Do Loop will not execute
I recently bought a Board of Education and I'm going through
the "What Is a Microcontroller" course. When I came to the section
that turns an LED on and off, I noticed the DO LOOP function does not
work.
My BS2 will not execute the Do Loop command.
When I hit the run button, the program between the DO LOOP runs once.
For example the LED will go on then shut off once.
Can anyone tell me how to get the DO LOOP function working?
work.
You aren't the first to hit this. Jon Williams of Paralax has been
helping someone the last 3 or four days. Go back through the
messages and see what you find. There are quite a few messages.
Happy Holidays,
Frank
--- In basicstamps@yahoogroups.com, "johnharvard03"
not
> work.
once.
Out of curiosity...
Do you think the "bad port behavior" is preventing successful
programming of the Stamp (program download)? Or preventing normal
execution of a successfully downloaded program? If the latter,
would removing the programming cable also be effective?
Can anyone explain the technical details of the FIFO-Stamp issue?
Thanks and Merry Christmas,
Steve
DEBUG "Test"
If the program runs normally after that, the problem has to do with your
serial port. You can "fix" this problem (bad port behavior -- I'm
betting you're using a laptop) by changing your port FIFO settings to
their minimum values. I explained how to do this in an earlier post.
Happy Holidays
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RZt76-tUWDe5d9rsXwIXnKX6fMrMZqxrXlArOv94uEjs3N66L866RqFUozip-6fgbsdR24RtADFVKi3Qx3g]johnharvard03@y...[/url
Sent: Tuesday, December 23, 2003 10:20 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Do Loop will not execute
work.
For example the LED will go on then shut off once. Can anyone tell me
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
sometimes does not work if I use the picBasicv2.5
syntax with an earlier version of the Basic Stamp
Editor software (v1.33). Once I upgraded the software
and chose PicBasic2.5 in the Directive menu, the
DoLoop compiled and worked just fine.
One this note, when will the Baisc Stamp manual v2.5
be available to account for the syntactical code
changes of the latest version?
thanks,
~ danielle
--- Jon Williams <jwilliams@p...> wrote:
> Put a DEBUG statement at the top of your program,
> like this:
> DEBUG "Test"
> has to do with your
> behavior -- I'm
> FIFO settings to
> an earlier post.
> Happy Holidays
> -- Jon Williams
> -- Dallas Office
Original Message
> From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=O6jn9y1NmPdLDX-HHVk91hdq3a8vQ99PvS9DSFZhn0GTQ5ZHXJUENV2v9iO11tbzGrfpFFIFLDLTRyiKoYmf]johnharvard03@y...[/url
> through
> to the section
> function does not
> work.
> DO LOOP runs once.
> Can anyone tell me
> Text in the Subject
> Yahoo! Groups Links
> report SPAM to
> abuse@p....
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing.
http://photos.yahoo.com/
>Another thing I've noticed is that the Do Loop
Hi Danielle -
The '{$PBASIC 2.5} directive is only recognized by the latest compilers.
Any earlier version will only view it as a comment, by SMART design.
>On this note, when will the Baisc Stamp manual v2.5
Sorry I don't have an answer here. Perhaps Jon can give us some idea.
Certainly not until after the first of the year, however.
>thanks,
>~ danielle
Bruce Bates
>> like this:
>> DEBUG "Test"
>> has to do with your
>> behavior -- I'm
>> FIFO settings to
>> an earlier post.
>> Happy Holidays
>> -- Jon Williams
>> -- Dallas Office
Original Message
>> From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LJ4sQUDQ32rs3YYHHf5nbfJXv1DgjMZAteI1Xko3Q0vOhncQSErcfxsO-d5uToAElVAvAsw3LNXJGEOMC0xth3kq]johnharvard03@y...[/url
>> through
>> to the section
>> function does not
>> work.
>> DO LOOP runs once.
>> Can anyone tell me
>> Text in the Subject
>> Yahoo! Groups Links
>> report SPAM to
>> abuse@p....
>> ignored.
>> Yahoo! Groups Links
>Do you Yahoo!?
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
only with versions 2.x of the editor. We are actively working on
updating our manual -- it's a very big process with all the language
changes, and the addition of the BS1 to the new editor. Keep in mind
that the online help file will generally be the most up-to-date source
of syntax information since it is the easiest document for us to update.
Happy Holidays.
-- Jon Williams
-- Dallas Office
Original Message
From: Danielle Lee [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jr_n6qDINyXL-C7cIBJ8PQZXYggJBTdKRqSs1vn7eth_bzTwEFjr3wTnInKBZzgXmcl7MMxsE9c]sooki1@y...[/url
Sent: Wednesday, December 24, 2003 10:27 AM
Subject: RE: [noparse][[/noparse]basicstamps] Do Loop will not execute
thanks,
~ danielle
> like this:
> DEBUG "Test"
> has to do with your
> behavior -- I'm
> FIFO settings to
> an earlier post.
> Happy Holidays
> -- Jon Williams
> -- Dallas Office
Original Message
> From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y5vq3rxcUc6YyjJbNyXKWX_Bc-HefRMBREz39yRNTffdEhVS6JWlHmTroaeip5X3XYvh9F19vmnM5kwyCg]johnharvard03@y...[/url
> through
> to the section
> function does not
> work.
> DO LOOP runs once.
> Can anyone tell me
> Text in the Subject
> Yahoo! Groups Links
> report SPAM to
> abuse@p....
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
abuse@p....
You asked
I'll take a stab at it. I might be less wrong by way of analogy than in
specific details.
FIFO set to none/minimum: every character into the serial port is passed
immediately to the CPU.
FIFO set to maximum: characters are buffered by the serial port until a
large-enough number of characters (the buffer size) is accumulated, and then
the batch is passed to the CPU. There is a 'time-buffer' as well as a
'character-buffer'; that is: so as to prevent a partially filled buffer of
characters from languishing, periodically, the buffer is passed to the CPU
even if it is not full.
Communications that depend on tight timing sequences (a response must be
received within a certain number of milliseconds, or else an error is
signaled) requre that all serial port characters be passed on to the CPU
before the sequence's timeout.
Thus accepting greater CPU load for serial communications (FIFO = none)
preferred in these cases.
HTH,
Daniel
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, 24 December 2003 01:02
> Jon-
> Out of curiosity...
> Steve
> [noparse][[/noparse]...] Once I upgraded the software
Jon's answer as to publication plans has to be considered authoritative for
the full manual, since of course he is one of the principal authors -- but
if you simply want a reference for the syntax, you have one already,
Danielle. The version of the manual built into your upgraded software is an
excellent one. I've used nothing else and have found only one or two minor
editing issues. Click on the rightmost icon of the toolbar to open the
document.
Gary
am the keeper of our online help file.
Another feature of our help system is that you can highlight a keyword
(double-click it) in the editor, then press the [noparse][[/noparse]F1] key -- help will be
opened to that keyword.
Happy Holidays to all.
-- Jon Williams
-- Dallas Office
Original Message
From: Gary W. Sims [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a-vxmdHgDd4bC8173uytfLBrC92tdsy2aw9eZt5vBpePeSReEw3sZxV4Z73WB27wXF2IRjvZavTcMlDONA]simsgw@c...[/url
Sent: Wednesday, December 24, 2003 6:36 PM
Subject: Re: [noparse][[/noparse]basicstamps] Do Loop will not execute
for the full manual, since of course he is one of the principal authors
-- but if you simply want a reference for the syntax, you have one
already, Danielle. The version of the manual built into your upgraded
software is an excellent one. I've used nothing else and have found only
one or two minor editing issues. Click on the rightmost icon of the
toolbar to open the document.
Gary
Yahoo! Groups Links
abuse@p....
drivers when idle and the periodically blip them on(port scanning?) causing a
reset. I put a switch in the DTR line.
> execution of a successfully downloaded program? If the latter, would
wrote:
> Put a DEBUG statement at the top of your program, like this:
> DEBUG "Test"
your
to
post.
> Happy Holidays
> -- Jon Williams
> -- Dallas Office
Jon,
Merry Christmas.
I placed the DEBUG "Test" line at the top of my program and inside
and the Do Loop still does not function. Also, I am not using a
laptop. Is there anything else I can try to get the Do Loop working?
Thank you,
Kevin
Original Message
> From: johnharvard03 [noparse][[/noparse]mailto:johnharvard03@y...]
not
> work.
once.
me
Subject
> Yahoo! Groups Links
> abuse@p...
* You can always download to the Stamp, but the program only runs once.
Right?
* You have specified {$PBASIC 2.5}?
* Your connections and power-supply are good?
* You're using the latest version of our compiler (Version 2.1, Beta 1),
right?
* Have you tried the LED on a different pin with the same results?
Does this version of the program run any differently?
Main:
HIGH LedPin
PAUSE 500
LOW LedPin
PAUSE 500
GOTO Main
The code above will run on any BASIC Stamp -- even down to the Stamp 1.
If that works, try this:
Main:
DO
DEBUG, "Yes, I'm here.", CR
PAUSE 500
LOOP
If the DEBUG version doesn't work then I am going to become suspicious
of your serial port. Do you have another serial port you can use? You
may have a goofy or faulty port.
I'm sorry you're having so many frustrations -- this is way out of the
norm. The reason the BASIC Stamp is so popular is it's
plug-it-in-and-it-just-plain-works track record.
Happy Holidays.
-- Jon Williams
-- Dallas Office
Original Message
From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PMkItKLs1p_DK6rBg5ltBci-kuku2PFT-z4peRMdLW5UYPRI0I-FT2ekjGgwdrVESHL9PlU3K_mlzpRP0uGq]johnharvard03@y...[/url
Sent: Saturday, December 27, 2003 7:30 AM
Subject: [noparse][[/noparse]basicstamps] Re: Do Loop will not execute
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
> DEBUG "Test"
your
to
post.
> Happy Holidays
> -- Jon Williams
> -- Dallas Office
Jon,
Merry Christmas.
Thank you, Kevin
Original Message
not
> work.
once.
me
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
serial port, although you would think that if he can download the serial
cable/port would be OK.
Sid
separate thread and can interpret special codes from the Stamp -- it's
built-in and easier to setup than Hyperterminal.
-- Jon
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1fTtQ2dcjD7PnMQD4RcwlliFjcfWrlBv5wuCH4suyX33jkerreIWgG-S9FPBOj53XMSsPQ]Newzed@a...[/url
Sent: Saturday, December 27, 2003 10:57 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Do Loop will not execute
Jon, maybe a try with Hyperterminal would help identify a bad serial
cable or
Sid
Yahoo! Groups Links
abuse@p....
jwilliams@p... writes:
> The compiler's DEBUG window is just a terminal program that runs in a
Then the other weird thought I had was that as the Stamp reads the EEPROM
and runs the program, it erases the EEPROM. Is that possible?
Sid
-- Jon Williams
-- Parallax
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gZbJfwhD69yp8dZhrgj9-xcLEv29ZO-ZDW33rK5-jIeFh9zcN0FQyMm6_b9nUxto-zX6XQjIJw]Newzed@a...[/url
Sent: Saturday, December 27, 2003 11:06 AM
In a message dated 12/27/2003 11:59:38 AM Eastern Standard Time,
EEPROM and runs the program, it erases the EEPROM. Is that possible?
Sid
Yahoo! Groups Links
abuse@p....
Thank you for your response.
The Main: GOTO Main function does work on my board. I will continue
through the "What Is a Microcontroller" course using
the NAME: GOTO NAME function whenever a DO LOOP is required.
The Main:
> DO
> PAUSE 500
> LOOP
did not work.
I don't have a second com port to try.
I am using the serial cable that was supplied with the BOE.
Also, I did change my computer's Com Port 1 Receive Buffer and
Transmit Buffer
to the lowest settings, but that did not help.
Regarding your other questions:
once.
Right?
YES
YES
YES
1),
right?
The CD sent with my BOE has version 2.0 Beta 2 as the latest.
Yes, I tried the LED on different pins, but same results.
Kevin
wrote:
> To be honest, I'm a bit stumped ... but we'll keep trying.
once.
> Right?
Beta 1),
> right?
> Main:
> HIGH LedPin
> PAUSE 500
> LOW LedPin
> PAUSE 500
> GOTO Main
Stamp 1.
> Main:
> DO
> PAUSE 500
> LOOP
suspicious
You
the
> Happy Holidays.
> -- Jon Williams
> -- Dallas Office
install the latest version of our compiler. We are only able to update
CDs a couple times a year, so the software on the CD is not always the
latest. Here's the page:
http://www.parallax.com/html_pages/downloads/software/software_basic_sta
mp.asp
In case the link gets broken, go to our web site, then select Downloads
-> Basic Stamp Software from the menu bar.
DO-LOOP is very powerful and goes beyond GOTO-Label, so we'd like you to
be able to use it.
-- Jon Williams
-- Dallas Office
Original Message
From: johnharvard03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7seo0pr2IfiPhDobXx1nISBlq7vYJXPLrqfXlG3I-1gbJ5DB_3Ap7ctwtCr8_VGso__h7xdHbzjR-cTgrhNA]johnharvard03@y...[/url
Sent: Saturday, December 27, 2003 9:19 PM
Jon,
The Main:
> DO
> PAUSE 500
> LOOP
did not work.
Transmit Buffer
once.
Right?
YES
YES
YES
1),
right?
* Have you tried the LED on a different pin with the same results? Yes,
Kevin
once.
> Right?
Beta 1),
> right?
> Main:
> HIGH LedPin
> PAUSE 500
> LOW LedPin
> PAUSE 500
> GOTO Main
Stamp 1.
> Main:
> DO
> PAUSE 500
> LOOP
suspicious
You
the
> Happy Holidays.
> -- Jon Williams
> -- Dallas Office
Yahoo! Groups Links
abuse@p....
do allow you to read and write the EEPROM.
If you don't use the 'Write' call, though,
I don't think there is ANY OTHER way to
write to the EEPROM during normal use.
Of course, the IDE writes to the EEPROM
when it first compiles the program, but
you're not talking about that part.
in a
it's
EEPROM
> Sid
