Measuring Capacitance
Hi All,
Can anyone direct me to an article or link that shows how to measure
capacitance using a Stamp? I just think it would be neat to try. I'm
familiar with the famous equation V(t)=Vo*e^(-t/tau). The problem is
is after charging the capacitor to Vo, you then have to disconnect
the source so the cap starts to discharge through R, and start an
RCTIME command until the V(t) hits logic swing. I can't think of how
to do these two things at precisely the same time. Thanks for any
help.
-Dave
help.
-Dave
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: nuclearspin2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sMr2lHJCXfR9HDEIrv9kf6e-lgkgwpzVbClZoP9j-ETUnadQIijYZIHoBXxDUp2MOdq3Cx-OxJz4eGZoJki9FsE]nuclearspin2000@y...[/url
Sent: Tuesday, January 06, 2004 6:57 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Measuring Capacitance
Hi All,
help.
-Dave
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
I read through that thoroughly. But there are fundamental problems
with Parallax's description of the circuits used in the examples from
the help file. As examples they present circuit A (preferred) and
circuit B. Circuit A has two variations, the first one is:
Vdd=+5
C
|---220---I/O pin (7)
R
Gnd
Example code from the help file:
result VAR Word ' Word to hold result
Main:
HIGH 7 ' Discharge the cap
PAUSE 1 ' for 1 ms
RCTIME 7, 1, result ' Measure RC charge time
DEBUG ? result ' Show value on screen
END
The problem is that the instruction HIGH 7 doesn't discharge the
capacitor as long as the suggested 220 ohm resistance is there. The
voltage at the lower side of the cap is whatever the voltage drop
across R is when HIGH 7 is executed and it isn't +5V unless R is much
greater than 220 and then it's still an approximation.
Omitting the 220 ohm resistor fixes the above problem and I've done
this in the past but I'm trying to measure a capacitor marked as
1000uF. After working out about a page of calculations I get that R
must be no more than about 43 ohms to keep the time constant small
enough so that the value returned by RCTIME falls within the range
for my BS2SX which is no more than 52.43mS based on 65535*(0.8uS),
and that's also assuming a natural response RC circuit, maybe that's
where I'm going wrong.
Now if I omit the 220 ohm resistor and pull pin 7 high, the current
flowing from the stamp pin is minimally 5V/43ohms=116mA and I fry my
stamp pin.
Maybe I'm making this too complicated but it doesn't seem like it has
a simple solution to me. I guess I'll have to break out my circuits
books.
-Dave
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Take a look at the Stamp RCTIME command.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: nuclearspin2000 [noparse][[/noparse]mailto:nuclearspin2000@y...]
> Hi All,
measure
I'm
is
how
> help.
> -Dave
Subject
> Yahoo! Groups Links
> abuse@p...
values; for the reason you state: to keep the discharge timing in range
your R value is way too low and you'll have problems. The whole point
of the 220 is to protect the Stamp pin from a direct short to ground
where R should be.
What you may want to do is use your cap in a 555 circuit and measure the
output with PULSIN.
-- Jon Williams
-- Dallas Office
Original Message
From: nuclearspin2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AADbmbCc2-K0mDERH91aQLX7gzOgxOBXLdxdGiN2KtnpWDVwgRNgV_VexPOFQSagTgFXogFn15NXg27vMaFPJ6pJ]nuclearspin2000@y...[/url
Sent: Tuesday, January 06, 2004 8:08 PM
Subject: [noparse][[/noparse]basicstamps] Re: Measuring Capacitance
Hi Jon,
Vdd=+5
C
R
Gnd
Main:
PAUSE 1 ' for 1 ms
END
stamp pin.
books.
-Dave
> -- Jon Williams
> -- Dallas Office
Original Message
> Hi All,
measure
I'm
is
how
> help.
> -Dave
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
anything but simple as I originally had suspected. A good value for R
for this circuit was about 100 ohms which should be enough to limit
the Stamp pin current to a safe level when discharging the capacitor,
50mA safe? I used the equation for a first order step response of an
RC circuit:
Vc=Is*R+(Vo-Is*R)*e^(-t/RC)
I replaced Is in my circuit with the Norton equivalent as dictated by
the equation and then solved for C.
A simple RCTIME command then gives the charge time of the capacitor
from 0 to 1.4V (threshold). Since everything else is known I can then
calculate C.
By doing this I calculated a capacitance of 785uF for a 1000uF marked
cap. That's a little more than then stated plus or minus 20% error
but there's probably some round off error going on not to mention the
resolution of the RCTIME command which could contribute as well.
I like your idea of using the 555 timer, especially considering
measuring larger caps would require lower resistances and result in
higher currents through the Stamp pins using RCTIME. I'll try that
next. Best regards,
-Dave
wrote:
> Your points are valid and RCTIME not intended for large capacitance
range
point
> where R should be.
measure the
> output with PULSIN.
> -- Jon Williams
> -- Dallas Office
Original Message
> Hi Jon,
from
> Vdd=+5
> C
> R
> Gnd
> Main:
> PAUSE 1 ' for 1 ms
> END
much
that's
my
> stamp pin.
has
> books.
> -Dave
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > Hi All,
> measure
> I'm
> is
> how
> > help.
> > -Dave
> Subject
> > Yahoo! Groups Links
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
> [noparse][[/noparse]...] A good value for R for this circuit was about 100 ohms
> which should be enough to limit the Stamp pin current to a
> safe level when discharging the capacitor, 50mA safe?
No, it's not, Dave. You need to limit it to an absolute max of 25ma when
sinking, and 20ma when sourcing. 220 ohms is the smallest recommended size
of resistor.
Gary
because the line of code to discharge the cap takes place in just a
couple of mS but I'll have to use more care in the future and rethink
the design. Thanks for the warning.
-Dave
--- In basicstamps@yahoogroups.com, "Gary W. Sims" <simsgw@c...>
wrote:
> From: "nuclearspin2000" <nuclearspin2000@y...>
when
recommended size
> of resistor.
> Gary
take a lot of abuse above the ratings. They will usually survive a
direct short circuit. But, each instance may well shorten the life
of the chip.
In your calculations, remember that the SX stamp output resistance is
around 60 ohms, both sinking and sourcing, and it will not output a
full 5 volts under load.
My approach to a big capacitor would be to make a long-period
"RCtime" command out of a loop, and use a large resistor in the
standard circuit. It would need a little calibration. Use standard
RCTIME for small caps.
o
220---I/O pin (7)
R C
Gnd Gnd
e.g. R=10k C=1000uF RC=10 seconds
DO
HIGH 7 ' charge C
PAUSE 2000 ' RC=0.22 second
ticks=0
INPUT 7 ' C starts discharging thru R
DO
tick=tick+1
PAUSE 9 ' increments of ~10 milliseconds
LOOP WHILE IN7
DEBUG ? ticks
LOOP
-- regards,
Tracy Allen
http://www.emesystems.com/BS2rct.htm
>I was reading that in the Stamp FAQ. I guess I got away with it
>-Dave
>when
>recommended size
>> of resistor.
>> Gary
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
