Do Loop will not execute — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2003-12-29 16:56 in General Discussion
I recently bought a Board of Education and I'm going through
the "What Is a Microcontroller" course. When I came to the section
that turns an LED on and off, I noticed the DO LOOP function does not
work.
My BS2 will not execute the Do Loop command.
When I hit the run button, the program between the DO LOOP runs once.
For example the LED will go on then shut off once.
Can anyone tell me how to get the DO LOOP function working?
  • ArchiverArchiver Posts: 46,084
    edited 2003-12-24 05:43
    John,
    You aren't the first to hit this. Jon Williams of Paralax has been
    helping someone the last 3 or four days. Go back through the
    messages and see what you find. There are quite a few messages.
    Happy Holidays,
    Frank
    --- In basicstamps@yahoogroups.com, "johnharvard03"
    not
    > work.
    once.
    edited 2003-12-24 06:02
    Jon-
    Out of curiosity...
    Do you think the "bad port behavior" is preventing successful
    programming of the Stamp (program download)? Or preventing normal
    execution of a successfully downloaded program? If the latter,
    would removing the programming cable also be effective?
    Can anyone explain the technical details of the FIFO-Stamp issue?
    Thanks and Merry Christmas,
    Steve
    edited 2003-12-24 06:32
    Put a DEBUG statement at the top of your program, like this:
    DEBUG "Test"
    If the program runs normally after that, the problem has to do with your
    serial port. You can "fix" this problem (bad port behavior -- I'm
    betting you're using a laptop) by changing your port FIFO settings to
    their minimum values. I explained how to do this in an earlier post.
    Happy Holidays
    -- Jon Williams
    -- Applications Engineer, Parallax
    -- Dallas Office
    Original Message
    From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RZt76-tUWDe5d9rsXwIXnKX6fMrMZqxrXlArOv94uEjs3N66L866RqFUozip-6fgbsdR24RtADFVKi3Qx3g]johnharvard03@y...[/url
    Sent: Tuesday, December 23, 2003 10:20 PM
    To: basicstamps@yahoogroups.com
    Subject: [noparse][[/noparse]basicstamps] Do Loop will not execute
    work.
    For example the LED will go on then shut off once. Can anyone tell me
    To UNSUBSCRIBE, just send mail to:
    basicstamps-unsubscribe@yahoogroups.com
    from the same email address that you subscribed. Text in the Subject
    and Body of the message will be ignored.
    Yahoo! Groups Links
    To visit your group on the web, go to:
    http://groups.yahoo.com/group/basicstamps/
    To unsubscribe from this group, send an email to:
    Your use of Yahoo! Groups is subject to:
    http://docs.yahoo.com/info/terms/
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-12-24 16:27
    Another thing I've noticed is that the Do Loop
    sometimes does not work if I use the picBasicv2.5
    syntax with an earlier version of the Basic Stamp
    Editor software (v1.33). Once I upgraded the software
    and chose PicBasic2.5 in the Directive menu, the
    DoLoop compiled and worked just fine.
    One this note, when will the Baisc Stamp manual v2.5
    be available to account for the syntactical code
    changes of the latest version?
    thanks,
    ~ danielle
    > like this:
    > DEBUG "Test"
    > has to do with your
    > behavior -- I'm
    > FIFO settings to
    > an earlier post.
    > Happy Holidays
    > -- Jon Williams
    > -- Dallas Office
    Original Message
    > From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=O6jn9y1NmPdLDX-HHVk91hdq3a8vQ99PvS9DSFZhn0GTQ5ZHXJUENV2v9iO11tbzGrfpFFIFLDLTRyiKoYmf]johnharvard03@y...[/url
    > through
    > to the section
    > function does not
    > work.
    > DO LOOP runs once.
    > Can anyone tell me
    > Text in the Subject
    > Yahoo! Groups Links
    > report SPAM to
    > abuse@p....
    > Text in the Subject and Body of the message will be
    > ignored.
    > Yahoo! Groups Links
    __________________________________
    Do you Yahoo!?
    New Yahoo! Photos - easier uploading and sharing.
    http://photos.yahoo.com/
    edited 2003-12-24 16:43
    Hi Danielle -
    The '{$PBASIC 2.5} directive is only recognized by the latest compilers.
    Any earlier version will only view it as a comment, by SMART design.
    >On this note, when will the Baisc Stamp manual v2.5
    Sorry I don't have an answer here. Perhaps Jon can give us some idea.
    Certainly not until after the first of the year, however.
    >thanks,
    >~ danielle
    Bruce Bates
    >> like this:
    >> DEBUG "Test"
    >> has to do with your
    >> behavior -- I'm
    >> FIFO settings to
    >> an earlier post.
    >> Happy Holidays
    >> -- Jon Williams
    >> -- Dallas Office
    Original Message
    >> From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LJ4sQUDQ32rs3YYHHf5nbfJXv1DgjMZAteI1Xko3Q0vOhncQSErcfxsO-d5uToAElVAvAsw3LNXJGEOMC0xth3kq]johnharvard03@y...[/url
    >> through
    >> to the section
    >> function does not
    >> work.
    >> DO LOOP runs once.
    >> Can anyone tell me
    >> Text in the Subject
    >> Yahoo! Groups Links
    >> report SPAM to
    >> abuse@p....
    >> ignored.
    >> Yahoo! Groups Links
    >Do you Yahoo!?
    >from the same email address that you subscribed. Text in the Subject and Body
    >Yahoo! Groups Links
    edited 2003-12-24 18:18
    This is true. DO...LOOP is only available in {$PBASIC 2.5} and works
    only with versions 2.x of the editor. We are actively working on
    updating our manual -- it's a very big process with all the language
    changes, and the addition of the BS1 to the new editor. Keep in mind
    that the online help file will generally be the most up-to-date source
    of syntax information since it is the easiest document for us to update.
    Happy Holidays.
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: Danielle Lee [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jr_n6qDINyXL-C7cIBJ8PQZXYggJBTdKRqSs1vn7eth_bzTwEFjr3wTnInKBZzgXmcl7MMxsE9c]sooki1@y...[/url
    Sent: Wednesday, December 24, 2003 10:27 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Do Loop will not execute
    thanks,
    ~ danielle
    > like this:
    > DEBUG "Test"
    > has to do with your
    > behavior -- I'm
    > FIFO settings to
    > an earlier post.
    > Happy Holidays
    > -- Jon Williams
    > -- Dallas Office
    Original Message
    > From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y5vq3rxcUc6YyjJbNyXKWX_Bc-HefRMBREz39yRNTffdEhVS6JWlHmTroaeip5X3XYvh9F19vmnM5kwyCg]johnharvard03@y...[/url
    > through
    > to the section
    > function does not
    > work.
    > DO LOOP runs once.
    > Can anyone tell me
    > Text in the Subject
    > Yahoo! Groups Links
    > report SPAM to
    > abuse@p....
    > ignored.
    > Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Groups Links
    abuse@p....
    edited 2003-12-24 22:32
    Steve,
    You asked
    I'll take a stab at it. I might be less wrong by way of analogy than in
    specific details.
    FIFO set to none/minimum: every character into the serial port is passed
    immediately to the CPU.
    FIFO set to maximum: characters are buffered by the serial port until a
    large-enough number of characters (the buffer size) is accumulated, and then
    the batch is passed to the CPU. There is a 'time-buffer' as well as a
    'character-buffer'; that is: so as to prevent a partially filled buffer of
    characters from languishing, periodically, the buffer is passed to the CPU
    even if it is not full.
    Communications that depend on tight timing sequences (a response must be
    received within a certain number of milliseconds, or else an error is
    signaled) requre that all serial port characters be passed on to the CPU
    before the sequence's timeout.
    Thus accepting greater CPU load for serial communications (FIFO = none)
    preferred in these cases.
    HTH,
    Daniel
    Original Message
    To: <basicstamps@yahoogroups.com>
    Sent: Wednesday, 24 December 2003 01:02
    > Jon-
    > Out of curiosity...
    > Steve
    edited 2003-12-25 00:36
    > [noparse][[/noparse]...] Once I upgraded the software
    Jon's answer as to publication plans has to be considered authoritative for
    the full manual, since of course he is one of the principal authors -- but
    if you simply want a reference for the syntax, you have one already,
    Danielle. The version of the manual built into your upgraded software is an
    excellent one. I've used nothing else and have found only one or two minor
    editing issues. Click on the rightmost icon of the toolbar to open the
    document.
    Gary
    edited 2003-12-25 03:42
    And if you report those minor issues to me, Gary, I will fixed them as I
    am the keeper of our online help file.
    Another feature of our help system is that you can highlight a keyword
    (double-click it) in the editor, then press the [noparse][[/noparse]F1] key -- help will be
    opened to that keyword.
    Happy Holidays to all.
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: Gary W. Sims [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a-vxmdHgDd4bC8173uytfLBrC92tdsy2aw9eZt5vBpePeSReEw3sZxV4Z73WB27wXF2IRjvZavTcMlDONA]simsgw@c...[/url
    Sent: Wednesday, December 24, 2003 6:36 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Do Loop will not execute
    for the full manual, since of course he is one of the principal authors
    -- but if you simply want a reference for the syntax, you have one
    already, Danielle. The version of the manual built into your upgraded
    software is an excellent one. I've used nothing else and have found only
    one or two minor editing issues. Click on the rightmost icon of the
    toolbar to open the document.
    Gary
    Yahoo! Groups Links
    abuse@p....
    edited 2003-12-25 13:57
    I had a similar problem. It turned out my laptop would shut down the RS232
    drivers when idle and the periodically blip them on(port scanning?) causing a
    reset. I put a switch in the DTR line.
    > execution of a successfully downloaded program? If the latter, would
    edited 2003-12-27 13:29
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    > DEBUG "Test"
    your
    to
    post.
    > Happy Holidays
    > -- Jon Williams
    > -- Dallas Office
    Jon,
    Merry Christmas.
    I placed the DEBUG "Test" line at the top of my program and inside
    and the Do Loop still does not function. Also, I am not using a
    laptop. Is there anything else I can try to get the Do Loop working?
    Thank you,
    Kevin
    Original Message
    > From: johnharvard03 [noparse][[/noparse]mailto:johnharvard03@y...]
    not
    > work.
    once.
    me
    Subject
    > Yahoo! Groups Links
    > abuse@p...
    edited 2003-12-27 16:39
    To be honest, I'm a bit stumped ... but we'll keep trying.
    * You can always download to the Stamp, but the program only runs once.
    Right?
    * You have specified {$PBASIC 2.5}?
    * Your connections and power-supply are good?
    * You're using the latest version of our compiler (Version 2.1, Beta 1),
    right?
    * Have you tried the LED on a different pin with the same results?
    Does this version of the program run any differently?
    Main:
    HIGH LedPin
    PAUSE 500
    LOW LedPin
    PAUSE 500
    GOTO Main
    The code above will run on any BASIC Stamp -- even down to the Stamp 1.
    If that works, try this:
    Main:
    DO
    DEBUG, "Yes, I'm here.", CR
    PAUSE 500
    LOOP
    If the DEBUG version doesn't work then I am going to become suspicious
    of your serial port. Do you have another serial port you can use? You
    may have a goofy or faulty port.
    I'm sorry you're having so many frustrations -- this is way out of the
    norm. The reason the BASIC Stamp is so popular is it's
    plug-it-in-and-it-just-plain-works track record.
    Happy Holidays.
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PMkItKLs1p_DK6rBg5ltBci-kuku2PFT-z4peRMdLW5UYPRI0I-FT2ekjGgwdrVESHL9PlU3K_mlzpRP0uGq]johnharvard03@y...[/url
    Sent: Saturday, December 27, 2003 7:30 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Do Loop will not execute
    > DEBUG "Test"
    your
    to
    post.
    > Happy Holidays
    > -- Jon Williams
    > -- Dallas Office
    Jon,
    Merry Christmas.
    Thank you, Kevin
    Original Message
    not
    > work.
    once.
    me
    Subject
    > Yahoo! Groups Links
    > abuse@p...
    Yahoo! Groups Links
    abuse@p....
    edited 2003-12-27 16:56
    Jon, maybe a try with Hyperterminal would help identify a bad serial cable or
    serial port, although you would think that if he can download the serial
    cable/port would be OK.
    Sid
    edited 2003-12-27 16:58
    The compiler's DEBUG window is just a terminal program that runs in a
    separate thread and can interpret special codes from the Stamp -- it's
    built-in and easier to setup than Hyperterminal.
    -- Jon
    Original Message
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1fTtQ2dcjD7PnMQD4RcwlliFjcfWrlBv5wuCH4suyX33jkerreIWgG-S9FPBOj53XMSsPQ]Newzed@a...[/url
    Sent: Saturday, December 27, 2003 10:57 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: Do Loop will not execute
    cable or
    Sid
    Yahoo! Groups Links
    abuse@p....
    edited 2003-12-27 17:05
    In a message dated 12/27/2003 11:59:38 AM Eastern Standard Time,
    jwilliams@p... writes:
    Then the other weird thought I had was that as the Stamp reads the EEPROM
    and runs the program, it erases the EEPROM. Is that possible?
    Sid
    edited 2003-12-27 19:46
    Not accidently. Perhaps there's a bad part on the board.
    -- Jon Williams
    -- Parallax
    Original Message
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gZbJfwhD69yp8dZhrgj9-xcLEv29ZO-ZDW33rK5-jIeFh9zcN0FQyMm6_b9nUxto-zX6XQjIJw]Newzed@a...[/url
    Sent: Saturday, December 27, 2003 11:06 AM
    EEPROM and runs the program, it erases the EEPROM. Is that possible?
    Sid
    Yahoo! Groups Links
    abuse@p....
    edited 2003-12-28 03:19
    Jon,
    Thank you for your response.
    The Main: GOTO Main function does work on my board. I will continue
    through the "What Is a Microcontroller" course using
    the NAME: GOTO NAME function whenever a DO LOOP is required.
    The Main:
    > DO
    > PAUSE 500
    > LOOP
    did not work.
    I don't have a second com port to try.
    I am using the serial cable that was supplied with the BOE.
    Also, I did change my computer's Com Port 1 Receive Buffer and
    Transmit Buffer
    to the lowest settings, but that did not help.
    Regarding your other questions:
    once.
    Right?
    YES
    YES
    YES
    1),
    right?
    The CD sent with my BOE has version 2.0 Beta 2 as the latest.
    Yes, I tried the LED on different pins, but same results.
    Kevin
    once.
    > Right?
    Beta 1),
    > right?
    > Main:
    > HIGH LedPin
    > PAUSE 500
    > LOW LedPin
    > PAUSE 500
    > GOTO Main
    Stamp 1.
    > Main:
    > DO
    > PAUSE 500
    > LOOP
    suspicious
    You
    the
    > Happy Holidays.
    > -- Jon Williams
    > -- Dallas Office
    edited 2003-12-28 14:55
    Okay, well I'm glad that your Stamp is working. Please download and
    install the latest version of our compiler. We are only able to update
    CDs a couple times a year, so the software on the CD is not always the
    latest. Here's the page:
    http://www.parallax.com/html_pages/downloads/software/software_basic_sta
    mp.asp
    In case the link gets broken, go to our web site, then select Downloads
    -> Basic Stamp Software from the menu bar.
    DO-LOOP is very powerful and goes beyond GOTO-Label, so we'd like you to
    be able to use it.
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7seo0pr2IfiPhDobXx1nISBlq7vYJXPLrqfXlG3I-1gbJ5DB_3Ap7ctwtCr8_VGso__h7xdHbzjR-cTgrhNA]johnharvard03@y...[/url
    Sent: Saturday, December 27, 2003 9:19 PM
    Jon,
    The Main:
    > DO
    > PAUSE 500
    > LOOP
    did not work.
    Transmit Buffer
    once.
    Right?
    YES
    YES
    YES
    1),
    right?
    * Have you tried the LED on a different pin with the same results? Yes,
    Kevin
    once.
    > Right?
    Beta 1),
    > right?
    > Main:
    > HIGH LedPin
    > PAUSE 500
    > LOW LedPin
    > PAUSE 500
    > GOTO Main
    Stamp 1.
    > Main:
    > DO
    > PAUSE 500
    > LOOP
    suspicious
    You
    the
    > Happy Holidays.
    > -- Jon Williams
    > -- Dallas Office
    Yahoo! Groups Links
    abuse@p....
    Well, there are two special purpose calls which
    do allow you to read and write the EEPROM.
    If you don't use the 'Write' call, though,
    I don't think there is ANY OTHER way to
    write to the EEPROM during normal use.
    Of course, the IDE writes to the EEPROM
    when it first compiles the program, but
    you're not talking about that part.
    in a
    it's
    EEPROM
    > Sid
