Basic stamp frying my serial ports -- solutions?
I've fried 2 serial ports with my Basic Stamp. I'm using the BS2-IC.
I've connected Tx/Rx and ground to the serial connector as per
instructions in the Stamp manual. Also, I've connected DCD to +12V
(through a 2.2k resistor). I need DCD to be 1 for Linux (otherwise
Linux fails to open the serial port). The Basic Stamp is being powered
by a PC-style power supply. I feed the power supply's 12V through a
7805, then feed the 5V to the Stamp. The power supply's from an old
Compaq PC I had laying around.
Can anyone offer any advice? Has anyone else had their serial ports
fried by a Basic Stamp?
Thanks.
- Chuck Messenger
Thanks.
- Chuck Messenger
connector, NOT to +12 through a resistor.
That '+12 through a resistor' thing only works
on the BS2 pins because it has VERY robust
protection diodes on it -- not true about a
'real' RS-232 driver which your PC is using.
This could be what is frying your port.
--- In basicstamps@yahoogroups.com, Chuck Messenger <chuck@c...>
IC.
powered
a
old
ports
> Thanks.
> - Chuck Messenger
for DCD, DTR, and DSR are connected, so when the serial port is opened by
Linux, the DTR signal goes to space (0 V and +12 V), and that drives the
DCD and DSR to space.
On my Linux computer, before I open the serial port, DTR is mark (-12 V).
When I open the serial port, DTR changes to space (+ 12 V). When the DB9
cable is connected to the NX-1000 board, the DCD and DSR pins follow the DTR
signal.
__________________
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, December 18, 2003 7:32 AM
Subject: [noparse][[/noparse]basicstamps] Basic stamp frying my serial ports -- solutions?
> Thanks.
> - Chuck Messenger
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
to RESET the BS2. As such, it doesn't loop it back
at all. Now, I don't have an NX-1000 board, so I
don't know how it's wired. Plus, I'm using Windows,
so I don't know what Linux wants either.
I also believe the BOE loops RTS(7) to DSR (6),
in order to detect if the cable is connected or not.
An 'inactive' serial port should output DTR -12,
RTS -12, and TX -12. When you 'activate' the port,
DTR should go to +12, and RTS should go to +12.
--- In basicstamps@yahoogroups.com, "Steve Nelick" <s.nelick@v...>
wrote:
> I'm using Linux and a BS2. I thought that the pins on the Parallax
boards
opened by
drives the
12 V).
the DB9
follow the DTR
> signal.
> __________________
Original Message
> From: "Chuck Messenger" <chuck@c...>
solutions?
IC.
+12V
(otherwise
powered
through a
old
ports
> > Thanks.
> > - Chuck Messenger
Subject and
> > Yahoo! Groups Links
(Board of Education). The BOE has one DB9 port for programming and
interfacing.
I've been using the Parallax NX-1000 Stamp Works Experiment Board, and the
board has two DB9 connectors. One is labeled DOWNLOAD, and the other is
labeled RS-232 INTERFACING. The one labeled DOWNLOAD, is like you said, DTR
is connected to ATN and RESET. I was using the other DB9 connector, the one
labeled RS-232 INTERFACING, and I was going by the diagram in the BASIC
STAMP MANUAL, figure 5.32 "Serial Port Diagram Showing Correct Connections
to a BASIC Stamp's I\O pin".
Getting back to Chuck's question, I guess one way to connect from Linux to
the BS2 is to not use DTR and DCD. If Chuck is using a c program, open()
has a flag , O-NDELAY, which says do not look for the DCD signal, and to
set the DTR line low, there is ioctl() and the ~TIOCM_DTR constant.
____________________
Original Message
Sent: Thursday, December 18, 2003 1:22 PM
Subject: [noparse][[/noparse]basicstamps] Re: Basic stamp frying my serial ports -- solutions?
> The BS2 'BOE' (board of education) uses DTR going high
> boards
> opened by
> drives the
> 12 V).
> the DB9
> follow the DTR
> > signal.
> > __________________
Original Message
> solutions?
> IC.
> +12V
> (otherwise
> powered
> through a
> old
> ports
> > > Thanks.
> > > - Chuck Messenger
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
> You should probably connect DCD to DTR on the
OK, sounds promising. Thanks for the suggestion.
(and thanks to the other responders, too...)
- Chuck
