
Armed:
for i = 0 to 99
sound alarm
pause X
next
pause 10
sound alarm
return
else
goto Armed
endif
sound alarm
return
endif
return
but it is a start.
Hope this helps,
Jonathan
www.madlabs.info
Original Message
> together, feel free to let me know. What i'm trying to build is a
> "bomb" to use in paintball, similar to the game "Counter-strike" on PC
> and Xbox. Don't worry, no dangers in this one, it will simply run a
> relay to a small siren to signal the "bomb" went off and the game is
> innovation first Spike relay. With the switches, the "Arm" switch must
> be held for 10 seconds to turn on the "bomb". A counter will count
> down from 100 seconds, while telling the relay to beep the siren again
> and again, with the time gap in between beeps getting smaller to match
> the timer. Now, the "Disarm" button must be held for 10 seconds to
> turn off the "bomb", which then results in the relay beeping the siren
> in some sort of pattern to let everyone within earshot know that it is
> disarmed. The 3rd button is an instant disarm, for in case the person
> disarming is the one on their team (or has access to the person) with
> the "disarming tool", most likely a headphone plug, which completes
> its switch circuit when installed. This is all built onto a Board of
> Education with a basic stamp 2 v1. The unit itself will be about the
> size of a small lunchbox. Thanks for any and all help you guys can
> give me.
> and
> Yahoo! Groups Links
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
Here's what i've got so far:
'{$STAMP BS2}
main:
IF button1 = HIGH THEN
PAUSE 10
GOSUB Armed
endif
endif
GOTO main
Armed:
FOR i = 0 TO 99
PAUSE 1
NEXT i
FOR b = 0 TO 200 'must be changed to match up with detonation
Spike HIGH
PAUSE .1
Spike LOW
PAUSE (99-i)/5
NEXT b
IF i = 99 THEN
Spike HIGH
PAUSE 10
Spike LOW
GOTO END
IF button3 = HIGH THEN
PAUSE 10
sound alarm
RETURN
else
GOTO Armed
endif
IF button2 = HIGH THEN
GOSUB Disarmed
RETURN
endif
Disarmed:
FOR a = 0 TO 20
spike HIGH
PAUSE .2
spike LOW
PAUSE .5
spike HIGH
PAUSE .5
spike LOW
PAUSE .5
NEXT a
GOTO end
RETURN
END
okay, it's probably alot of misuse of wording and formats, but I
think it's closer to the the finished product.
close. Copy and past my program into your editor to see which parts
come up blue, and which don't, such as the endif statements (not used
to this language of basic). Any translations for these would be
greatly appreciated. Also, i need to rig up 3 seperate on/off
switches and an output for an IFI spike relay, so if you know any
copy/paste solutions for that, i would be greatly thankful.
'{$STAMP BS2}
main:
IF button1 = high THEN
FOR z = 1 TO 10
PAUSE 1
endif
if BUTTON1 = LOW THEN
let z = 1
GOTO main
endif
NEXT z
GOSUB Armed
endif
endif
GOTO main
Armed:
FOR i = 0 TO 99
PAUSE 1
NEXT i
Spike HIGH
PAUSE .1
Spike LOW
PAUSE (99-i)/5
NEXT b
IF i = 99 THEN
Spike HIGH
PAUSE 10
Spike LOW
GOTO END
IF BUTTON2 = HIGH THEN
FOR y = 1 TO 10
PAUSE 1
endif
IF BUTTON2 = LOW THEN
let y = 1
GOTO main
endif
NEXT y
GOSUB Disarmed
endif
endif
IF BUTTON3 = HIGH THEN
GOSUB Disarmed
RETURN
endif
Disarmed:
FOR a = 0 TO 20
spike HIGH
PAUSE .2
spike LOW
PAUSE .5
spike HIGH
PAUSE .5
spike LOW
PAUSE .5
NEXT a
GOTO END
RETURN
END
Add the directive:
'{$PBASIC 2.5}
And use the latest editor. The endif's look ok to me. Of course, the vars
aren't declared, so it won't tokenize. Looks like progress though!
Jonathan
www.madlabs.info
Original Message
Sent: Friday, January 09, 2004 2:43 PM
Subject: [noparse][[/noparse]basicstamps] Re: Paintball "bomb" program
> Okay, here's the program revised alot better, hopefully it's getting
> '{$STAMP BS2}
> main:
> FOR z = 1 TO 10
> PAUSE 1
> endif
> let z = 1
> GOTO main
> endif
> NEXT z
> GOSUB Armed
> endif
> endif
> GOTO main
> Armed:
> FOR i = 0 TO 99
> PAUSE 1
> NEXT i
> Spike HIGH
> PAUSE .1
> Spike LOW
> PAUSE (99-i)/5
> NEXT b
> IF i = 99 THEN
> Spike HIGH
> PAUSE 10
> Spike LOW
> GOTO END
> FOR y = 1 TO 10
> PAUSE 1
> endif
> let y = 1
> GOTO main
> endif
> NEXT y
> GOSUB Disarmed
> endif
> endif
> GOSUB Disarmed
> RETURN
> endif
> Disarmed:
> FOR a = 0 TO 20
> spike HIGH
> PAUSE .2
> spike LOW
> PAUSE .5
> spike HIGH
> PAUSE .5
> spike LOW
> PAUSE .5
> NEXT a
> GOTO END
> RETURN
> END
> Yahoo! Groups Links
I worked all evening to crank this out, with lots of trouble figuring
out a way to keep a failed disarm attempt from restarting the armed
countdown. I've been using an LED hooked up where the speaker would
be, and even then, i plan on eventually replacing the simple speaker
high/low with commands going out to a spike relay, once i know how to
set that up. But for now, the LED has shown me that, using a jumper
wire to immitate switches being held, it works exactly how i want it
to. Here's the program:
'{$STAMP BS2} Program framework by Gary Denison
' Revisions by Neal Muzzy
OUTPUT 2
A VAR Word
B VAR Word
C VAR Word
D VAR Word
E VAR Word
Main:
A=1
IF (IN3 = 1) THEN arm
PAUSE 10
GOTO main
arm:
FOR B = 1 TO 10
IF (IN3 = 0) THEN main
PAUSE 1000
ENDIF
NEXT
GOTO armed
armed:
FOR A = D TO 1000
D=D+1
HIGH 2 'BLINK
PAUSE 20 'BLINK
LOW 2 'BLINK
PAUSE (1000-D)'BLINK
E=E+1
IF (IN4 = 1) THEN GAP
E = 0
GAP:
IF E=10 THEN Disarmed
IF (IN5 = 1) THEN Disarmed
IF C<1000 THEN armed
GOTO detonate
disarmed:
FOR C = 1 TO 100
HIGH 2
PAUSE 100
LOW 2
PAUSE 400
HIGH 2
PAUSE 500
LOW 2
PAUSE 400
NEXT
GOTO main
detonate:
HIGH 2
PAUSE 10000
LOW 2
GOTO main
