There are several "flavors" of CMOS, and with some you don't need to do any
translating for use with TTL signal levels. I'm not sure, though, if you're
talking about translating signal levels/voltages, or replacing CMOS
components with TTL components. I'll guess that it's the former...
If you can get your hands on a copy of "The Art of Electronics, 2nd ed."
there is a nice chart on p. 475 with the input and output signal levels for
a number of popular digital IC families. The 74HCTxxx family perfectly
matches TTL signal levels. It, along with TTL, Stamps and Microchip PICs,
has the input high/low voltage threshold at roughly 1.5 volts. The fact
that the CMOS outputs are much closer to 0 volts for a low and 5 volts for a
high adds noise immunity vs. the TTL output voltage levels. So the
74HCTxxx, Stamp, and PIC CMOS output signal voltages will drive TTL inputs
nicely.
...Or were you talking about the older 4xxx CMOS parts that may be operating
at voltages other than 5 volts? There are ways to deal with that as well.
I may just try and see if it will work without any extra chips.
I have a tool that operates at 3V. It has a computer port that
outputs CMOS levels. I purchased a cable that did CMOS -> RS232.
Thought I would eliminate the cable.
Frank
--- In basicstamps@yahoogroups.com, "Randy Jones" <randyjones@w...>
wrote:
> Hi Frank,
to do any
if you're
ed."
levels for
perfectly
Microchip PICs,
fact
volts for a
inputs
> nicely.
operating
as well.
> Randy
> www.glitchbuster.com
> > Is there a logic level translator or something else to go from
CMOS
> > to TTL?
> > Thanks,
> > Frank
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
Subject and
> Body of the message will be ignored.
> > Yahoo! Groups Links
> > To visit your group on the web, go to:
> > http://groups.yahoo.com/group/basicstamps/
> > To unsubscribe from this group, send an email to:
> > Your use of Yahoo! Groups is subject to:
> > http://docs.yahoo.com/info/terms/
Take a look at the Max3232CPE. It is power by 3 volt, and it's a 3
volt serial to +/-12 volt converter. I used it between a cell phone
and a PC. It works just like a regular serial 232 level converter.
Remember the 4 caps.
If you connect your 3 volt gadget via the Max 3232cpe, in to BS port
16, you are online. Or bye a regular Max232 to convert down from
12volt to TTL 5 volt, and use Input 0-15 on the stamp. But then you
end up with two serial converters. (Not the best solution regarding
noise and stability)
I recommend you to study the serial converters for future use. They
are wary handy when you need to develop something to BS. Hook up a
few LED to get an understanding of data flow. Remember 1K resistor
to LED on the 12V side.
If you are planning to convert regular 3 volt Logic signal, try
Motorola HC244A or HC245A.
STEIN.
--- In basicstamps@yahoogroups.com, "franksmith512"
<franksmith512@y...> wrote:
> Thanks Randy!
> Thanks,
> Frank
<randyjones@w...>
> wrote:
> > Hi Frank,
need
> to do any
though,
> if you're
CMOS
former...
2nd
> ed."
> levels for
> perfectly
> Microchip PICs,
The
> fact
> volts for a
the
TTL
> inputs
> > nicely.
be
> operating
that
> as well.
> > Randy
> CMOS
> > > to TTL?
> > > Thanks,
> > > Frank
> Subject and
> > > Yahoo! Groups Links
Will try the HC244A. That should do it. Even the Max3232cpe through
a Max232A is better than a $70 cable. I plan to have two or three of
my gadgets running at a time.
eeee..... I don't think the HC244A is meant to convert serial data,
just logic 0-3 volt converting to 0-5 volt (or vise versa). So stick
to serial converter if it's serial, and logic converter like the
HC244/245 when it's logic converting.
Stein
> Stein,
through
of
> Happy Holidays,
> Frank
nicely.
Randy
> Is there a logic level translator or something else to go from CMOS
> to TTL?
> Thanks,
> Frank
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
Frank
wrote:
> Hi Frank,
to do any
if you're
ed."
levels for
perfectly
Microchip PICs,
fact
volts for a
inputs
> nicely.
operating
as well.
> Randy
CMOS
> > to TTL?
> > Thanks,
> > Frank
Subject and
> > Yahoo! Groups Links
STEIN.
> Thanks Randy!
> Thanks,
> Frank
<randyjones@w...>
> wrote:
> > Hi Frank,
need
> to do any
though,
> if you're
CMOS
former...
2nd
> ed."
> levels for
> perfectly
> Microchip PICs,
The
> fact
> volts for a
the
TTL
> inputs
> > nicely.
be
> operating
that
> as well.
> > Randy
> CMOS
> > > to TTL?
> > > Thanks,
> > > Frank
> Subject and
> > > Yahoo! Groups Links
These are pin compatible with the MAX232 and fit in our RS-I boards:
http://www.al-williams.com/rs1.htm -- very handy for breadboarding.
Al Williams
AWC
Happy Holidays,
Frank
Stein
> Stein,
through
of
> Happy Holidays,
> Frank
